Funny, cause your BLF ID was on my box, so I figured they screwed it up and sent me the wrong one, but it turned out it was mine with the engraved "Tom E"...
I tried some protected 35Es that are very long on the MT03. The tailcap doesnāt screw all the way in but the light works just fine as thereās no electrical path on the body.
You need semi raised cells. Its touchy its the plastic protector around the tabs its either to raised or to hard and will not flex enough with pressure. But button tops are to big but they will still work fine. My HG2s work fine. You can always bend the ends out on the batteries? You could use magnets fine because the contacts dont spin the tail cap PCB stays still when you loosen and tighten the light but it may not fit still?
Personally I find that I use GAās more and more now days. Simply because if I do not have a light box nearby I canāt even tell the difference in performance with the naked eyes and the extra runtime is great.
4S and 2S2P option. My thoughts are what are you guys doing Haikelite? To whom are you trying to sell the 4S version, and to whom the 2S2P variant? Arenāt you guys going to get bombarded with questions what the difference between the two variants is? Or is this another change that you have implemented when realising that output is reduced with depleting battery charge? Seriously, from a business point of view this doesnāt make sense to meā¦
Iām finding burrs in the grooves. Threads could be better. With some minor improvements, this could be a great light. Start with a slightly longer battery tube, smoother threads, and either sharper tools or more deburring. You could sand blast more, but I think that will reduce thread quality. Maybe an acid dip?
I donāt care much about 2s or 4s, but that choice is probably going to cause lost sales. 4s is probably the better choice though.
Iād like to see a holster accessory. A kydex holster that puts the light in the head down position is my preference.
4S does true buck regulation, 2S2P doesn't. So 4S gives you amp regulation - this is what I was told at least, and I've seen other buck drivers behave like this as well.
I would expect 4S to have flat, constant output instead of slowly trailing off like Tom detailed in his 2S2P review. The trailing off deal might actually be preferable to some as youāll get longer run times and shouldnāt be able to see the slowly decreasing output unless you measure it.
I chose 2S2P because mostly think'n on upgrading to my own FET based driver. Dunno all the details but I don't mind voltage sag - longer runtimes, no sudden loss of output, no pulling high amps out of almost drained cells. Think all these things were said before...
Also they said protected cells are best with 4S, unprotected best with 2S2P. Hope protected cells can fit in the 4S light...
