“recoil” is the wrong name for such a design. There must be a more accurate name for this design where similar ones are used in different optical instruments, but mainly for gathering light. Some incan lights of various types used this design. In optics some designs use a double reflection to make a super pin-point exit pupil, but not sure that can be utilized exactly the same for a exciter rather than collector. Interesting to experiment with different optical designs like this.
How is it the wrong name? That's what it was named by the first people who made it...
It’s not accurate that’s all I’m saying. It does not align with the definition of the word recoil. Some marketing people came up with a name for some light, but optical designs tend to have accurate names that reflect the engineering and/or science that they encompass. Not important for many people I understand.
if you use a laser you have to make the spot on the LED target bigger than the laser can be focused
The focal point of the laser needs to be a cm or so above the LED so the spot gets bigger when hitting the LED
I am pretty sure that a XP-G2 can handle 4.5W laser light if you make the spot as big as the emitter is
I would guess as there is less absorbtion than light with blue light fom the LED from behind, so you need a warm white LED to get a decent tint
this guy extracts laser diodes from projectors
Laser/LED projector
My blue laser is this one from Banggood, bought it for no valid reason at all, and I’m pretty scared switching it on, even with green glasses that absorb almost all of it. It is actually even 2.5W.
Still not sure about doing the experiment
Bah, it's 2.5 chinese watts, so probably more like 1-2W :P
Just shine it at some old LED you don't care about burning and see if it makes more, similar, or less light than the LED driven regularly.
This isn't going to damage your eyesight as long as you don't shine the laser onto your eye or on a reflective piece of metal, I wouldn't be that worried.
EDIT- actually I did more research and found this: http://jss.ecsdl.org/content/5/10/R172.full#ref-15
4000lm+ with a single crystal phosphor, which doesn't get damaged by laser light, can withstand up to 300 degrees C, and has a high thermal conductivity for cooling.
Problem is that the laser needs to be over 14W to get that much output.
This definitely seems like a possibility for a flashlight, I will keep looking and maybe buy a YAG:Ce crystal if I can find one, and then maybe a high power laser.
I think 4000lm+ in a few mm size would be decent intensity for a spotlight, I can definitely see this replacing short arc lamps in the future :)
Anyway, enough derailing the thread, let's see what OP can do with a regular LED and that mirascope reflector :D
There are 4.5W diodes availiable
Its probably driven by multiple 2W laser diodes
Wow! 4000lm from 14 Watts power is better then any LED ?!
(edit) Ah, that’s 14 Watts laser light output power…
I needed to repair friends Ultrafire UF-007 recently(burned emitter swap) and I can say that even swapping old burned XRE EZ1000 to new XRE (old and unused) was a pain. And as you know XRE has nice bottom ± contacts so It can be handled easier than most emitters. Modding with XP-G2 or similar will require more thinking and tinkering (so to reflow to miniature pcb and epoxy it or reflow same configuration to minature brass shim or even direct reflow of bare emitter to miniature brass shim)
My opinion about estimated performance even before you finish it in comparison with 50mm aspheric:
UF-007 is 25kcd light if you manage to get 1.8A to stock XRE.
Good 50 mm aspheric with same XRE emitter will roughly have 70kcd at same drive current.
Modding: Swapp old XRE with de domed XP G2 de domed and better components in 50 mm aspheric and you are roughly at 220kcd which is around 200% kcd performance increase over old XRE so it is right to estimate that with same modding of UF-007 light you’ll also get 200% increase and that means that even modded UF-007 will not pass 100 kcd.
More likely around 80kcd.
It will be nice experiment… Good luck :+1:
Yeah, it’s soldered to the tiny copper core of the centre piece of the boom. I used a tiny butane torch to heat it up and pulled the XR-E off by the wires.
Does it need a shim for the correct focal distance?
I took my UF-008 (same set up as 007) apart, removed the XR-E and will (try to) give it a new slim copper boom and planning to use a de-domed XP-E2, run it on 5x 7135 if possible (heat dissipation).
I expect it to be comparable with a 35mm aspheric lens.
It will have a tighter beam than one with an XP-G2.
