Sure would like to know if it's a U21 clone or made in the same factory - suspect it's from the same factory - dims and outputs are exactly the same specs I believe, and even the finish looks the same. The driver in the U21 is suspect - I know of 2 that failed (mine and one other BLFer). Hopefully it's been improved.
It's a quality light though - great compact thrower, though I prefer it cranked up in amps with a dedomed XPL - I've gotten up to 1,770 lumens and 253 kcd w/Narsil, and 5.93A at the tail (clamp meter) on a dedomed XPL W2.
As the light in the other thread is VERY reminiscent of the Manker E11 at about half the retail price (on the group buy). Utorch UT01
If these are even close to the quality of the counterparts, I’m VERY tempted. Especially since I JUST spent $65 on the Manker U21….I might still be in my return period with Amazon……hmmmmm.
EDIT: That being said, put me down for ONE NW. Thank you.
Manker perhaps you need to speak with your factory to find out why these look almost identical to your model.
It seems there is not much that can be done in the Chinese market about the issue of clones, other than to make the original worth the premium over the clone.
Here at BLF, some people will avoid a clone out of principle, but many people will buy what appears to be the best value.
