I suppose they are from medicine. I will try to find them in medical equipment shop (I knew that smth similar does exist but still continue using low-cost chinese tweezers).
I received my spacers yesterday. Looking good. Shipping was quite fast from Russia to Germany. Will report back when I have the first one installed. Thank you very much, kiriba-ru!
Here is it:
Neck+short tube=18650 light
To use 18350 (s), you need extra rings (number of rings=number of 18350)
I have only big rings that fit tail right now (made from SS). Later I will make smaller ones (to use them between tubes) and those one that can fit between neck and head (all from brass). Head side is little long, if you wont use ring between head and neck you need to sand it down a little or just put some o-ring there.
You can screw-in any convoy S series pill. Triple pill or single pill with spacer can be used to build quad with Carclo optics, single pill without spacer can be used together with some single optics.
You can use long tweezers to adjust pill position for optics height.
Just received my package from kiriba-ru, color me very pleased. The spacer seems nice and everything was packaged very very well. He even shipped it in this nice little plastic box. Tracking was provided and accurate. Would recommend!!
I had a couple of questions about the solid neck p60 AL. Do you mean that, the neck + 18350 extension tube, head, and tail = you can fit a 18650 cell? Also I’m not sure if I understand what you mean by if you add extra rings you can use 18350 cells. Is that for multi-battery setups?
Yes neck only is close to fit 18350 cell inside.
One 18350 cell is longer than half of 18650 cell length (and ext tube length), two 18350 cells are longer than one 18650 cell and etc.
So if you will use one or two 18650 cells, you will have enought space for cells inside and extra rings allow you to use protected cells.
But if you are going to use one, two, three or four 18350 cells you have to add at least one, two, three or four rings respectively.
I have made 2 of them from Al and 2 from Cu so this are test versions. They are not so pretty as I wish.
Anyway I cant polish them soon, I will try to sell them as is.
Some members have asked me about them, I will contact them PMs and make my offer.
So Im not sure that I have them on sale, I can say that they are already reserved, if those that asked about them earlier will refuse, I can contact you.
How do you think, is here any need in stock design p60 pills in copper? Some drop-in manufactures using brass pill with xhp50, xhp70, driving up to 20W to the led. Not good at all.
X6 SS version spacers and U11 kits will be ready in a week in work.
Next to produce:
- P60 copper pill (for single led and stock reflector, surefire-compatible, with driver retaining)
Thinking about:
- more ZY-T08 pills? Anybody interested?
- regular noctigon and tpad pcbs in stock?
- more Cute-3 optics in stock? Could be available with mass interest only.
- more specific (rare) optics in stock?
- tir+pcb decision for SRK clones? Could be available with mass interest only.
illuminated tailcap decision (pcb with soldered leds) X6 style tail? Could be available with mass (very mass) interest only.
Also, thinking about offering small pieces of bare Al/Cu rod for cheap price.
Waiting suggests about new mechanical parts.
Hi. I made my first order here a while ago. Shipping was quick and took maybe six working days.
The items were well protected, some of the best packaging I’ve seen for a small parcel. http://i.imgur.com/3AII11X.jpg http://i.imgur.com/yN5Y5dk.jpg
Sadly I will have to wait much longer for my other parts to arrive from China and Hong Kong, so I can’t comment on how they work right now, but I’ll make sure to do an update later.
Thanks to Kiriba-ru for providing this service for people who do not wish to order from USA.
I saw your problem with PayPal, did you find any alternative or solution yet? While I don’t know much about AliPay, it does seem like a very similar alternative and I would expect many here to already use that service.
