BLF recoil über-thrower
384 posts / 0 new
Enderman
Enderman's picture
Last seen: 21 hours 45 min ago
Jerommel wrote:
Hey guys, Just got my mirascope in, and as a mirascope it's not impressive, at all... The mirror surface is a bit messy unfortunately.. But, a quick test with an XP-E2 light looks kind of hopeful none the less. This evening when dark outside i will see if it's worth working with or just a waste of time and money.
Another benefit of large reflectors is that imperfections/aberrations have less effect on the beam Wink
Like, look how ugly this is, yet it still throws several kilometres xD
Image result for gorilla giant searchlight candlepowerforums
Jerommel
Jerommel's picture
Meanwhile it got dark outside, so i can do some beamshots.
I placed a ‘screen’ in the garden, will be projecting out the window. Smile
2Q19
Enderman
Enderman's picture
Nice setup!
DavidEF
DavidEF's picture
Last seen: 11 hours 19 min ago
Oh, I am SO looking forward to this! Wink
- The YKK Philosophy
Jerommel
Jerommel's picture
Well, i’m eating now, i tried some stuff, and well, it works, but..
Beamshots will follow later…
2Q19
Texas_Ace
Texas_Ace's picture
Last seen: 11 hours 3 min ago
I have to admit, I didn’t think this idea would be taken to this level. Great to see people really putting the effort into something new!
Jerommel
Jerommel's picture
Okay, some beamshots then:
And compared with Jacob A6:
I should have used a tripod..
So with the same power it seems to throw more light in the right direction than an A60.
This was only 10 meters distance to the screen, so i’m still not sure what it will do over longer distances.
Quite a bunch of anomalies around the hotspot, which seem to come from the outer perimeter of the recoil reflector.
Will do some more pics later to investigate further.
2Q19
DavidEF
DavidEF's picture
What bin XR-E and XP-E are you using? I’m wondering how much of the difference is from the emitters themselves. Or, possibly, the difference in emitters could be working the other way, depending on bin, so the difference from the reflector set-up might even be more than shows in the pics!
Jerommel
Jerommel's picture
I have no idea what bin those LEDs are.
The XP-E is from a SingFire 348, so probably nothing special, The XR-E is how i bought the Jacob.
I was assuming it would be similar enough.
2Q19
Enderman
Enderman's picture
Sweet.
What's the diameter of the spot?
Is this focused to a point or focused to infinity (collimated)?
Jerommel
Jerommel's picture
Dang, camera battery empty…
I’m trying approx. 20 meters now, but either way, this thing does a nice job throwing in the good direction, but a better reflector would have been considerably better, i think..
2Q19
Jerommel
Jerommel's picture
Enderman wrote:
Sweet.
What’s the diameter of the spot?
The spot @ 10 meters is approximately 50 cm in diameter.
This is a compromise between collimation and focussing, it’s “the best it can do” so to speak.
2Q19
Enderman
Enderman's picture
Jerommel wrote:
The spot @ 10 meters is approximately 50 cm in diameter. This is a compromise between collimation and focussing, it's "the best it can do" so to speak.
That is a 1 degree half angle beam divergence, very good for a toy reflector! Smile
Do you have a luxmeter to measure?
Jerommel
Jerommel's picture
Enderman wrote:
Jerommel wrote:
The spot @ 10 meters is approximately 50 cm in diameter. This is a compromise between collimation and focussing, it’s “the best it can do” so to speak.
Hmm, when you put it like that, i guess it’s not too bad. :)
No i don’t have a lux meter (yet)
I thought i’d compare it with a known light: the Jacob A60.
The recoil setup seems to outthrow the Jacob hands down, which is not bad either.
2Q19
Jerommel
Jerommel's picture
By the way, the XP-E is soldered on a 1.8 mm diameter copper wire, and it seems to be enough for about 1 watt.
Cools better than i expected.
2Q19
Enderman
Enderman's picture
Jerommel wrote:
Hmm, when you put it like that, i guess it's not too bad. Smile
No i don't have a lux meter (yet) I thought i'd compare it with a known light: the Jacob A60. The recoil setup seems to outthrow the Jacob hands down, which is not bad either.
Hmm that's alright I guess. Maybe look into buying one in the future if you're into flashlights a lot, I got one for $50 a while ago and it has been extremely useful.
For myself, I also contacted a company that makes real reflectors, and it's like $700-1000 for a nice 16 or 20" reflector xD a bit pricey!
pilotdog68
pilotdog68's picture
Last seen: 3 weeks 5 days ago
Jerommel, maybe I missed it somewhere, what is the diameter of that reflector you tested? Looks pretty big.
Theodore41
Last seen: 14 hours 58 min ago
djozz wrote:
My blue laser is this one from Banggood, bought it for no valid reason at all, and I’m pretty scared switching it on, even with green glasses that absorb almost all of it. It is actually even 2.5W.
Still not sure about doing the experiment Sad
http://www.banggood.com/445nm-2_5W-2500mW-Blue-Laser-Module-With-Heatsin...
