[SALE] High CRI 90+ Nichias (ENDED)
Update 161123: Price brackets and free shipping calculation policy has been updated. It’s not affecting all existing order.
I have reflowed LEDs and it’s not gone bad yet, but I can get them reflowed already I don’t mind paying a little extra… I’m lazy :smiley:
Add two triples to my order.
I see, fair enough :slight_smile:
So now I’m not sure from your posts what the exact numbers of which leds reflowed on what board you request?
Got you added to the list!
4 x single 219C 90CRI 4000K on 16mm copper MCPCB
4 x single 219C 90CRI 4000K on 20mm copper MCPCB
2 x triple 219C 90CRI 4000K on copper MCPCB to be used on S3 hosts
That means: 4 + 4 + 3 + 3 = 14 pcs of LEDs, right?
@djozz, please put me down for:
  • 3 pcs 219C 9050 sm403
  • 2 pcs144A 9050 sm503
  • 2 pcs VirEnce 30mmx30mm CDTP board
Thanks!
Guys,
Can i still add this to my order?
2x 219C 4000K (2 pcs in total)
2x 219C 3500K (6 pcs in total)
2x 219C 3000K (6 pcs in total)
Thanks.
Yes, my fault, corrected the list!
Hey TA are you going to have any of those Virence boards for us US folks? Cause I’d like two of those as well, if its possible.
Happy Thanksgiving all!
Yes, they can be ordered with the GB as well. I will add that to your list.
Sub’d
hello, can these 5700k nichia leds be put in maybe a convoy s2+ ?
like for a triple ?
thanks.
The 144A you are talking about? It is a differnt footprint and would not fit in the triple. Finding a driver would be hard as well.
The 219C on the other hand would work just fine.
Problems:
- 144A doesn’t have thermal pad built in. And there’s very limited options available at the moment. You have to use custom MCPCB like VirEnce or Djozz board. The easiest way is to find board designed for 119A. Then you need to scrape off the solder mask to widen the pads. I haven’t seen 119A boards for triple too.
  • Triple 144A would require 18V - driver problem
144A is already 4 x 219C crammed together. You should get approximately the same output with quad 219C.
The most benefit of 144A over 219C is higher max output, simpler single optic source point, higher quality light above 4000K region. It has fatter (almost 40%) spectrum in 480nm region, the area most cool white LED lacking
Hi Djozz, can I get 7*4000k and 5*3500k 219cs and 1 4500k 144A on one of your boards if there are enough left please?
Thanks!
Thanks so could the Nichia 219c 3500k be ok for a Cu P60 Mule ?.
Any idea of the lumens ?.
Would I need it on a board too as someone I know would build it for me ?.
Better than the 219b?.
Thanks for your help!.
Texas Ace, my current order is 4x 219C 4000K.
Can you add 4x 219C 3000K to my order.
Please pm me your paypal and total so I can get the funds to you asap.
I assume paypal gift is preffered to avoid fees?
Shipping of my LEDs will be to DB Custom.
Thanks!
Texas_Ace, I’d like to order:
4*219C 3000K
4*219C 4000K
Thanks!
Djozz,
Sending PM as well… please PM total and paypal info for my order… thanks…
