That looks sweet, was just looking at buying one of those from illumn.
That’s where i bought mine, not many left on the market.
I’m getting to where I like the smaller lights, I’ve got a T10 and a T10T that I really like.
Yeah i bought the T10T a couple of years ago and thought i’d get the 16340 version while i still could.
Happy with it now after the tweaks or should i say total rebuild.
I received this “Solder bridge” style S2+ copper pill from Hoop long time ago but just used them today.
IMO this is the best driver retention system, it secures the driver very firmly and the ground has a true direct path to the pill. The solderable part is very cleverly designed like a bridge (hence the name) so the heat doesn’t immediately dissipate when applying the iron. Black S2+, NUV FET+1, XP-L HI and smooth reflector waiting to be used with pflexpro’s MT glass.
Built one of my Titanium triples from Rey. XP-L HI 3A, Mth Fet+1 Bistro.
Very nice!!
Funny VW, I just got done with my own Rey Ti tube light triple! lol
I dug out an old driver with the big Vishay 07N02 MOSFET on it, replaced a couple of components to ensure it worked properly, now I have 7 modes to 3 XP-L emitters (dome on) under the Carclo 10507. With an 18350 (how I’ll use it) it’s making
31.57 lumens
82.11
356.73
665.51
1003.95
1411.05
1918.20
This is on an older light purple Efest 18350.
The board is one of the very old original designs when we first quit using Qlite’s stripped down, it’s got components on both sides so I soldered the ground ring into the threads instead of using a retaining ring. There are positive via’s out close to the edge for the positive lead to the emitter, the ground ring would overlap these. They literally left a gap in the ground ring for these 2 side-by-side vias, it’s crazy! This is BLF 17dd Ver 3.0, if you want to look it up. The LVP resistors and Offtime cap are on the battery side of the board, along with zener pads and the reverse polarity diode. THAT’s how big the 07N02 FET is!
I literally found a copper pill with a Noctigon triple already mounted, with 3 XP-L emitters on it, in my kit. (They show up orangy under a UV so they’re in the 2B-3D range) It fit right into this Ti tube light so I went ahead and used it. Was a bit dumbfounded to find it, as I know this is a limited run light, where that copper pill came from is beyond me. It had a copper retaining ring in it as well, the new one had a brass retaining ring. Beats me! But it fit, so it’s in the light and working! lol
Kinda working on a couple at the same time today. Got a bunch of switches bypassed including this lighted one in the SS. Did a few things while the hot plate was on too. Got another SS while the price was right and finished it up today. My second SS triple and did this one with the elliptical optic. Same emitters as the other with polishe optic, XP-L HI 3A. Kept the X6 driver and the lighted tail on this one. Typical hot issues with the reversing brightness but it stays on pretty long on high before it kicks down or the UI issues start. Copper body was stripped of coating, copper spacer soldered into it and the XP32 MCPCB soldered on top.
Cute-3 elliptical? Are you sure?
I’ve got a question…
What wires should i use from driver to leds on a triple xhp70 light , with fet driver ?
Sorry for not using the correct terms, it is 3:30 AM here.
That soldering on the bridge looks real sweet will. :+1:
I did bypass on both springs on the s41s with 22awg wire and changed the stock thermal paste with Arctic MX-4. DMM readout at the tail shows 12.1A with VTC6 @ 4.2v. If i remember correctly in stock form it was about 10A so 2A gain is not bad, it gets hot even faster tho, after 45sec turbo run you cant even touch the copper, it will burn your hand, not very usable.
The super hot running lights work great on cold winter nights. Just sayin…
The CUTE-3 from Ledil comes in Soft Spot, Medium, Wide, that might be the Medium VW used… the wide has an entirely different apperance, somewhat like a sharkskin texture. I’ve seen the wide optic cut 1100 lumens off a 4000+ lumen build.
Hey DB or anyone that can offer advise.
Got the Rey Ti X6. No glass. Is there room for it? or don’t bother. Not in a position to preassemble it but can order to get a head start.
Oh, would need the OD too please.
I just used the Optic, no glass lens. The bezel won’t fit on properly with the added thickness of a lens.
Thanks Dale.
Darn, sometimes I an doing or using stuff that will kill the plastic. I would like and prefer glass over. Oh well.
The glass adds what, 1.85mm? I could cut you a copper or aluminum spacer to fill the gap between the bezel and head, then the glass lens would work without leaving any exposure?
Thank you, will have to see if that would work. Can’t check it ATM, thinking about the O ring at bezel to head.
Also striking out finding 35mm glass. KD has some slightly over 36mmX2mm thick.
