Review : Utorch UT02 Flashlight (XHP35 / 26650 / usb rechargeable)(in progress)
237 posts / 0 new
giorgoskok
giorgoskok's picture
Last seen: 6 days 6 hours ago
Utorch UT02 LED Flashlight – 1300Lm Cree XHP35 HI 2A Quick Charge
Groupbuy here : Click!
Overview :
Brand: Utorch
Model: UT02
Lamp Beads: Cree XHP35 HI
Luminous Flux: 1300LM
Luminous Intensity: 124000cd
Color Temperature: 1A 6500K / 3D 5000K
Feature: Anti-Roll Rugged Design,Cooling Slot of High Efficiency,Lanyard,Lightweight,Low-voltage Warning,Pocket Clip,Power Indicator,Tail Stand
Function: Camping,EDC,Hiking,Household Use,Night Riding,Walking
Switch Type: Side Clicky
Mode: 7 (Turbo – High – Mid1 – Mid2 – Low – Strobe – SOS)
Battery Type: 18650,26650
Battery Quantity: 1 × 18650 / 26650 battery (not included)
Rechargeable: Yes
Waterproof Standard: IPX-7 Standard Waterproof
Power Source: Battery
Working Voltage: 2.8-4.35V
Reflector: Aluminum Smooth Reflector
Lens: Toughened Ultra-clear Double Glass Lens with Anti-reflective Coating
Beam Distance: 601-700m
Impact Resistance: 1.5M
Flashlight Processing Technology: Aerospace Grade Aluminum Body with Anti Scratching Type III Hard Anodization
Available Light Color: Cool White,Neutral White
Available color: Black
Product weight: 0.306 kg
Package weight: 0.470 kg
Product size (L x W x H): 14.80 × 5.90 × 5.90 cm / 5.83 × 2.32 × 2.32 inches
Package size (L x W x H): 24.00 × 9.50 × 9.50 cm / 9.45 × 3.74 × 3.74 inches
First Look :
*Package Contents: *
1 x Utorch UT02 LED Flashlight
1 × 18650 Battery Holder
1 X USB Cable
1 X Lanyard
1 x O-ring
1 x English Manual
Some more pictures :
Flashlight has a nice , kind of matte anodization :
UT02 length : 14.80cm
Utorch logo close-up :
Closer look to the e-switch :
Back side , with USB port :
And a closer (over-exposed) of USB port :
Very nice Knurling :
Square , Anodized threads :
And tailcap side :
Reflector :
Reflector is made from aluminum , and it has zero imperfections :
Parts & Disassembly :
Left to right : UT02 head , Battery Tube , 26650 battery , 18650 battery , Tailcap
Driver side : Double springs , gold plated
Tailcap : We have double springs here too , and springs are soldered on a pcb that makes contact directly with the battery tube
I think most long 26650 batteries fit (sorry , i don’t have longer than Basens) :
Bezel removed (no glue Big Smile ) . Reflector is threaded , and glass is AR coated :
Led is on DTP mcpcb (28mm ?) :
How it works (&modes) :
From off —> one short click turns the light on at the lowest level.
From off —> a long click turns the light on at the last used level (low mode does not count).
When the light is on —> a double click gives you strobe mode.
When the light is on —> a single click when the light is on advances in the next mode (low-medium-hi-turbo (if you are in the constant output mode) , strobe-SOS-“breath flash” if you are in the flashing mode).
Slightly longer click turns off the flashlight .
There is a shortcut for breath flash: from off make 3 double click.
When the light is on breath flash, a single click will activate the SOS, a double click will activate the last used mode.
In breath flash mode, the led under the switch will slowly turn on and off .
Measurements :
Using… Liitokala Lii 26650 battery
Lumens on highest setting (high mode) : Coming soon…
Intensity : 84kcd
Tailcap measurements (amp draw) :
Standby current (parasitic drain) : 0.007mA
  • Low – 109.7mA
  • Medium1 – 0.30A
  • Medium2 – 0.60A
  • High – 1.08A
  • Turbo – 2.60A
USB charging :
When you connect the micro-usb indiactor turns red , and blue when battery is full .
Charge current is 1.95 A . (Approx 3 hours for a 5000mAh cells) .
Beamshots :
Coming soon…
Edited by: sb56637 on 09/02/2017 - 11:56
keithd
keithd's picture
Hmm, so how hard would it be to get the driver out?
