I think a cheap and good reflector from china will be very hard to find...
The smaller you go, the more accurate it needs to be if you want a good beam.
I highly suggest you install optical ray tracer to test that the reflector properly focuses light, since usually the only information given is the depth and diameter of the reflector. http://arachnoid.com/OpticalRayTracer/
Also, a big problem with getting stuff from china is that even though it is low price they usually have a minimum order quantity and you can't get something unless you buy a set of 50 or whatever.
But search around, test the mirrors with the ray tracer and see if you can find a decent one at a good price.
Might I suggest having a play at this site :student:
For cooling how about miniature heat-pipes, think of an upside down Mercedes symbol, you could use three or four in line for one support and use two of these for the top two supports, with the third (bottom) support just being 1mm flat copper.
Just throwing it to see if it sticks
Cheers David
Edit, forget the three or four miniature pipes (expensive) however they do 2.5mmx8mm for laptops fairly cheap.
Even if you guys could find a suitable host and reflector, won’t the placement of the led with big limitations on heat transfer limit the Amps the led will be able to endure?
And thus limit the beam intensity - throw of the light?
If a light like this can use 100% instead of roughly 75% ot the light for the spot, but the led can be driven at 75% of maximum, where’s the benefit? (other then beam characteristics).
The heat transfer will indeed be the big limiting factor, so just one arm would probably not suffice. Maybe the “Mercedes” star design would be best?
Interesting idea, bu waiting to see whether it can be turned into a practical design.
I think some of you underestimate the thermal conductivity of a copper boom.
But we could opt for a bar across the reflector, so it goes both directions to the head.
A ‘mercedes star’ will definitely look nicer but is much more complicated to construct from one piece.
I think i will change the drawing to have a copper bar in stead of a boom, doubling the thermal conductivity.
But you should also consider that an XP-L can run 3 Amperes on a ‘normal’ aluminum MCPCB, which is absolutely not ideal.
It will only need one pipe to handle a 50w light as roughly half is converted to light and half generated as heat, a 8mm x 2.5mm pipe will handle that with room to spare, however I would suggest two for rigidity and also the cooler a led is the more efficient it is.
Have a read of this pdf from Digi-Key.
Still that much?
If an XP-L HI is used at 6A @ 3,9 V, would that not mean a total energy of 23,4 Watts of which the majority is transformed into light?
Please correct me if I’m wrong, these kinda calculations are not my strong suit.
So maybe one small copper bar with one small heat pipe inside?
The reflector that I’m checking out atm is a cheap plastic reflector used in those optical illusion discs, like this one: http://www.ebay.com/itm/Toysmith-3-D-Mirascope-6-Inch-/162165285686?hash=item25c1cde336:g:5XQAAOSw9NdXq7Kw The focal length of this reflecor, as EasyB noted, is short, just as needed for this kind of set-up, just a bit above the edge of the reflector. I have a 6 inch version that I’m trying out, but there is a 9 inch version that should work better and have better throw. But here in The Netherlands I can not buy one for cheap, in the States they are plenty available. I think that optically the reflectors in these toys are not bad (or they would not work for the optical illusion) but I suspect that the surface does not reflect optimally, there’s more light loss there than is desirable.
In a test set-up with a XP-G2 S3 3d dedomed and direct drive (I used a 14500 zoomie flashlight without lens, so as a mule), and blocking the outer edge of the beam so that a 90mm diameter section of the reflector is used, I get 310kcd. But it is running from an Efest 14500 and the flashlight and clamp are blocking quite some light, in a better build I expect over 400kcd from this. Considering that 90mm of the reflector is used, there is room for improvement, probably with a better reflector, but it is fun anyway to see the principle working so well.
heat pipes by themselves can not handle anything, they only move heat, not dissipate it.
there is always a heatsink and fan on the other side of heatpipes, also heatpipes work well only when hot end is lower than cold end, with something stationary like a computer, you can have radiator\heatsource mounted with height difference, but a flashlight that is not stationary it is not the best solution at all.
I think a heatpipe is probably a good solution for getting heat away from the LED. Even if it is not oriented optimally, it’s probably a lot better than a solid piece of Cu of the same size. I could be wrong about that, but heatpipes in laptops, for example, are not oriented vertically.
I think everyone is aware that the heatpipe is just a way to transfer heat and not dissipate it. Of course it would be connected to a heatsink.
I’m going to make my test light without active cooling: the XP-G2 will be producing about 14W of heat, let’s see if I can get that guided away fast enough, I think I can
To make this a bit more quantitative:
The thermal resistance of a piece of material with cross sectional area A, length x, and thermal conductivity k, is
R=x/(A*k)
So for a copper bar 0.5cm x 1cm and 7cm long, with k=385 W/m*K, the thermal resistance is 3.6 K/W. This is quite high when compared to other flashlight shapes/designs. For example, I did some thermal testing of a couple flashlights and found their thermal resistances (from MCPCB shelf to outside of flashlight head) were almost 10x less. Whether it’s too high depends on the power of the LED and the size of the heatsink and how hot we allow the heatsink to get.
