Pick the HG2 and the 30Q, and only turn on the 5A curve. I think this is what I've seen in my own tests - slight favor goes to the 30Q, but again, they are very close. If you can find a better/cheaper source for HG2's or already have HG2's, they are a good cell and will perform well.
The differences shown in HKJ's tests could be negated by normal batch to batch, or cell to cell variations.
To add confusion, some lights perform better with a cell that tests lower. I’ve seen a cell give more amps, but less lumens. The thing is that it’s not cold hard facts, there are always variables.
Any of the top cells will work well. The ultimate high performance is usually, or typically, only in the first seconds of use anyway and even then the differences are subtle and undetectable to our eyes.
Okay, a question I should know the answer to, but just for assurance, how “matched” do the four matched cells need to be? Should we check capacity before using them as a set?
As long as they are within .1-.2V they should be fine, the closer the better naturally.
I charge all my cells on a parallel charging bank and My rule of thumb is .5-.6V between cells before connecting them together. I have done as much as 1V without any effects though.
Well, others are more qualified to answer this, but for me - reasonably close. Certainly they should be rated the same and be the same make/model, and hopefully a top 5 brand (LG, Sam, SANYO, PANA, SONY). Better still from the same batch, typically if bought at the same time. If you met those conditions, I'd feel safe enough. If fairly new and not much charge cycles, I wouldn't check, but if they are a bit older and racked up some usage, good idea to check they are charging up to the same level, taken into account charger slot differences, etc.
yeah I have sets, check IR and mAh
use them as sets (both series or P)
when I put them in the charger check regularly to see if they all charge about the same.
I’ve got to say that I’m absolutely giddy with delight over the idea that if TF gets this right (*crosses fingers AND toes), I’ll be wielding a pair of bada$$ lights at a superbly economical price. Thank you to everyone involved with getting this thing happening!
I wonder what the TF price will be after this initial group buy if it’s made per the specs on the first page. It seems like it will stack up against lights costing easily three or four times as much.
Seems so simple doesn’t it? All they have to do is build the driver exactly as it was designed and tested and they have a serious top shelf winner on their hands. Don’t follow the recipe, they just have a mess.
I work with many Chinese shop owners and the one thing I notice for 110% certainty is they are extremely tight as all mighty penny-wise. An example is asking for credit for literally 1/2 a bottle of fizzy drink - because the boxes come in 15’s, and 7 were leaking. I said I would credit half a box…… meaning the 7 damaged…. but he took me literally and demanded 7.5 were credited :person_facepalming:
We are all hoping for that driver to be to 100% spec but I’ll be honest I’m getting a little apprehensive now. Obviously I know not of what’s going on behind the scenes. But I think 8 months is pushing the boat out……
Adding latest battery tests, including the protected GA's just received last night, the LG2's with solder tops, and 30Q's solder tops to make the comparison with the LG2's
Measurement of the Protected GA's:
Measurement of the HG2's:
Measurement of the 30Q's (new cells):
Notes
Those Protected GA's seem to do well for protected cells, least better than I thought. They even out performed the solder top GA's. Could be being brand new, charged slightly higher, and the new Seiko high performing protection circuit, or combination thereof.
The last test of the solder top 30Q's produced the highest amps, even better than the VTC6's. These are also very new 30Q's recently bought from GearBest when they had them in the US warehouse. This may have been the first time used as well.
For the most part, lumens output and amps track pretty well.
Edit: Ooops, typo: lumens taken at 30 secs, not 20 secs
Re: matched cells,
I don’t think the capacities or discharge rates of the cells need to match, only the voltage close enough so they don’t charge each other so fast they heat up. I am sort of planning to use whatever cells I am not using elsewhere, some of the time. It will run off the high discharge ones when in turbo mode and the high internal resistance ones will charge them back up when it is switched off. That won’t give 6,000 lumens, but it beats running on less than four cells.
Technically this is fine, it is the same thing I do when charging cells. I toss them all in the same parallel bank, only thing I worry about is the voltage, the brand, type and model all vary. Never an issue, never had a good cell get hot doing this. They all come off the charger at exactly the same voltage.
that said this can be abused by those that don’t check the voltage so best to put a disclaimer on this setup, only if you know what you are doing.
I personally would never use different capacities or discharge rate cells in one light. Like smoking a cigarette while fueling the car. Way too risky for me.
If I’ve got 4 cells in parallel supplying power to a driver, I want them to all run down in a similar fashion. If I don’t have 4 matched cells, or very close to being matched, I simply won’t use the light until I get 4 new cells in.
I won’t put different brands of tire on my car either, not only same tires on an axle but same tires all around for me. I’ve got well over a million miles behind me and this has never failed me, not gonna change it up now.
So there it is, for the record, the guy with several hundred builds behind him DOES NOT recommend mixing cells. Not different brands, not different capacities, not different voltages within a few hundredths (like 4.20, 4.19, 4.18 maybe… I’d probably toss the 4.18 to single cell use and re-order 4 for a light like this, too high on the amperage pull to mess around).
