I just don’t think it can be done.
Making it too hard imo
Then do you have any meaningful contributions or suggestions that would help?
There have been some strange happenings here lately…… I really hope no one is trying to hijack the GT idea.
Wow, 5ar, amazing! Also thanks for the comparison between our two designs!
Since you still have the old design (the light is around 17mm shorter there I think) maybe you could exchange it to the most recent version:
http://i.imgur.com/wMIGf3t.jpg
But only if you have time! It doesn’t really matter that much as they are quite similar anyway.
The light is 341mm long.
Sorry for not replying earlier. As thijsco19 already wrote, I performed some thermal analysis and the results do in my opinion not justify a change of design.
Here is the analysis with the design as it is:
And here the analysis with additional cooling fins and without switch or anything.
So there is a difference of 2.4 degrees. If I add a switch then it’ll be even less. So as I mentioned, in my opinion it does not justify a redesign. However, ultimately it is up to everyone who votes to judge that. But after performing several analysis I can say with confidence that heat will not be an issue in any of the designs. The light is so huge and has so much mass and surface that even with an XHP70 or more we wouldn’t run into problems. Additionally, I performed the analysis under quite strict conditions. The ambient temperature is 30 degrees Celcius (which is quite hot) and the convection coefficient is around 20 Iforgottheunit. As soon as you go outside with the light this coefficient will go up, furthermore, your hand holding the light is actually also quite good in getting heat away. The heat added to the heatsink is around 40 Watts which is quite a bit more than out XHP35. Maybe someone knows how much heat the XHP35 actually emits?
i am in for one
Fritz, if anything, the fins seem to act as a dyk/buffer to keep tube cool, I like that, i hate hot cells
Agree with J-Dub74 one a “tactical” ring, italso is nice anti roll
Vol,it is clear you want another light to be made, thatis cool,but this is not the toic for that.
As erommel did withtherecoil thrower I suggest you start a topic for it, BLFs a very friendly and helpfull community so who knows what is going to happen there then.
It is indeed good to see a large reflector for ~$3,20
sureit is not the size we want but still it is huge for the price of a C8 reflector, nice.
And of to update the OP!
Yes OP list updated, all should be there.
Jerommel, this stage is getting an idea and for us away to show the idea
We all understand that the disign to be chosen will need some tweaking along the way or details adaptations.
Here my design for the BLF GT. Some details are mentioned further down
- Attachment points for shoulder strap
- Tripod mount close to the centre of mass
- Illuminated switch
- Tailswitch
- Anti roll design
- Fine thermal behaviour
- (Possibly) Plastic cups on tailcap and bezel to minimise impact when dropped and increase durability.
Please note the designs are just conceptual and no matter which design will be chosen there will probably be some small changes (Mine for example might get some more anti-rolling details).
Here is a thermal analysis which uses quite strict values:
The reality will be colder. For more information about heat and the fin placement see here and here.
Additionally, IF some folks are interested in a handle and would be willing to pay a little extra for this feature, this design allows an easy attachment of a handle. This would not add any costs for anyone who doesn’t want a handle! However, this is just theory and would depend on the amount of people who would want a handle.
And finally I have to say how awesome the BLF community is. We are creating this unique light, so many people have valuable input and we have several different amazing designs of which we can choose from. :+1:
I bet Thrunite is watching, maybe Acebeam too! Since they started the XHP35 thrower revolution! It’s only common sense that a bigger thrower would come out, eventually! Maybe not for a “Budget” price,which is yet to be seen so far, but you never know!
So get cracking!!! :+1:
Yeah Kawi!
Fritz amazing post! Thanks.
I have to say it is going to be a very hard choice between these great designs… When does the voting start?
Fritz,that`s it :+1:
Regards Xandre
Tonight at 23 local time (~9 hours from now) I am going to build the poll
Including two pics (or one with the design twice) of each design and a link to the post of designer where they can have more pics and a talk aboit it (so for Fritz the blpost above for example)
Of course an nonsense option and the possibility to choose “I am OK. With whatever design, just make the GT”
Very nice look'n design! I like the overall shape, just not a fan of all the smooth surfaces. Not sure bout the whole thermal analysis - the fins as designed do not gain all that much surface area - too few, too thick, too shallow, and from their location and size, I'd say they will do very little, not even worth having. Are the threaded connections taken into account, and if so, how does/would a good thermal conductive treatment on those threads effect it? I've seen actual thermal imagery of the effect and it's significant. Also for thermal imagery, all depends on time lapse - hot zones tend to spread over time. What you are showing there is a simple snap shot at one moment. You reach a critical max temp, then it spreads over time. In reality, it's pretty complicated, and with other factors you mentioned - holding it, ambient temperature/humidity, etc.
Hi, you are of course right, this is just a theoretical consideration. However, the conditions are worse in the analysis than they are in real life and it is just meant to see that it works. The heat distribution with the boundary that heat is added as well as the ambient temperature will converge to some equilibrium for a large Time t. Those thermal analysis consider the equilibrium state.
This has been one heck of a thread. Hard to follow as it seems to move at the speed of light but fascinating from the start.
Fritz, while I don’t necessarily want this light to be the BLF GT that is only because I was already completely sold on the 5AR design. Your unexpected entry here took me by surprise. I would definitely love to see your light in production not necessarily as the GT but how about the GTX? :student: I’m at the point where I refuse to choose. The unique look of your light with the handle is just awesome. I want them both. Well done. :+1:
I like the surface treatments of the HaikeLite MT07 for example, don't care for the smoothness of the TN42 design, though the overall shape/form factor of the MT07 is awful and the TN42 is better. The MT07 and TN42 are almost two opposite extremes of designs for big lights - TN42 is designed for light weight and a thin look, MT07 doesn't care how heavy or butt ugly it is...
Hi, thanks! Maybe if it won’t be the BLF GT design something with a 90mm reflector and an XHP70 would be interesting as well
I’m IN! :+1:
Fritzs, I am really curious, what happens if you do the thermal analysis with ~240W+ of power from the LED as would be the case in a quad XHP70? Or even 120W from quad XHP35? Or what about ~80W from a single XHP70?
The idea with this light is to be overbuilt to the extreme to allow for anything we could possible dream up later to be easily done.
