I have been tweaking my light canon, and Iām ALMOST at 1.5Mcd!!!
Sooo closeā¦ 61000 lux at 4.9m = 1.46Mcdā¦
I will post pics when I get to the magical 1.5!
Truly awesome Lux numbers, looking forward to seeing pics of the light and set up.
For what itās worth, Canon is a registered trademark of a camera company, your use of the word would be cannon, as in long thrower. (just a bit of OCD coming through, right is right, after all)
Wouldnāt a light ācannonā project a large diameter beam, like the old aircraft search lights? Maybe I need coffeeā¦ sorry
Wow!! Congrats on this site unseen project! Try a reading at 10-15 meters, betcha you will get over 1.5 easy... I think every light I've tested at 5m got a nice little bump at ~12m, plus it's actually more accurate.
Sk68 died a smoking blue death (single mode with liion cell) so I pulled out the pill and reamed the hollow shell to the OD of 1/2ā copper pipe(.625ā). And made up a copper insert. I might go old school and direct solder an XRE since a sinkpad would raise the die out of focus.
Thanks guys I actually made a mistake in my calculations, thereās a thing called etendue, and due to this the formula 1/r^2 doesnāt directly apply to my light because of how it is almost collimatedā¦
The farther I take the measurement from the light, the more lux @ 1m I get.
The correct way to calculate it is by using this tool: Candlepower & Divergence Calculator For Uniform Beam Lights or you can do a bit of trig to manually figure out the distance behind the lens
This means that Iāve always been underestimating my measurements, and I might be getting actual candlepower in the tens of millionsā¦.
I need to make new measurements at a longer distance, and measure the diameter of the spot to figure out the real number, so hopefully in the next week I can actually tell you guys the real numbers
Yes, but there are so many ālight cannonā named lights I wanted mine to show up on google search, so I named it ālightcanon flashlightā so that it is pretty much the first result
The last emitters I bought to dedome died under direct drive, I think they were U3ās?
What bin of XP-Lās are known to be more ādurableā? I know the W2ās on Aliexpress are an option, but Iām not sure I want to spend that much yet
The XP-Ls are new cree production. with the really low Vf, so pretty much any bin in direct drive will die from too much current.
You need to use a current limiting driver for these, not FET or DD
Iām really not sure what you are talking about. I have heard zero reports that XP-Lās suddenly have a lower Vf. Unless you are talking about XP-L2ās?
This is interesting. The details of this are not often discussed. I think for largish diameter lights this definitely makes a significant difference in how we would calculate the throw (cd).
I think you explained it fine; this is just some further explanation of my understanding of the subject. The inverse square law, which we use to calculate the cd, is valid for a point source of light and the distance in the formula should be from the point of light to where you measure. With flashlight beams, the light appears to come from a point behind the flashlight, not the face of the flashlight, and so this effective distance should be used in the formula, (cd)=(lux)(d^2), instead of just the distance to the flashlight.
Something bothers me about that calculator you linked, though. It implies that (with all other things the same) the size of the emitter affects the divergence distance behind the aperture. This somehow doesnāt seem right to me. I did some quick tests with my UF 1504 lens light. To get a more accurate measure of this effective divergence distance, I measured the beam size at different distances (2.5m, 4.2m, 10.2m from the lens), then simply graphed the points and drew a line through them. The point at which the line crosses zero is the effective point from which the light is emanating. I did this with two different sized emitters, the dedomed old XPG2 and the XPL HI, and got equal divergence distances behind the lens, 2.5m. This means, effectively, that the beam size is not the size of the lens at the lens. Anyway, I donāt understand all the implications, just wanted to put it out there.
They were XM-L2ās that died, but when I reported it I realized that it wasnāt just me, U3ās were dying for everyone. So I was wondering if there is a similar ācursedā bin of XP-Lās
