BLF recoil über-thrower
It would have the same relation between throw and area as a normal reflector. A potential advantage is that it could be made to gather near 100% of the light into the beam. However, as I was explaining in the other thread, the increase in light collection won’t be large because standard reflectors are already pretty good at this.
For example, a C8 reflector, with depth=32mm and reflecting diameter=38mm, collects 74% of the light (lumens) into the beam. Only 26% escapes as spill.
Interesting project!!
You’ll find that reserved post handy down the road
Notes: updates in the OP do not give a thread that red “update” flag or put it back on top (so ideal for interest list and such)
You can PM 10 people at the time, a reply from one of those will be send to all.
Well there’s more than none on the market. A search turned up this one, for instance. I’m not saying its a good light, only that it is out there. This idea has been tried before, just not to great effect.
Sold out, like the good old Ultrafire UF-007. It was an interesting light but not worked out as well as could be done (pretty low-driven XR-E led).
I’m in for one of these.
I have one of those budget recoil throwers. It certainly had potential, but didn’t deliver in stock form. And despite several attempts at modding it I’ve got nowhere with it. But a well designed one from the ground up would be a pretty cool addition to the collection.
Have this one:
http://s.aliexpress.com/qMFbuqEb
(from AliExpress Android)
Where did you get a parabolic reflector?
Or do you have a spherical hollow reflector?
Anyway, keep us posted.
That one has an even smaller reflector (pure waste of head size!) than the original UF-007 !
Copper LED support must be like Mersedes label star.
That’s crazy cheap…
I have this one:
It seems the original has a larger mirror / the cheap one has a tiny mirror in it.
And the mirror in the original one is already small and shallow, it only picks up less than 60°
[edit] no, it seems to catch 90° of the LED light[/edit]
of the emitter light, and then it’s hindered by that big XR-E…
It does throw well though, very tight beam, but i have always found it a frustrating and inefficient design.
I think the mirror is spherical by the way, but you don’t notice that when you only use < 60° [edit]that’s 90°[/edit]
I’m planning to mod it one day, replace the boom / holder and put an XP-E2 or maybe an XP-C in it, but again, i can’t find parabolic mirrors, would have to use original mirror.
This seems to be the thing that discourages folks.
But i think that with a copper boom / arm / LED holder, on which the thermal slug of the LED is soldered directly, will suffice.
In my drawing it may be too thin a fin perhaps, although i think 2mm wide will do the job, both as a thermal path and as a sturdy holder.
The “Mercedes star” would look great though, but maybe a fin across the whole diameter would be best, fitting in 2 slots in the head, centring and focusing easier / more reliable and exact in production of the light.
Been waiting for you to start a thread on this. Really sounds exciting.
I used to have a 6 inch reflector telescope that I gave to a friend to give to their kid for Christmas. My understanding is that the kid only tried to use it once. I wasn't aware of recoil lights back then. A soon as I learned about recoils, I regretted gifting it. It was one of those lower-end Tasco telescopes, but I bet it would have worked great.
To collect close to 100% of the light the parabolic mirror should have its focus point near the height of the rim. Mirrors used in telescopes have their focus point much farther away, which is necessary to make a good image. In that case only a small amount of light would be collected.
I think it’s because you can’t use normal MCPCBs and you have the + and - leads that have to be long (and thus not too thin).
For a flashlight spill is a good thing usually, or zoomable, not a fixed pin spot.
There seem to be no decent affordable parabolic reflectors out there either, so it’s all unusual parts you need for a recoil.
None the less, modern small footprint high intensity LEDs are ideal for a recoil set up, as they’re hardly in the way of the reflected light (unlike the old XR-E models), plus LED’s radiate their light in the suited direction for a recoil.
Dumb question, doesn’t the ” boom” get in the way of the light?
In the first drawing i limited the diameter of the mirror to where it was 45°, for a full 180° reflection.
That’s how i found the focal point.
In the new drawing i just used the same, but limited it to about 145° by cutting off some of the rim of the reflector.
So the focalpoint is more or less accurate in the new drawing too.
But, the drawing is for reference only, because i didn’t know how to draw a perfect parabole.
I tried, but it’s apparently almost spherical (concave)…
Yes it does, but it’s only a thin fin.
I will calculate how many % it would block when it’s 2mm wide.
Probably less than 2%.
The reason for making or buying a recoil style light like this is for the Beam shape in particular. Yeah, it’s not the perfect setup, but the beam is so cute! I have the 007 and I would want to try one that was smaller and not as bright.
Been considering doing this for quite a while, I've always wanted a long range spotlight like those HID throwers.
The only issue is that the LED surface area is much larger than what a short arc would be, and far less lumens too.
That leads to a large spread and less intense beam, unless you use a really large reflector.
If I do this I will be watercooling the LED, because the distance of the copper "arm" is too long to provide good cooling for a high power LED running at 12 amps or more.
There are some good reflectors from edmund options for $50-100 that are 12-24" diameter and have a short focal length. Problem is that edmund optics import costs are extremely high.
I've ordered a lens from them before and it the COD was more expensive than the lens itself. Can't imagine what it would be like for a 12" or 24" huge box....
http://www.edmundoptics.com/optics/optical-mirrors/focusing-concave-mirrors/large-parabolic-reflectors/1364/
Another option is this guy that makes acrylic parabolic mirrors for sun collection, not sure how accurate the parabola is but the 24" and 37" deep parabolics seem pretty good quality, and shipping within the US is cheap.
http://greenpowerscience.com/SHOPARABLOICHOME.html
The larger the diameter, the tighter the beam will be. This is really important if you plan to use a large LED like XHP70, SST90, SBT140, or something like that which has lots of lumens.
I'm not sure how large you're planning to make yours, based on the image I would guess 6-12". I am interested if anyone can find a good cheap parabolic reflector below 12" with an accurate parabola.
Remember that the smaller the mirror is, the more accurate the parabola needs to be, and the smaller the LED die needs to be. XP-L HI or dedomed XP-G3 would be optimal IMO.
Best surface brightness (lumens/mm^2) I have found so far.
My idea entails an XP-L HI or an XP-G2 or 3(dedomed) or maybe even a hard driven XP-E2?
I was thinking about 4 to 5 inch diameter reflector.
Finding good ones that are deep enough to take 145° of light is indeed the problem…
…that is, when you’re on a tight budget…
For this to get built by the hundreds i think they would have to be custom made in China to make it affordable.
I fear this is where this idea will cease…
I’m hoping for someone here with the right connections with Chinese manufacturers.