Thank you for the review, now I’m wanting one…
giorgoskok
Once i take the last measurements we will see Wink I think pretty easy …
wolfdog1226
wolfdog1226's picture
Last seen: 1 year 1 day ago
Thanks for the review!
Hmmmmmmmm that looks awfully similar to my Manker U21vn!!!!
Exact same tail cap assembly and spring assembly in the head w/ the same numbers,,DL053/DL046.
Only difference is some knurling on the handle. Wink
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
eebowler
eebowler's picture
Last seen: 4 months 4 days ago
Looking really nice!!!
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
giorgoskok
Just measured standby current (parasitic drain) : 0.007mA
Tom E
Tom E's picture
Last seen: 43 min 29 sec ago
Ok, good review so far... But those amp readings are very low. The XHP35 HI draws lots of power, much more than a 3.6V LED from a single cell (boost driver).
My Manker U21, and another I modded for Light Junkie, have dedomed XPL's in them, and it cranks in lumens and throw, support with the switch LED as a indicator LED, nas smooth ramping from Narsil. What did Vinh do with the U21?
Both mine and LJ's drivers crapped out, so not much choice but to mod it up.
giorgoskok
I checked 5-6 times the reading in turbo (lii 26650 – 30q – vtc5a) , seems low to me , too . I’m using Uni-t clamp meter for the high modes .
Vinh did the same thing you did , dedomed xp-l and fet driver (without your awesome Narsil of course) .
How did you remove the driver on your U21 ?
Tom E
Tom E's picture
wolfdog1226 wrote:
Thanks for the review! Hmmmmmmmm that looks awfully similar to my Manker U21vn!!!! Exact same tail cap assembly and spring assembly in the head w/ the same numbers,,DL053/DL046. Only difference is some knurling on the handle. ;)
Yes, it sure should look just like the U21. It's "disgusting" according to Manker, but no further explanation surprised. We are trying to figure out if it's made in the same factory, same guys, same parts, etc., or is some level of a clone, or they simply fell off a truck and got some re-branding. I'm thinking GearBest got disgusted with Manker for enforcing MAPS, or some other pricing restrictions, so did some creative product procuring. Manker has been play'n hardball with pricing, no group buys, etc.
keithd
keithd's picture
I wish some company would do a “re-brand” of the MK34. I really, really, really like that light but not the company behind it. What to do.
Tom E
Tom E's picture
giorgoskok wrote:
I checked 5-6 times the reading in turbo (lii 26650 - 30q - vtc5a) , seems low to me , too . I'm using Uni-t clamp meter for the high modes . Vinh did the same thing you did , dedomed xp-l and fet driver (without your awesome Narsil of course) . How did you remove the driver on your U21 ?
Ok, dang, I do need a better memory (mind?), I'm pretty sure it was lightly glued, and needed some pushing. I probably went from the top - used a solder pick to poke thru one of the LED wire holes and apply pressure on the outer lip of the dirver til I get some movement. Oh boy, let me check if I got pics.
giorgoskok
I saw them Tom , in your review .
It’s the same way mounted on the UT02 i suppose (some eppoxy) . No retaining ring .
Tom E
Tom E's picture
Here's a pic from LJ's:
Ahh, here notice the glue, actually is like white thermal epoxy, not very strong:
keithd
keithd's picture
That doesn’t give much hope for reprogramming anything.
wolfdog1226
Tom E wrote:
Ok, good review so far… But those amp readings are very low. The XHP35 HI draws lots of power, much more than a 3.6V LED from a single cell (boost driver).
My Manker U21, and another I modded for Light Junkie, have dedomed XPL’s in them, and it cranks in lumens and throw, support with the switch LED as a indicator LED, nas smooth ramping from Narsil. What did Vinh do with the U21?
Both mine and LJ’s drivers crapped out, so not much choice but to mod it up.
I have the XPL version.I love the light,a little more lumens and the same throw as my M2Xvn!
Spec 1: XPG2 PDT, Most throw, least heat, tight hot spot $132
ANSI
Lumen: 870
Lux: 320K
Throw: 1130m
Spec 2: XPL PDT, High output, larger hot spot $122
ANSI
Lumen: 1500
Lux: 260K
Throw: 1020m
        WOLFDOG
hIKARInoob
hIKARInoob's picture
Last seen: 1 month 4 weeks ago
Ok, so the U21 has/had problems with fried drivers. Is there anything known about the possibility the same problem could occur with the Utorch?
