[SALE] High CRI 90+ Nichias (ENDED)
No , i meant SM403 vs SM405 , then found the answer in the OP about steps McAdams .
Hey Clemence and TA, put me down for 4 219c 3000K emitters. Thanks guys!
Done.
djozz: 2x NV4L144AM (144A 6V) 4500K, Ra9050 and 4 of each 219C, so 4x 3000 K, 4x 3500 K and 4x 4000 K, thanks.
edit: throw in two of your MCPCBs too for the 144s.
Hey are you only getting 5 of each, or is that just all the list space you started with? I don’t actually need 4 of them and I’d hate for others to miss out just cause I got here first.
LOL, don’t worry. There are PLENTY to go around. Please buy all you want!
I simply started out with 5 and copy/pasted them to each list.
Good, that’s kinda what I thought but I didn’t want to be the greedy joker that bought all the emitters either. Glad to know I can have my four without guilt :slight_smile:
Thanks again.
hey djozz, please put me down for
10x 219C 90cri 4000k
thanks clemence and djozz!
Djozz :
4 × 219C 90cri 4000k
So dumb confirming question:
The “– NV4L144AM (144A 6V) 4500K, Ra9050, E900 flux, sm453 (3 steps McAdams, tightest bin available)
NV4L144AM Data sheet (link is external) This 4500K 9050 will be available in mid December 2016 due to raw material shortage – Nichia Rep” Emitters are much like XHP50 emitters in that they are both big and need 6v, sort of an XHP50 without the cross and a high CRI. Am I close?
Can I get 5 each if the 3000K and 3500K 219C?
Is the 4000K the same bin as offered by Rey? I have a bunch coming from him.
@Djozz :
Please put me down for 4 × 219C 90cri 4000K sm403
Djozz:
5x 219C 90cri 4000k
The one from Rey is sm405 (afaik), here you get sm403.
They are close, djozz has a test posted of them. It does still have a cross but not as noticeable. It is a good high output high CRI LED but it won’t match the XHP50 in raw power like most Nichia LED’s.
What about 144A LEDs with 4000K? I thought those were also ordered? :slight_smile:
Sorry, I ran out of money to get more than 300pcs of 144A - they’re expensive
Based on Maukka’s test the 5700K (5steps) resulted in lower 5000ish. I assume with 3 steps, we’ll end up the 4500K close to 4200ish. The demand of 5700K and 4500K also higher.
Cheers,
Clemence
I just got an update on the available quantities as od this evening.
These will be first come, first served.
If you want some super nice high CRI LED’s this is your chance. I doubt you will see more 3 step binned 219c’s for sale for quite a long time if ever.
Finaly I appreciate their “PDOT” reflector. Used to be just one of many Nitecore marketing abbreviations for me
Hi Clemence…can you put me down for 10 × 219C 90cri 4000K sm403 please…. :smiley:
