Well, as long as weāre speculatingā¦
Iāll go with what a previous poster posited: They probably are using a tube for this, not a solid bar, and the hole in the shelf is most likely the original tube ID.
Not sure if it shows well in a pic I took, but the hole gives full access to the 3 holes in the MCPCB - just wide enough, no more, no less. Maybe this one:
If we do want to make a point to them the reflector has to be changed to be secured down by 1 or 2 screws, then this could all change.
Its amazng. Put me in the list!
How is the reflector kept in place now? I would very much like to see it screwed down throw the shelf so that is clamps the MCPCB in the middle and really presses it down to give a good heat path.
Ahhh, well, it's the usual o-ring, glass, bezel compression thing to hold the reflector down - far from ideal, and must say a real PITA to re-assemble because the stupid o-ring is too small, and got to try like 10-20 times to get the glass down to force the o-ring to sit outside the reflector - yes, it doesn't sit on the top edge, and dunno if that's good or not. I gotta find a better way - this is driving me to drink, well, most things drive me to drink...
Perhaps we can convince (at least we can ask) Thorfire to use a u-shaped silicon ring around the lens, it is wonderful to work with those. In a distinct colour that has not been used by other manufacturers yet, yellow?
Please add me to the list for 1!
Wow two new members, welcome to BLF! Will update list later!
Honored you signed up for the Q8!
Argh yes we had such a nice idea, two screws holding th e reflector
Dutch: Haastige spoed is zelden goed
OE crudely translated āhaste is rarely goodā
Yep this needs addressing
It is almost funny, reflector, mounting and thickness of ledboard was not discussed and well not on oar now
Glad this is a proto not the end result.
Oh yeah amber or yellow as oring would be nice Djozz
While Iām for a black or clear o-ring that doesnāt draw attention, a yellow one would be cool to say āhey! Watch out! This is the business end!ā lol
Transparent/clear +1
GITD O-ring!!! :+1: :+1:
(Iām half serious about that)
People like to dis the GITD Orings but frankly while sure they are kinda silly, they also look neat when showing the light off to people.
Personally a flat gasket would be ideal instead of an o-ring. I donāt really care what color but white/clear is my first preference.
Count me in.
If there is still room I would like to join the list for 1. Thank-You.
Excellent! And welcome. Iām quite new and literally only joined to buy one of these. Now I have ~100 posts, and am on the list for the GT as well. :person_facepalming:
It certainly wonāt be my first hand warmer, however.
Just the first designed by the BLF crew - I.E. top notch.
Add me to the list, canāt hold on any longer
Really like the design
But the anodization looks cheap, hope it the final product will look more like the L6 or Eagle Eyes X6. Those have some seriously good anodization, better than most premium lights.
OP updated
I am in for an orging in the same color as the switch cover. Translucent,
GITD is nice but not a real issue IMHO
We were just emailing about the ano yesterday.
Of course HA3 sees ideal, but I really hope Tom manages to make a video of the tailcap being slowly baked a bit above a gasflame in his kitchen. This would give not only an indication of what ano the proto has, if it is type 2 we will see such beautiful transformation of colors going on I think lots of people set on HA3 will start thinking twice about that
Please add my name to the list. Thanks.