Having a 445nm blue laser,I use these protecting goggles,which are red. http://www.banggood.com/405nm-445nm-532nm-Anti-Blue-Viole-Light-Laser-Go....
djozz
djozz's picture
Last seen: 3 hours 16 min ago
The green glasses reduce the power to about laserpointer power so I can still see the beam. I will still be careful with the glasses on.
Jerommel
Jerommel's picture
About 14 cm / 5½ inch parabole.
2Q19
Jerommel
Jerommel's picture
Enderman wrote:
Jerommel wrote:
Hmm, when you put it like that, i guess it’s not too bad. Smile
No i don’t have a lux meter (yet) I thought i’d compare it with a known light: the Jacob A60. The recoil setup seems to outthrow the Jacob hands down, which is not bad either.
Hmm that’s alright I guess. Maybe look into buying one in the future if you’re into flashlights a lot, I got one for $50 a while ago and it has been extremely useful.
For myself, I also contacted a company that makes real reflectors, and it’s like $700-1000 for a nice 16 or 20” reflector xD a bit pricey!
I would still very much like to find an approx. 5 inch one that can capture 135°, although 120° would make me happy too. Smile
2Q19
pilotdog68
So not exactly a same-same comparison to the A60 lol
Sounds like you need to make a custom build for next year’s competition!
Enderman
Enderman's picture
Jerommel wrote:
I would still very much like to find an approx. 5 inch one that can capture 135°, although 120° would make me happy too. :)
Currently it does more than 135, does it not?
You can always trim away like 1/2" off the edge of the reflector...
I haven't modeled the 6" mirascope reflector, so idk how much it actually is capturing.
Jerommel
Jerommel's picture
Indeed not..
But it’s a similar LED die and and both run 180 mA (low mode on A60 and with variable resistor 3x AA NiMH for the recoil)
Planning to join next year’s competition for sure, but probably not with this reflector..
2Q19
Jerommel
Jerommel's picture
Yeah, you’re right.
I thought it was like 120° but it’s actually 140°
This may explain why it does considerably better (lumen / wise) than the A60.
When my camera battery is full i’ll do some shots from the screen towards the LED, hopefully it will show how much of it is actually doing the good work.
It seems the outer perimeter of the reflector is a little ambiguous though.
2Q19
Enderman
Enderman's picture
Jerommel wrote:
Yeah, you're right. I thought it was like 120° but it's actually 140° This may explain why it does considerably better (lumen / wise) than the A60. When my camera battery is full i'll do some shots from the screen towards the LED, hopefully it will show how much of it is actually doing the good work. It seems the outer perimeter of the reflector is a little ambiguous though.
Ok cool. Also, what's this competition people are talking about?
Jerommel wrote:
\Planning to join next year's competition for sure, but probably not with this reflector..
DavidEF
DavidEF's picture
Enderman wrote:
Jerommel wrote:
Yeah, you’re right. I thought it was like 120° but it’s actually 140° This may explain why it does considerably better (lumen / wise) than the A60. When my camera battery is full i’ll do some shots from the screen towards the LED, hopefully it will show how much of it is actually doing the good work. It seems the outer perimeter of the reflector is a little ambiguous though.
Ok cool. Also, what’s this competition people are talking about?
Jerommel wrote:
\Planning to join next year’s competition for sure, but probably not with this reflector..
The contest everyone is talking about is the Annual Scratch-built Flashlight Contest which has recently closed for this year, and winners haven’t even been announced yet.
Jerommel
Jerommel's picture
I made some nice and grainy shots facing the light from about 20 meters away, light on extremely low power of course:
Left is taken from left, middle from the middle and right from the right of the hotspot.
I conclude the outer perimeter of the parabola reflects too much inward, the ring section inside that is okay, inside that one seems to reflect a little too much outward, the middle is okay.
(The most outward perimeter is not parabolic but flat so that does nothing at all.)
2Q19
Enderman
Enderman's picture
Jerommel wrote:
I made some nice and grainy shots facing the light from about 20 meters away, light on extremely low power of course Left is taken from left, middle from the middle and right from the right of the hotspot. I conclude the outer perimeter of the parabola reflects too much inward, the ring section inside that is okay, inside that one seems to reflect a little too much outward, the middle is okay. (The most outward perimeter is not parabolic but flat so that does nothing at all.)
Yeah looks like a bad parabola, that's unfortunate. You're getting the same effect that djozz got with the outer part of the parabola focusing inwards.
It should still work alright for a handheld flashlight, but probably won't get 1M lux :/
Jerommel
Jerommel's picture
Enderman wrote:
Yeah looks like a bad parabola, that’s unfortunate.
Yeah, that sucks a little…
[quote wrote:
You’re getting the same effect that djozz got with the outer part of the parabola focusing inwards.
..and then a ring that’s okay, and than a ring that reflects outward, and then another change in angle…
Considering glueing rings on the back pushing and pulling it in shape, but…
Quote:
It should still work alright for a handheld flashlight, but probably won’t get 1M lux :/
Not sure it’s worthwhile to continue with it.
As a mirascope it’s not much good either..
2Q19