Tom E
Tom E's picture
About the fried drivers, really dunno. My died after the tear down for the review, but it was an engineering prototype unit. The other one was used for a few weeks before it died. I haven't heard of any one else having problems, but haven't really heard much at all overall. With all the Manker drama, and the fact it was never offered discounted kept BLF sales down I would think, but it's a great light - really like it's size, performance, quality.
Ahh, ok. Vinh is good at getting the most throw w/focusing. The two I modded using dedomed XPL's do about 1,700 lumens (@30 secs) and 240 kcd, but measured at 5 meters, so could be closer to 250+ kcd measured at 10+ meters.
will34
will34's picture
Last seen: 4 hours 35 min ago
Thanks for the review. Seems like a good host for modding, stock amps are very low though…
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 11 min ago
Meh, just got 2 of them today, 2.45amp and 2.22 amp on the other! Purple Efest 4200, Basen and a Imren IMR 26700 all read the same. Dust particles on/in both reflectors and a smear of shmuck on the inside of the lens on one of them! Facepalm
Seem well built, focused. Don’t like the switch, sets too low for my liking, too much travel a PITA to activate for me any way, FAT fingers!!! Just wish they were cleaner inside, I’ll try blasting the crap out and clean the lens. Angry Hopefully they will clean up? Sad
KB1428 “Live Life WOT
hIKARInoob
Tom E wrote:
About the fried drivers, really dunno. My died after the tear down for the review, but it was an engineering prototype unit. The other one was used for a few weeks before it died. I haven’t heard of any one else having problems, but haven’t really heard much at all overall. With all the Manker drama, and the fact it was never offered discounted kept BLF sales down I would think, but it’s a great light – really like it’s size, performance, quality.
Ahh, ok. Vinh is good at getting the most throw w/focusing. The two I modded using dedomed XPL’s do about 1,700 lumens (@30 secs) and 240 kcd, but measured at 5 meters, so could be closer to 250+ kcd measured at 10+ meters.
“The Manker Drama”. Sounds like a Netflix series.
LightRider
LightRider's picture
Last seen: 2 years 1 month ago
Isn’t 2.6amps on turbo kind of low? Maybe not. I was expecting more though.
hIKARInoob
It’s a 12V led…
LightRider
hIKARInoob wrote:
It’s a 12V led…
Yes but amps were taken at the battery where it is still 4v. So led amps is well under 1amp
hIKARInoob
LightRider wrote:
hIKARInoob wrote:
It’s a 12V led…
Ah, ok. I think this was one of the odd things of the U21; the light wasn’t pushed hard at all, nothing like the E14 for example. The light was ok, but nothing more than that…
BOMBAY
Last seen: 50 min 48 sec ago
UT02- 2.6A , U21-5,5A on Turbo
hIKARInoob
Sorry, it’s messed up in my head lol.
DB Custom
DB Custom's picture
Last seen: 1 day 7 hours ago
As far as the XHP-35 goes, 2.6A is the sweet spot, output drops off after that. That’s emitter amperage though, I don’t know what tail current should be on this particular light to achieve optimum emitter current.
Edit: This is both in my experience and with testing TA is doing. Wink
Tom E
Tom E's picture
Amps at the cell is like 4X the LED, roughly, maybe little more. Should be doing over 5A because stock, the U21 was like 1300 lumens, so in the 1-1.5A range, think it was spec'd at 1.3A at the LED. Wonder if he had it on true turbo... I've made that mistake before.
Since these boost drivers are a bit more finicky, don't think you can crank them up much, plus it's a huge pull of amps for a single cell - 2.5A at the LED is at least 10A from the cell. Good reason to convert the driver over and go with a conventional single cell LED, like the XPL. I got just over 1,700 lumens on a dedomed XPL in this light.
khas
Last seen: 8 hours 44 min ago
Thank you for the review so far, the amp draw is very low, I have a X1 with a boost driver it pulls 7,34A on a rested King Kong 4000 mAh ICR26650 at the tail for 1,47A at the LED. I think it should be pulling at least 5A to get 1A at the LED.
giorgoskok
I have already contacted Gearbest and i’m waiting for more info about the driver . It should pull 5-5.5 amps .
Intensity is lower too , something isn’t ok with the driver .
cdjaney
cdjaney's picture
Last seen: 7 months 2 weeks ago
Making not look forward to the delivery of mine now. Hmmmmmmm……
John 1:5 "The Light shines in the darkness, and the darkness did not comprehend it."
