Got my A01 today, it does indeed have PWM but I don’t see it being an issue for 99.95% of people, no idea what the tint is but it’s good as far as I’m concerned.
Well worth the $7.99 I paid.
oooh, looks like it will be back at $7.99 later today so think I will grab a couple more for Xmas gifts
Interesting. I have the original A01 version (bought earlier this year) with the 4000K tint, and I can’t detect any sign of PWM with my dSLR on any of its modes. I’m glad I bought these when I did. It’s too bad they redesigned this light. 4000K tint is perfect for me, and I don’t like PWM.
I had two A01’s arrive yesterday, after a month long trip from China (and oddly enough, postmarked Vanuatu!).
They are exactly as described in the original post. Drivers are clearly marked ‘Manker’, strobe is well hidden, tint is < / > 4,000 k, and I’m not noticing any PWM (although I’m not very PWM sensitive).
One seemed to have a slight intermittent contact issue, but cleaning the threads and the contact surface at the front of the tube solved that.
The front of the tube appears to be either polished smooth after the ano is applied, or else protected so the ano doesn’t stick to it - I noticed a whitish waxy film on that surface that seemed to be preventing solid contact. A brisk wipe with alcohol on a paper towel removed it at once, and the light immediately worked properly.
All in all, I’m very pleased. They work as well as any other twistie (and I have a quite a few from several premium makers) - and of course, the tint is superior. I won’t be modding these two; they’re excellent just the way they are.
I finally got around to ordering the copper Blf A01 and while the aluminium ones were reduced I added an orange one on for my other half to put on her keys. The copper one is noticeably nicer/better. The head on the orange one seems very loose and wobbly and as someone said above, the pill isn’t branded ‘’Manker’. Still, it’s no problem for the price and the head is nothing some ptfe tape can’t fix!
The copper one is great, smooth threads and picking up a nice patina
Just to vouch for the waterproofing on these. I gave one to my toddler to play with in the bath. It finally bit the dust last night after daily submersions for around a year maybe? Can’t knock that. I can reuse the lens in another lens-less one I have so all is good. Decent, robust little lights.
I concur, the sturdiness of these lights is impressive indeed.
I gave one to my wife for Christmas and she put it on her car keyring. A month later she dropped it in the snow. When the snow thawed (months later) we found it. Keyring all bent, probably run over by the car. The coloring of the light a bit scratched, but otherwise not dented at all and worked perfectly. Can’t beat that.
Off-topic, sorry, but stories like this always get me. I can’t imagine living in a place where you can lose your car keys right in your own driveway for months, because snow.
The summers in Sweden are very nice. Typically around 25 degrees Celsius (77 Fahrenheit) and long days (in the northernmost part of the country even midnight sun).
In the winters we do need our flashlights though, when daylight is short (in the northernmost part of the country the sun doesn’t rise at all for a month).
My wife and I were married at the Ice Hotel in northern Sweden in January 2011. Kiruna/Jukkasjarvi is the coldest place I’ve ever been to. It got down to minus 37 celsius. My eyelashes stuck together with ice……
Snow is usually better than grass, when it comes to not losing stuff. The only downside to snow is that (if it’s fresh) an item dropped into snow can fall through quite a distance. But at long as the surface hasn’t been disturbed, it’s usually pretty easy to see the hole, and find the item that way. In the woods, it can be tricky, because lots of stuff drops off trees to make little holes everywhere.
I’ve lost way more stuff in the lawn during summer, than I have in the snow during winter.
I don’t much like cold winters, but it does have the nice effect of killing off all insects and most other pests.
The downside to winter, when it comes to flashlights, is that most flashlight buttons are designed to be used with bare hands. Thick gloves make it almost impossible to turn on some flashlights, and removing them when it’s –20 or –30 is not something I like to do (especially if the flashlight metal is also –20).
Ridiculous…… I went to have a look at the lanyard on my dead A01 to transfer it to something else…. It was actually on in moonlight mode…. All modes work, no problem. It just needed a few days to dry out. Cockroach torch.
For me after EDC for years. build and LED is good.
Only complaint for this light are the rubber ring hardly in place that impact water seal and mode change.
Time to time need to adjust it back to it position.
Anyway i may not recommend to my friends anymore if new batch have more issues.
I’ve had a bright orange A01 for 6 months now and it’s performed flawlessly. I’d order more in a heartbeat if needed. I hang mine on my standard neck lanyard, run it on Eneloops (get some good run times out of them) and find it perfect for EDC use.
One modification I did which improved the light for my use was the addition of some clear PVC tube around the waist of the light. Cut to length, heated in boiling water and then slid on with some soap, it has shrunk into place and gives my teeth something soft to bite into when I want my hands free. It also really does help my fingers grip too the barrel too, and you can also slide the PVC down over the end to give yourself a much better tail-standing ability.
I’ll add that since I thought of the tube trick, I have modded my Olight i3S similarly. I do enjoy chip-free teeth . I suspect there are several lights out there that would like the PVC tube treatment
PS: before anyone asks, I can’t remember what size tube it is, sorry - easy enough in a store to try a few until you find one that is hard to get on - that’s the one you want as with some hot water and soap it will slide on easily.
