Thank you for the review so far, the amp draw is very low, I have a X1 with a boost driver it pulls 7,34A on a rested King Kong 4000 mAh ICR26650 at the tail for 1,47A at the LED. I think it should be pulling at least 5A to get 1A at the LED.
I have already contacted Gearbest and i’m waiting for more info about the driver . It should pull 5-5.5 amps .
Intensity is lower too , something isn’t ok with the driver .
Making not look forward to the delivery of mine now. Hmmmmmmm……
Maybe only mine is/was faulty .
Anyway , if there is an issue it will be solved somehow .
Contact Manker, they have the blueprint.
Gearbest is the shop that sells the lights . That’s the one thing i know , and contact gearbest if you want to know the manufacturer .
I would appreciate if people who get the light report back , thanks .
Trouble is most have no way of measuring output so won’t know if it’s working properly or not
Cool, thanks for reviewing this light.
Measuring the amps at the tail will do.
Mstevens113:Trouble is most have no way of measuring output so won’t know if it’s working properly or not
Exactly
Think I’ll give this one a miss.
Don’t have the equipment to measure output or amps at tail.
We don’t know if any other flashlights have any problem.
We will see…
For reference, and comparison, does anyone know what the stock Manker U21 pulls?
From Tom E ’s review i remember 5.45 amps in turbo .
Ohhhhhh. That’s why those numbers were being quoted. Sorry. I thought that was AFTER he modded it.
No, it's in the review thread OP and I'll stick with stock #'s, etc. for the OP.
"On Turbo, measured 1.08A at the LED (16 AWG patch wire, UT210E clamp meter), and 5.52A at the tail with a EFEST IMR 26650 5200 mAh cell. "
cdjaney:Ohhhhhh. That’s why those numbers were being quoted. Sorry. I thought that was AFTER he modded it.
No, it’s in the review thread OP and I’ll stick with stock #’s, etc. for the OP.
“On Turbo, measured 1.08A at the LED (16 AWG patch wire, UT210E clamp meter), and 5.52A at the tail with a EFEST IMR 26650 5200 mAh cell. ”
Ouch. I really hope giorgoskok’s results aren’t the norm then. Guess I’ll find out tomorrow night when mine arrives. I don’t know how to measure that, but at that much of a difference, I’m sure eyes will tell me when sitting side by side with my U21 (that I was hoping to be able to send back if this could replace it).
So far It’s three out of three that’s low in amp draw :
Meh, just got 2 of them today, 2.45amp and 2.22 amp on the other! Purple Efest 4200, Basen and a Imren IMR 26700 all read the same. Dust particles on/in both reflectors and a smear of shmuck on the inside of the lens on one of them! :person_facepalming:
Seem well built, focused. Don’t like the switch, sets too low for my liking, too much travel a PITA to activate for me any way, FAT fingers!!! Just wish they were cleaner inside, I’ll try blasting the crap out and clean the lens. :rage: Hopefully they will clean up?
2.22Amp, well, it’s even lower than some Xp-G2 flashlight
2.22*4V~9W, with 80% effective, i think the power of led is around 7W, Doubt it is over 1000 lumen
This is what I measured on the Manker U21, CW 1A:
