Yeah definately see wall shot first if it has ugly artifacts and rings
With intensity at 10,000 cd, its probably still not much of a thrower…
Pretty sure my Eagle Eye X5R has that candela… And is a similar size, and doesn’t have a fancy reflector.
Maybe the main point of this Fenix one is that you don’t HAVE to have the throw, but can use it for reading, walking paths, as a “candle with diffuser” where you don’t need much intensity of beam.
20% less throw than a LED Lenser P7.2 (320 lumen and 4xAAA). Please try harder Fenix!
My X5R is super dim, i think its defective because the output was very low in my DIY sphere and in my ceiling bounce test. A really nice light for the money if it would work correctly. Right now i meassure only 820 lumen in a ceiling bounce test and a bit lower in the sphere but as i said i think something is wrong with the light.
Anyway, i guess the Fenix FD30 is not declared as a thrower, as far as i have understand it you can select between flood and throw but the light wont produce a laser tight beam. It is likely that the “throw” mode has the candela values of a normal reflector flashlight in that size. I dont expect it to have more throw than a normal reflector flashlight in that size/diameter (X5R). The benefit of the zoom mechanism is probably the additional flood mode. So to me it looks like a normal tube shaped 1x18650 light with the possibility of an additional ultra flood mode. That would be fine for me.
My “hate” of zoomies is that tiny hotspot when zoomed- if I want a laser-like point I’d buy a laser. Something a bit wider would be great but I haven’t seen that happen yet.
Wallshots and beamshots somebody- please!
Phil
Yes, mine too… Zero spill is not nice.
And if its got a square hot-spot; Yuck.
I like the ability to widen or narrow the beam.
Cross fingers for a review from someone.
I highly doubt it has a laser tight beam or square hot spot, not from Fenix. It seems the light acts like a normal reflector light with an additional 76degree flood mode.
link
Looking good on the link :+1: but need more data- 2 pics ain’t enough and no wallshots to check out any artifacts or ringiness.
Phil
True, those are only manufacturer shots. Maybe i can show you beamshots next week but im sure someone will post pics in the next days anyway.
Then you just zoom out a little?
link
It’s always looking good in advertising photos. Real world is totally different.
Something like my old P7.If intensity matters.
Zero spill is quite usefull for rifle mounted bigger scopes like Zeis Victory or Mark 5, that spill will nuke your eye in a matter of 2-3 minutes tops
IN the matter of fact Sunwayman`s zoomie is one of the best arround
I like my Cometa…
I want some spill with most of my flashlight uses. Zooming back loses intensity so fast that the larger beam doesn’t help me with visibility. Some bright spill (corona?) near the hotspot or a larger focused beam might give me a reason to buy. Based on pics I’ve seen, the B158 is close to what I want so far but I don’t want to spend on any more shelf queens. I need to see the performance before I’ll buy.
Phil
honestly speaking this new Fenix zoomie is probably the most practical zoomie type flashlight, without giving up some lumens to the zoomie lens while projecting both smoother throw and flood beam option
Alright, anybody have one? whitewall shots?
I have the FD40 which maybe is just the 26650 version of this? I personally love it for a flood/throw combo light. It is not designed for tactical purposes but for me has several general purpose type uses as well as bike light. Yes, when zoomed in it has much more of a standard reflector type beam profile akin to something like TN12, P12, EC20 etc. albeit sloppier. The flood though is very nice imo.
Flood is not the big circle, but rather a flat wall of light which is just perfect and only limited possibly by its lack a few hundred more lumens. 900 or 1,000 lumens is still just that, and when spread out so very well, it might not be the brightest. It is for me though bright enough to use it full flood as a bike light and still see everything just fine for any type casual riding. If you’re a speed demon though, you may want to see a bit further up the road. I have to say that I personally like the FD40 but by far my biggest complaint is the UI. I don’t like press and hold for on/off. The worst thing is that when it is on and I forget to press and hold but single click only, it goes to lowest and I may not notice that I didn’t even turn it of so there goes the battery.
I’ll post some beam shots here soon. But with the FD30 and FD40, I’m not sure if it’s the same design for zoom. FD40 though is rather compact for a 26650 size which is definitely another plus.
FD40
From the pictures of the lights, the FD40 looks like it probably has an LED Lenser style TIR optic. That type of optic consists of a single-piece TIR but with a large pocket in the center. The LED sits on a post that can extend and retract into the optic.
FD30
In contrast, the FD30 appears to be a conventional aluminum reflector split into two sections. The cutaway also clearly shows a flat lens.
- In spot mode, the inner and outer section form one narrow, but very deep reflector. I would expect a fairly large spot and corona, with a small amount of spill. As it is still a very narrow light, I would expect little throw.
- In flood mode, the outer portion of the reflector retracts out of the way behind the innermost reflector section. The result is the light now has a tiny, relatively shallow reflector. I would expect a wide floody beam with generous spill and almost no throw.
The FD30 is the first light using this type of mechanism. I’d be very interested in seeing some white wall shots of it in action. I’m undecided whether to try one myself. I like pocket-sized EDC lights and at 140mm this light is far too long for pocket use. If I gutted it and replaced the innards (assuming I can actually open it… Fenix are usually heavily glued) I might be able to take off a couple cm. But even 120mm is still too long for me to EDC.
