PM (with coupon) sent
(1) NW please (thank you)
Ordered
How about this… instead of producing an exact Manker copy. Utorch offers a XPL-HI w/ smooth reflector option… I would be in for a couple of those.
It could be the UT01 V2 .
Contact gearbest , you never know
I would like two NW.
Many thanks
This seems very similar to the Klarus Mi7, but of course this one is cheaper, and I don’t see a neutral white option for the Klarus. Am I missing anything, or is this one just the obvious choice?
This one does not have a XP-L HI.
Review sample is here !
More coming soon
I would like 02 NW.
Thank you.
Finally! Come on now, give us the review, can’t wait!
Ordered 02 NW.
Thanks.
Me too!!
If you could start with:
- overall build quality
- output levels
- power on max on Eneloop/Alkaine (is it about Klarus Mi7 or more like Manker E11)
I would be very grateful
Also, if you don’t mind, could you confirm the mode order, and whether or not it has memory? Thanks!
And beamshots!
And tint impressions/comparisons!
And runtimes!
Ha ha, I know you’re working on it - looking forward to the review!
The review will be posted tomorrow . But here is a sneak peak :
UI : Ultra low - Low - Medium - High and hidden Strobe - Sos - Beacon mode
From off :
Single click (short) turns light on , on the lowest mode
Longer click turns light on , on the last used mode (not available for ultra low mode , because you can access it with short click)
Double click turns light on strobe (you enter hidden modes)
From on :
If you are in a regular mode :
Single click cycles between (Ultra Low - Low - Medium - High)
Double click and you’re in Strobe
If you are in a hidden mode :
Single click cycles between (Strobe - SOS - Beacon)
Double click and you’re in last used regular mode
Also , max lumens on High , using 14500 should be ~600 (to be confirmed in review) .
Doesn’t fit protected 14500 as some people said .
High quality from a quick view .
So far I like it’s UI, but not the “Doesn’t fit protected 14500” part.
Giorgos, could you compare UT01’s lm/cd output to Mi7’s?
I don’t own a Mi7 . Sorry
Strange!
The Mi7s I’ve ordered haven’t arrived yet, else I’d gladly give you one to compare.
The E11 suffers from this too