For the 6” recoil light i’ll use a XP-L HI initially.
I’m thinking about a way to make it zoomable by moving the LED towards the reflector, but this will obviously complicate things…
Dang, i just measured the UF 007 (or 008) and it approximately reflects about 90° of the light, which is more than i expected.
With the mirascope reflector the light will only reflect an additional 30° (120°) which is only 33% more…
That’s not so über i.m.o…
Maybe use a tiny primary lens…
Using extra optics will not increase the throw, even decrease it a bit. It may increase the output and hotspot size.
Yeah, i know, but since it’s such a big reflector, maybe a good compromise can be achieved with a little bit of pre-collimation…
I would think so. If I ever try this, I want to use liquid cooling to help get heat out of that pillar.
“Does it need a shim for the correct focal distance?”
Well I think that maybe it is not necessary… How? Once you put those tiny copper bolt out and re-flow emitter directly to it
(this will be tricky and pain since you’ll need to trim those tiny bolt before pre-tining and soldering directly to bare led).
If properly done you can manually adjust height to desired level (probably around 0,7mm higher from copper bolt base) and mark an outline on that copper(brass) piece when you find correct distance.
After that put it back in a empty bolt hole glued with thermal glue like artic alumina.
About long tiny wires… Anything larger than 24 awg will be to much and you could braid it and epoxy once when done.
Choice of XP-E2? Well I am not sure… That will be to tiny but good thing is maximum performance at very low current draw. I think it reaches full performance around 2.2 but Djozz knows that better.
I’m considering it too actually.
Just hope 2 heat pipes will be enough, otherwise you need a waterpump too…
We’ll see.
Wow! 4000lm from 14 Watts power is better then any LED ?! (edit) Ah, that’s 14 Watts laser light output power…
Haha yeah, lasers that powerful are like $500 USD, even I can't afford that just for a potential experiment.
Maybe if I can find someone at my university with one...
Dang, i just measured the UF 007 (or 008) and it approximately reflects about 90° of the light, which is more than i expected. With the mirascope reflector the light will only reflect an additional 30° (120°) which is only 33% more… That’s not so über i.m.o… Maybe use a tiny primary lens…
Yes but the reflector is very small, which means the LED is a short distance from the reflector.
The closer the LED is to the reflector, the more beam divergence you will get due to the LED size.
If you made that reflector twice the size, the focal length would double, the LED would be twice as far away from the lens, and the beam divergence would be reduced even more.
This would be a similar effect as using an LED that is half as large (die area)
So yeah, the mirascope reflector should still be a huge improvement. :)
If you’re going to use heat pipes I’d suggest using a perpendicular head (think zebralight) for ease of manufacture. The laser design seems very effective but kinda dumb. Who wants to put on protective glasses every time he wants to use a flashlight? High power lasers can cause permanent severe damage to eyesight in a fraction of a second. To me that’s a big “Fuck No” as far as using them when not absolutely necessary goes.
The laser idea was just a concept for future stuff I might do, OP isn't actually going to do that for this light.
The point of laser+phosphor crystal is to get something similar to a HID searchlight but without needing several-kilovolt power supplies and thousands of watts of power.
HID lamps are also dangerous because they emit UV, can explode, contain toxic gases, require thousands of volts to run, etc... but people still use them because it is the only way of getting light powerful enough to reach many kilometres.
There will always be some risk when dealing with lights like this, which people are willing to take to make the brightest light possible, or in this case use a new technology such as laser+crystal.
This is not meant to be a typical flashlight that you just use to light up a path or anything like that. It isn't even called a flashlight at this point.
I need a 6 inch alu tube section, maybe a 19” alu strip bent around in a circle.
On it i will have to somehow fix the heat pipes which will be the boom that holds the LED.
Is that what you meant?
I thought it was a very nice idea actually, but unaffordable and as you say:
Who wants to put on protective glasses every time he wants to use a flashlight? High power lasers can cause permanent severe damage to eyesight in a fraction of a second. To me that’s a big “Fu*n*k No” as far as using them when not absolutely necessary goes.
It’s not gonna be a laser exited phosphor.
