Low-cost copper pills, spacers, optics, drop-ins (Updated 23/10/2022))
I saw your problem with PayPal, did you find any alternative or solution yet? While I don’t know much about AliPay, it does seem like a very similar alternative and I would expect many here to already use that service.
Venmo maybe an alternative as well if PayPal is giving you problems
Received my M1 Quad kits, S2+ kits and X5 kits, in perfect shape, a couple of the plastic containers took a beating but everything survived! :+1: Great Job and thanks, kiriba-ru!! :wink:
I can change plastic boxes in pte bags to corrugated fiberboard boxes, but they weight 60gr more, so this is reasonable for big parcels over 250gr only. Usually such heavy orders cost more than small parcel limit, so I use this type of package rarely.
I’d order a s2 single and/or triple if available
for the s2 single or triple? what’s a fair price to you?
I mean what quantity do you need.
All parts are made on manual lathe so abilities are restricted. For example I dont want to make driver retaining version of convoy single pills.
Prices of S2 pills can be similar to S2+ pills - $16 triple driver retaining, $12 single driver solder/press fit.
Hi,
the M2 Quad kit came in some days ago. Perfect packaging. The spacer fits into the Convoy M2 (from BG) perfectly. Light is not finished yet because the driver is still in the mail.
Regards
Kenjii
I ordered the following yesterday…and it was shipped this morning. That’s excellent service and fast turn around time…thank you very much!!
1 x BLF X5 Carclo quad copper spacer+ss liner
1 x Convoy M2 Carclo quad copper spacer+brass liner
3 x Carclo 10622 24mm quad Narrow Spot Plain TIR
3 x Copper spacer for Ledil Cute-3 triple X6 8.6mm height
interested for 1 BLF X5 Carclo quad copper spacer + ss liner, is available?
Thanks
If first post is saying that item is in stock, this means that it is so with 99% probability.
I can post current stocks photo every week if this is more presentable.
Now to get the funds for a pair of X6 triple “kits”, been wanting to do this for awhile. Hopefully after Christmas.
Bought a bunch of spacers from him and wow amazing customer service and fast shipping. Great to work with :) his products are best I've seen!
I received a M1 quad kit long time ago but haven’t started my build yet due to a small design flaw, the MCPCB “pocket” is 20mm and because the optic is larger there is no room for it to sit its legs. I think it can be an easy fix using a dremel and cutting disk attachment but I lend mine to a friend, so I’ll probably start the build some time later.
Yes I know about this problem. I had several request from users that wanted to have kit for Khatod quad but didnt had optics and havent realized that it requires “rooms” for optics legs.
You need to mill black marked areas.
Anyway you have got some rare part for good price. Ive made 15pcs only and think that this is all.
A little file work! :wink: :+1:
kiriba-ru, received my F13 copper spacer and it fits like a glove! Great doing business with you. Sorry…that kinda sounded like ebay feedback. Anyway, this beats the heck out of trying to sand down half a dozen copper disks on my end. Thanks.
I also got my order over the past couple of days. Mine came in two packages and they got split up along the way, but only by one day. Not a big deal at all, and very fast shipping overall. The parts are very nice and a great deal for the money I think, but I haven’t had time to assemble anything but my P60 shell. I’ll report back as the builds come together.
Thanks.
Quad kits for Manker U11 are ready.
I have built 2 SS triples with your X6 Spacers. It works. Just need to understand that the spacer does not touch in the 20mm emitter hole. It touches on the outer edge to the copper body. Here is a pic where it touches, marked in black.
Both of these SS Triples have Glass over optic. One Cute-SS has been sanded and polished smooth which lowered it slightly. Glass is against the smooth optic. The untouched optic has a slight gap between the Bezel and copper Head. Polished optic has no gap.
