Are there any standard screw placements for each 16mm and 20mm?
The screw holes need insulated vias or additional insulated washer for these boards. For 16mm board, even 2,5mm screw would be too big. It has to pressed down either using the reflector, optics, or additional fastening method if thermal pad is to be used. Or we can use thermal adhesives.
I plan to use thermal pad with 12-16W/M.K underneath the base, far superior than the best Arctic Silver. There’s thermal adhesives with proven 30+ W/M.K conductance from Australian manufacturer. The bad news: it’s permanent and has only 3 months shelf life.
Checked the AIN but still too expensive for small batch quantity.
I do remember it. AIN stands for Aluminum Nitride. I was referring to AIN coating to the base of MCPCB.
Nice find BTW Bark, will read them data sheets tonight.
Lurked into the price list and found the 0,64mm thick cost GBP 148 for a square piece of 25mm x 25mm!!! Usable for only a single 20mm board.
You can get lower price for 20 pcs but it still GBP 33,8/piece
Far more expensive than what I got. No good for BudgetLessFellow :weary:
Yes, for 20mm PCBs there are standards. I would use the same screw hole placements as Sinkpad and all the other companies do. Here at the bottom of the page are some pdf documents with measurements for 20mm Star PCBs from a German company.
Scheduled for January….
My first design wasn’t intended for flashlight, it’s for my personal specific use. This was a perfect size/shape for prototyping many general lightings with 144A/119 series.
I’m in the group buy for 2 of your “universal” boards and I’ll honor that commitment, but I’m definitely interested in some of these boards too. 16s and 20s seem like a great start.
Let’s not hope much. CDTP design is highly surface area dependent, smaller surface area = higher Tj. That means bigger board will be better. But this new design utilizing maximum possible surface area possible for both anode/cathode. I also try to reduce current heating as much as possible. Using dielectric with as high as possible thermal conductivity I could get. I predict it would be a bit less cooler than the standard VirEnce S30 but in smaller 16mm package.
Fellows, you're venturing into new territory here with a cathode direct thermal path board.
The lack of electric isolation is going to be a real hurdle, I think. Something which could be fixed with a thin layer of some über-high conductivity material. If the cathode track pad is reasonably maximized in surface and you can get some thin layer of über-conductive electrical isolator below, the problem is solved, and the industry moves forward.
Pretty sure there's someone around there who can offer aluminium nitride/beryllium oxide sheet/foil at much less than those prices, clemence. Hell, you could get diamond foil for a lower quote, LoL!
It’s indeed universal. I use some for my desk and workshop light with assymetric TIR optics. Plan to use it for my parking area lighting with Ledil Jenny CY optics.
Thanks Bark,
Even without super material CDTP can be designed to surpass neutral DTP approach as long as you have the required surface area. The idea is to lower the heat potential difference (does anyone know shorter terms for this?) thus less thermal resistance. This is pretty much why Nichia still manufacture 2 pads design.
In theory two pads design can achieve lower Tj compared to three pads design (ignoring the surface area required) since copper used in cathode/anode has much better thermal conductance than the dielectric material commonly used in LED. Combined together with very high conductance and thin solder joint such as Indium solder, the result should be even better.
Upstream just at the heat source, heat flux intensity is higher that downstream where the surface area is cooler and larger.
For example: If a 119 has to pass 10 watt of power through two tiny solder pads. The heat intensity is roughly 10 watt/11,9 mm^2 (0,84 W/mm^2). After heat flux passing the solder pads, the intensity lowers down to 10 watt/201 mm^2 (0,05 W/mm^2) using a circular 16mm MCPCB.
- Downstream
Thermal pad material with X thermal conductance
heat intensity ~0,05 W/mm^2
To get the same state, thus X= ~2,9 W/M.K
I still don’t have any valid data to stand up for this one yet. I rather make some and then test it based on that logic. The universal VirEnce board test result was higher than expected. And I think (emphasizing the: I think), solder choice is one of the most important thing in CDTP design, it’s where the bottleneck occurs (not downstream at the MCPCB’s thermal pad). As long as we use MCPCB with surface area reasonably LARGER than the footprint of the LED’s solder pads.
I’m using Sn96,5Ag3Cu0,5 for most of my newer project now. It’s harder on the boards (218C liquidus) than 60/40 and requires extra effort to get a good reflowed boards. The thermal conductance is ~58-60 W/M.K.
I have a spool of SnxxAgxx (lost the label) solder wire rated at 70W/M.K but requires 240C to a flowable liquidus. Much harder and stronger joint very useful for aluminum soldering.
The larger the MCPCB surface/mating area to the heatsink, the less sophisticated the thermal pad required.
