So if you could get only one, would it be the MT07 or the L6?
I already paid for a MT03, and I can’t see getting a second one. But I’m not into throwers so much (says the guy with a X60vn). I’d get a Noctigon M43, but an M43 v2 is rumored to be out soon.
I havent check Tom’s review in detail but I believe L6 can be modded with resister for higher current + dedome led and smooth reflector can match the performance of MT07
Yeah it can be modded to match, but a lot of people don’t want to or can’t mod a flashlight. And of course there is the possibility of modding the MT07 for even more output.
Yes, but since the MT07 is already driven harder than the L6 there is less room for modding. With both driven to the max (DD) the output should be the same.
I already modded the MT07 up, but moderately. Probably will do it little by little.
Resistor mod (mild), think added an R075, and sanded down the centering ring base only slightly to ensure flattening (0.92mm to 0.90mm) and files the top down so total height went from 1.95 mm to 1.61 mm. Results:
On fresh GA's:
lumens: 5,678 @start, 5,318 @30 secs
throw: 148 kcd (taken at 5m)
Next mod is to replace LED with a P2 1C, possibly sliced, not sure yet. The sanding down of the LED centering piece increased throw from 140 kcd to 148 kcd, so I'm pretty confident it helps both throw and lumens. The idea is to remove possible blockage of photons coming out at steep angles from the LED. It seems to work on pretty much any light that has that type of centering piece, where the lip protrudes upward, even though it's below flush with the reflector.
