I don’t believe this for a minute. No remotely responsible manufacturer charges Li-Ion cells in series without charge balancing. You’re to need to be much more specific about these packs. Laptops most certainly use charge balancing and cell monitoring. Electric and hybrid cars use charge balancing and cell monitoring. The RC folks use charge balancing. Please cite specific examples of all these packs without charge balancing.
Drill battery packs didn’t use balance charging for the many years. This is why the drill battery packs were so unreliable for so many years.
Although I did overestimate the number that didn’t have balance charging. After awhile you stop taking notice of things like that and just get into a routine, grab the pack, twist it till it breaks, pull out the cells, take voltage readings, dispose or clean up and keep the cells. Repeat for the next 6 hours.
After awhile you tend to not notice anything except that your fingers hurt real bad and you should really address those cuts. lol
I have pulled apart quite a few packs that only had electrical connections at the end of the series of cells and nothing in the middle.
Well, cordless tools have generally used NiCD or some cases NiMH packs. Li-Ion packs weren’t on tools 20 years ago. Further, many tools that do have Li-Ion packs more recently have used high current safe chemistry sells like the A123 variety which may not need charge balancing.
I have never seen a drill with A123 cells, heard about them but never seen them. The drill manufactures swapped to Lithium but used the same battery setup as nicd for a long time (aka, no balance charging).
I never said these packs were 20 years old, I said I have opened laptop packs that are that old and didn’t have balancing. I used to care when I first started pulling them apart and noted things.
I also have home made battery packs that have a lot of use without balancing with very little divergence.
The end point is none of this matters for flashlights, they are not charged in series anyways. I was simply stating that the balance issue is not as bad as some make it out to be from my experiance.
I’m learning a lot here. Thanks TA and Stereodude. Just a detail to add here: I do believe charging in series does happen with flashlights. For example Lumintop SD75 (2S2P), and Nitecore MH41 (2S). I have been wondering for a long time whether unbalanced charging of lithium ion occurs with products such as portable vacuum cleaners etc…
Yes, in some lights they charge in series but lets just say that people that use internal charging doesn’t really care about the cells anyways. I have yet to see an internal charging system I truly trust or feel like waiting on.
I feel the same; however, this is actually the weird part. No doubt you’ve seen plenty of videos where people put different cells in their Skyray King or something; it happens all the time.
So you have unbalanced charging in certain lights, and it is exactly the not so careful people that put different cells in these lights for use and charging without ever taking the batteries out again. And apparently things don’t go sour… Certainly not recommendable, but this is perhaps your view how the dangers of lithium ion are exaggerated? Meaning if you have a set of quality cells from the same batch, it is pretty much impossible that things go wrong in 4S configuration.
Yes, that was exactly my point. Even when abused the cells themselves are actually quite safe now days.
I have even tried shorting them out on purposes (as was documented in the Q8 thread) and there was another thread where a member tried to get them to explode and it was surprisingly hard to do that.
The dangers of brand name 18650 cells is really not all that bad. Don’t short them out, keep them at reasonable temps and keep the voltage between ~2.75 and 4.2V and they will work fine.
HaikeLite, could you please explain very briefly the positives of the different battery configurations you use in this lite?
I mean 4s vs 2S2P. Probably I missed this lesson…
My 4S MT07 and MT03 samples are supposed to be shipped out this week via DHL. Based on past experiences with DHL they should arrive before the 27th. I should have enough time to get beamshots of the MT07 vs MT03, as well as Turbo and high run times before the end of the GB.
My set of flattop GA cells is going to be here in time so it just comes down to the shipping.
Outdoor beamshots are now posted see bottom of the OP in the review here: https://budgetlightforum.com/t/-/42543, hoping they came out better, but I'll probably be giving it another go the end of this week if the weather cooperates.
I did, however, apply a resistor mod last night (added an R075). Mode outputs on frssh charged set of SANYO GA's are now:
low-low: 56 lumens
low: 610 lumens
mid: 1,570 lumens
hi: 2,530 lumens
turbo: 5,300 lumens @30 secs
Forgot to measure moon, but it's still very low...
LOL! I showed that pic to my girl, and she nearly passed the fuck out! Figured I’d show her that there are guys who have the addiction WAY worse than I do, so she should stop her complaining!
