The extension is totally fine by me.
Big thanks to you three for making this even happen!
Added.
Do the 319A LEDs also have 453-Tint?
I would have prefered earlier shipping, but I understand the reasons for the delay.
Thanks for doing this.
Thank you for the understanding, really sorry about it.
Yes the 319A should be available in sm453. But don’t expect the Ra90 or Ra9050 anytime soon. There will be limited samples as usual. I can’t promise you guys I’ll get it though.
Hi
I finally registered so i could get me some of those incandescent-like 219C’s.
I’d like 14 of the 219C 9050 sm305.
Cheers
Welcome to the BLF unique boring guy
PM Djozz for your order
NOTE: Make it 15 and you’ll get the whole last 219C 305. Djozz isn’t online yet. I’ll update the inventory stock in #1 page for you
Thanks
I sent a PM before i saw the note but why not, I have no doubt I’ll find a use for it; I’ve sent another PM. I don’t ‘need’ it the same way as the others though so if someone was hoping to add a single one to their order or something I can easily be persuaded to give it up.
The delay is quite understandable (though I wish it were otherwise) so late December is fine. Thanks for the heads up!
djozz, any of the “219C 90cri 4000k” left ?
If yes, I would take 4 pcs on your 16mm mcpcb…
Clemence is doing the counting, but there were 300 of those so I’m sure there’s enough left.
Added you to the list!
just drop me a PM when its time for payment, too many threads here too many interesting things to read and too little time for all of that :weary:
+1 …very understandable
Finally there’s Nichia seller that will not cost me much for shipping.
Will order some after moving to new house :+1:
Hello,
Would it be possible to swap the XPL LED´s in the Q8 with the 219c without changing anything else (driver?)? Or will they get to much current because of the low Vf? If it is not a problem I am interested in 4* 219C 90cri 4000k. How much would it cost inklusiv shipping to Germany?
Yes, they will be a direct swap into the Q8. They will use a lot of current but they can handle it. Or you can simply use a lower mode as well.
Djozz:
5x 219C 90cri 4000k
Some aditional…
Please a total of
10x 219C 90cri 4000k
3x 144A 9050 sm453 with djozz MCPCB
End of december is ok. Maybe I order some 319A.
Djozz, I sent you a PM about buying a few of your MCPCB’s for the 144a
found it, will answer. I’m sorry, I’m not very fast with answering all PM’s but eventually I will answer them all.
219C 9050 sm305: SOLD OUT
219C 9050 sm353: SOLD OUT
219C 9050 sm403: (75 pcs left)
144A 9050 sm453: (86 pcs left)
144A 9050 sm503: (90 pcs left)
144A 9050 sm573: (98 pcs left)
VirEnce 30mmx30mm CDTP board (28 pcs left)
At this rate we will sell out before the 144A’s come in! :+1:
