Armytek Prime C2 (v3) XP-L emitter swap - who has done it?
34 posts / 0 new
The_Driver
The_Driver's picture
Last seen: 12 hours 45 min ago
Has anybody here swapped the LED of an Armytek Prime C2 V3 XP-L? I like this light quite a bit, but Armytek has made it really difficult to get the LEDs PCB out. It is fastened with brass rivets inside the head. The difficult part is that one needs to avoid damaging the cables because those can’t really be replaced. The problem with this is that the cables come up through the rivets!
An experienced modder is helping me and he has basically given up on the light. Too much risk, he says.
Edited by: The_Driver on 12/04/2016 - 13:47
Budda
Budda's picture
I gave up on Armytek modding.
All my reviews, in italian and english, here: Lumenreviews.com
chadvone
chadvone's picture
Last seen: 1 month 1 week ago
That as far as I got on my Prime.
Bort
Bort's picture
Last seen: 1 week 3 days ago
Being brass you can carefully upend both of the ends and presumably pull out the star. Precision work with a small diameter steel rod, or even dentist tools.
Assuming its not then glued you can remove it. If it is glued you may have to break it
If the rivets were not there would the reflector hold it in place (or you can add glue later as well).
You could pull it apart but ruin the light, or you may be ale to replace without a hitch or something in between, is it worth the risk?
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
The_Driver
Bump!
Anybody else have experience in this regard?
eebowler
eebowler's picture
Last seen: 3 weeks 3 days ago
Sorry mate, no experience. My prime A1 didn’t have the rivets. I would disconnect the leads first and try with a pick, sharpened small screwdriver, or knife to pry up the edges of the rivets. It doesn’t matter if they are destroyed if you have thermal epoxy or if the reflector/optic presses down on the star..
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
The_Driver
Was your PCB glued? If so, how did you remove it?
eebowler
eebowler's picture
I don’t remember scraping any glue from the star or flashlight, so it must have been only thermal paste. I reflowed a warmer XM-L2 onto the stock star and replaced the paste with what I have.
clemence
clemence's picture
Last seen: 22 hours 55 sec ago
No it’s not glued. AT only use sticky thermal paste. You can check it yourself, the MCPCB can slide sideways a bit. I will mod mine as well as soon as I got some left over 219C Wink
AT use rivets to make it more durable (and harder for us). I love this Prime very much, slim and durable except the too stiff switch.
- Clemence
The_Driver
Clemence, you were able to mod your light with The rivets?
clemence
clemence's picture
No, I was waiting for you to do it first Silly
But it seems it’s the other way around now Big Smile
Will try it today
clemence
clemence's picture
Here you go….
Not the prettiest surgery, but that was a quick easy job. Sacrificed a small flat screwdriver, sharpened to blade
OK, mr. Driver, it’s your turn now
Cheers,
Clemence
clemence
clemence's picture
Very nice result! Much tighter beam, definitely great tint, and of course lower lumen output. But you won’t want to get back to those ugly XPL! Thumbs Up Crown
It’s like upgrading to XPL HI with all the benefit of 9050 219C – Lossless swap!
Will post the result + beamshots tonight Wink
The_Driver
Thanks a lot! My hopes have gone up again Thumbs Up Smile
clemence
clemence's picture
Sorry guys, I couldn’t find the Bear Smile
The_Driver
Indeed “premium” Wink
The difference in hotspot size does seem noticeable though…
clemence
clemence's picture
The_Driver wrote:
Indeed “premium” Wink The difference in hotspot size does seem noticeable though…
Couldn’t resist not to add “premium” label next to the original “premium” branding. Why AT uses premium word for such a greenium stuff?
- Clemence
Gunga
Gunga's picture
Last seen: 3 hours 5 min ago
Anyone mod a wizard or tiara? Similar construction?
The_Driver
In the russian fonarevka forum somebody opened his Wizard (XM-L2). I think the PCB was just screwed down. It’s a little bit more difficult because the bezel ist press fit instead of screwed. You need to pry it up.
clemence
clemence's picture
Ask Dale here in BLF. He managed to pry open his Wizard. Link: http://budgetlightforum.com/comment/1048158#comment-1048158
The trick is how to remove the fit pressed bezel. Some suggest to freeze it, while I prefer to heat it up to 200C.
eebowler
eebowler's picture
I could NOT get my tiara C1 open. Even cut grooves in the bezel to turn with a steel ruler (too bendy) or force it with a hammer and screw driver and got nowhere. The ring might be press fit or shrunk fit? (where it is freezed and after heating up, expands tightly into place.)
Gunga
Gunga's picture
Oh. That sucks. I’m wary of their xpl neutral. I’ve seen some pretty green neutral XPL,…
clemence
clemence's picture
To my understanding, heating expand most materials, and vice versa. With freezing as suggested by some member, you’ll only get it shrunk tighter. Al. has higher thermal expansion coefficient than SS (the bezel). Al. will also shrunk more than SS in cold. So heating is the way to go. The ideal case is to heat it up to a point where there’s no interference fit between aluminum and stainless – the bezel should fall off the headlamp. But….
Even though that most SMD should withstand leadfree soldering up to 260C for 30seconds (At least you know you’ll not ruin the components at that elevated temp), not many manufacturer use leadfree, you could make all the components fall off the board by heating up to 260C. Armytek seems to use 63/37 solder judging on the temp I used to de-solder the emitter (180C).
The PMMA optics used also rated only 120C. The red locktite will soften at 140C. The O-rings, button, and epoxy/silicone potting compound will probably much less than that.
100C is the safe side if you want to heat it without destroying all those low temp parts. Otherwise use your heat gun set to 250C.
I plan to make a contraption especially just to remove the bezel from all those press fitted flashlights. Once we get a good grip on it, adding more heat should make things easier.
- Clemence
clemence
clemence's picture
No girls are pretty when they’re green Silly
Gunga
Gunga's picture
Was yours neutral?
Edit: just saw that it was green. I mean cool.
clemence
clemence's picture
Gunga wrote:
Was yours neutral?
I modded my WGW Prime. It was good ONLY in turbo mode. Lower modes = more green.
I never really use the CGW, too harsh to the eye for most uses. Also gives you eerie horror movie feeling if used in the foggy woods.
Edit: WGW = Warm Green White; CGW = Cool Green White
clemence
clemence's picture
Gunga wrote:
Was yours neutral?
Before modded:
I use EXACTLY the same emitter tested/pictured here:
Gunga
Gunga's picture
Any one tried the tiara c1 warm xml2 high cri? I don’t trust the warm xpl they use.
The_Driver
I have the Wizard v1 with the high-cri XM-L2. If you like the light from household halogen lights, you will like this LED. Is is basically identical (including the pronounced yellow tint). I used to really like it, but some of the better Nichia and Osram (and Yuji) LEDs have slowly changed my opinion. This doesn’t mean that it is bad, but there are definitely nicer LEDs these days. Two years ago it was basically the only 90CRI headlamp on the market.
The_Driver
Well, we tried, but we managed to kill the driver in the process. One of the parts got mechanically damaged and we can’t tell what is written on it because the potting covers the top. I will probably contact Armytek and try to get a replacement.
clemence
clemence's picture
Hi Driver,
Have you succeeded? I’ve done several more mods with success (only minor scratches on the PCB). Once you get it, it’s fairly easy. I got 6 more modification orders for Tiaras and Primes. Still waiting for the stuff to arrive.
- Clemence
