What did you mod today?
So, what meter did you purchase? I’ve got a tab up with an HS1010A from Banggood in my cart.
I ordered that same one from Banggood, but it showed backordered. So I cancelled it and ordered the same one from a US seller on eBay
I have that one too. Works fine. No problem.
So what about your L2, PD? Did charging up the battery help? I think you should see at least 150 kcd, even 200+ kcd is possible with high binned XP-L HI.
The XP-L HI in that L2 isn’t that hard to focus properly. I’ve done it three times. The first time I raised the emitter by soldering a copper disc underneath the MCPCB, but for the last two I went without that, but achieved the same well focused result.
For a L2 with dedomed XP-G2 I had to raise the emitter as well, that one was much more a PITA to focus as the XP-L HI.
I have another L2 that I wanted to build up for a friend (XP-G2 dedomed + FET-Driver), but ran out of FET drivers, so I put a sliced XP-E2 @2,1A in there, just for fun. Now that is a pencil beam. Since it was just for fun and won’t stay like that, I didn’t fiddle around with focus too much, probably should though, to see what it’s good for…
So now, I have three L2’s, one with XP-L HI, one with dedomed XP-G2, one with the sliced XP-E2. However, I’ll keep just one, still have to decide which. Would have posted beamshots that compare the three, but have only two working tail-caps right now, since one is in the progress of beeing converted to a reverse clicky. Not as easy as it sounds! I really dislike the stock forward switches, fried three out of five during the usual bypass operation.
The cell in the L2 was a lot lower than I thought: 3.6v. I didn’t have time to let it charge last night so I’ll test it again tonight. I’ve been considering moving to dedomed XP-G2 in it, after these readings I might give it a shot.
I thought for sure my Courui would be above 300kcd, and I know the cells are for sure over 4v in that one. The focus being bad is the only thing I can think of.
That’s what I was worried with getting a meter, that it would make me unhappy with lights I previously enjoyed. For that reason I don’t think I’ll make a sphere or pipe. I mainly wanted the meter to measure before/after for the upcoming TM16 mod.
Haha, expect no wonders with the cell at 3.6V. I think with a good charged one you’ll have a reading that is much more towards 200kcd…
Pd before changing something , measure the amperage draw . If it draws enough amps , then it’s a focus issue :wink:
Well I still can’t decide what I like better in an L2, the dedomed XP-G2 with more lux or the XP-L HI with more lumen and better tint. I’d say the XP-L HI is more practical in use. The sliced XP-E2 is funny and maybe cool to have that kind of reach @ 2,1A, but not practical at all. One day I had a fox lit up maybe 200-300 ft away, I had to hold that light soooo steady just to keep him inside the beam… Dedomed XP-G2 is somewhere in between, but compared to the sliced XP-E2, even the dedomed XP-G2 is so much more practical.
I hear you on the measuring stuff, PD. I don’t like to measure the heck out of my lights, I simply like em or I don’t, don’t care much about numbers.
D01 with xp-g2 should be well over 300kcd. I measured mine at 305kcd and it is running dedomed xml2 u2 driven at ~5A.
I recently ordered Noctigon XP32 boards, would love to see what numbers will D01 give me with dedomed xp-g2, if i find a good one.
What do you guys think of the TM16 numbers? Do you think I need to adjust all of my numbers up, or is the TM16 just under-performing?
Pretty close to what I got. 111kcd. The TM16 utilizes direct drive for turbo so it’s heavily dependent on cells.
It might have been over 120 before the limiting voltage thing.
I thought they would be using a fancier driver I guess. I’ll charge them up and try it again too. I need more chargers apparently
Using original (stock) reflector ?
Yes, stock reflector but i might be wrong about the current because it is direct driven, no driver at all, so it might be higher. At the time of the test i had three 25R’’s in it, ive seen that same led pull just over 5A from a single cell, so with 3 in parallel there might be a bit more juice delivered to the led.
My TM16 is making 109.75Kcd, essentially stock… I didn’t change anything on the driver, still has the NW (on the warm side of NW) emitters, but I used 18ga Turnigy leads throughout, in place of the 20ga they used.
So I’d say you’re in the ballpark.
I’m using fresh charged LG HE-2 Button Tops.
Direct Drive for Turbo? Where does that info come from? I see an R010 sense resistor on the driver… mine tests out at a bit over 4100 lumens.
As djozz explained me :
Yeah, tested it, three 25R’s @ 4.19V = 5.7A at the tail, so there it is, it is more than 5A.
Probably misremembered DD.
Max did a really nice write up on the TM16.
With the lumens Nitecore quotes (4000), Turbo is probably like 2.8amps per emitter. It still could be susceptible to a tenth of a volt or two.
My only remaining Courui D01 also uses 25R’s, it’s making 545Kcd with an XP-L HI for 1476.48M throw.
Not liking myself for selling the SBT-70 D01.
(gotta see if I can tweak it for that remaining 436 feet to make a mile. :smiley: LG HE-4’s will probably do it. :wink: )
Edit: Best is actually from Efest 35A’s in this light, at 557.5Kcd for 1493.32M. Still some 381 feet shy of that elusive mile. Oh well.
