Something like that would be awesome, but unfortunately they’re spherical, not parabolic…
19.41€ 16% OFF|2 stuks 100mm Diameter Concave Spiegels Optics Fysisch...
Smarter Shopping, Better Living! Aliexpress.com
I’m considering shaping a sheet of aluminium and then polish it.
But it will be a ghastly endeavour getting it in the proper shape…
…but it says, Reflector Lens Spherical Surface+ Parabolic Reflector +Bow
Jerommel: mdeni:Here is one small mirror. Page Not Found - Aliexpress.com
They’re used for HID lamps in projectors, so that 2 sides of the light are collimated by an aspherical lens.
Slide projectors have them too (but with a halogen incandescent lamp)
Don’t bother, no chance of getting even close to that cigarette lighter thing.
That same aliexpress store has this, but it is glass so a bit fragile to put in a flashlight. And for the price I do not expect it to be optical quality.
Tbh I don’t care about prototypes or manufacturers, if it throws I will build one from scratch.
The problem is I don’t want to drop $200+ on a custom reflector not knowing how well it will work.
It needs to at least match my 1Mcd aspheric thrower…otherwise it will not be worth the cost.
There’s not enough enthusiasm either so that we could have a thousand pieces made in China for a reasonable price.
Plus i have no idea how to deal with manufacturers, let alone Chinese.
Maybe rename the topic to “DIY über thrower”.
Jerommel:I’m considering shaping a sheet of aluminium and then polish it.
But it will be a ghastly endeavour getting it in the proper shape…Don’t bother, no chance of getting even close to that cigarette lighter thing.
Have you received that ‘solar lighter’ already?
19.41€ 16% OFF|2 stuks 100mm Diameter Concave Spiegels Optics Fysisch optische Experiment Instrument|mirror centerpiece|mirror tvmirror switch - AliExpress
Yes,i have seen those too.
Didn’t look too good to me
I wouldn’t mind it being made of glass though.
Found this in a vintage shop, russian, fifties, with a 35cm parabolic glass mirror in good condition.
LOL, it is labeled as a ‘flood light’, which is correct where the bulb is mounted now . Minor set-back: €795,- did not buy it.
Awesome ‘host’
But they just stuck a E27 fitting in there making the whole thing pointless (hey, that’s a pun!)
Love the wooden tripod too.
Ridiculous price though.
I did some quick test on the fly with the cigarette lighter
just had the camera in one hand and the reflector in the other
its not perfectly focused but shows how it is, good hotspot and some lighter area around it, which is in my opinion not bad at all
XP-G2 R5 with dome at 0.5A
laser range meter says 11m
That looks promising Lexel !
Yeah looks very good, actually looks square, and not a circle
the cigarette lighter is not good enough
I did compared it now to a smaller projector lens
Oh, now it looks really bad in comparison…
I’m going to email optiforms tonight and see how much a 4-6” reflector will cost.
If it’s under $100 I’ll go for it.
I did compared it now to a smaller projector lens.
Ah, that’s a pity…
Thanks for sharing.
And i bet you don’t even smoke either?
You’re gonna make us jealous.
the lens was 20cm from the LED
so overall brightness far less
and spot brightness better
both pictures use same camera settings
f2.8 1/40s ISO1600
Hah I wish, otherwise it will be a waste of $100 xd
Always good to experiment though and pass on information to others who want to try similar stuff.
Could this be the good news we’re waiting for ??
A BLFer contacted me and he is in contact with a Chinese company able to make any size reflector without minimum order quantity
He wants to order a sample of what would be a GT reflector and pm me with results to post (I think he got a little scared of by the little over the top discussion the last pages so for bow he does prefer me communicate about it.)In others words, if a BLFer can do it so a manufacturer
Meaning we could just set the size and shape of a reflector and have some results of it pretty fast and can adjust design based on what we come up with as reflector, this is great news and requires me to edit topic title and OP but I cannot do that till much later today so hopefully you guys pick up on this post
A BLFer contacted me and he is in contact with a Chinese company able to make any size reflector without minimum order quantity He wants to order a sample of what would be a GT reflector and pm me with results to post (I think he got a little scared of by the little over the top discussion the last pages so for bow he does prefer me communicate about it.) In others words, if a BLFer can do it so a manufacturer Meaning we could just set the size and shape of a reflector and have some results o…
Say 4 inch diameter and deep enough to collimate 120° of the emitted light?
That would be totally awesome.
The Miller:A BLFer contacted me and he is in contact with a Chinese company able to make any size reflector without minimum order quantity
Before random ordering a reflector size/focal length, we first must establish what ‘catch angle’ is optimal for a recoil reflector, and my suspicion is that 120 degrees is too much. My fear: the outer part of the reflector will produce a larger and fuzzier image of the die and therefore hardly contribute to the throw. As well as Lexel I will experiment with the cigarette lighter reflector to see if I find the same as with the Mirascope reflector.
