So should I interpret your last comment as a dig at non-native English speakers, because I’m pretty sure the membership of this website is strongly international…
You said:
… so what’s the second half of that statement?
“There are flashlights that size with a standard reflector that get nearly 2x its throw, but they don’t have the same smooth flood light capability.”
That is how I’d finish it.
It appears that instead your argument is:
“There are flashlights that size with a standard reflector that get nearly 2x its throw, and can also provide a similar smooth 76 degree flood beam.”
If I’m interpreting that correctly, I’d like to know what light you have in mind that can do both even and smooth flood lighting, AND 20kcd. In a 1x18650 25mm tube light format, don’t forget.
The FD30 at its flood setting advertises 1100cd and specifies a 76 degree flood beam, which is fairly wide. If you run the numbers for for 1100cd and 76degrees, it translates to 1465lm, which is not a lot more than the 900lm that Fenix specs as the flashlight’s overall output. (Alternately, you could calculate 900lm, 76deg = 676cd) That tells me that the 76degree flood is pretty evenly lit, with likely a large/mild hotspot. In contrast, let’s run the numbers on 76degrees and 20kcd: 26,639lm. So again, please tell us which light you have in mind that can do both smooth 76deg flood, and 20kcd.
I marked your comment rude because this is the second time (that I know of) that you have come into a thread about focusing/zoomable lights begun arguing (or implying - sorry ::eyeroll ) that a standard reflector light can do the same or better on both ends, which is simply not true.
edit: I’m done, I removed the rude report. Carry on, I’ll be elsewhere.
