KD (kaidomain): Deals and new products thread
You said it all, Jerommel. 7 regulators driven by the microcontroller (3 bits/outputs), plus your “magic trigger” to enable the wild bunch…
Cheers ^:)
The 380 mA 7135’s pre-populated on QLites are bad? or generally all 380’s (such as these from Fasttech ) fall out of regulation?
The properties are different. Sorry, don't understand it all, but for example with a 350 7135, you can get down to a PWM value of 2 or 3, while with a 380 you can only go as low as 4 or 5. So the 350's have a better range. I don't think it's as simple as binning them differently. The problem is the 7135 has gone obsolete years ago, so what's on the market now is clones, or clones of clones, so I wouldn't trust the specs you can find, or even the source. TK says there's even differences between 350's, so it's a difficult part to depend on for specs. The ones from FastTech seem to have been consistent. I've had many buys from them over the years, sometimes by the 100, sometimes by 10-50. Also the 350's over perform a little, while the 380's under perform a little, so really there's not much difference. Forgot where but more recently, a few of us were posting about 7135's and pretty much all agreed the 350 were the better ones, and to stay with them. It's what we use now in populating the FET+1 drivers, and the triple drivers.
Maybe this thread should be renamed to "KD Deals and endless esoteric discussion about things not Deal Related that makes you regret your last numerous visits to the thread to hear about the new KD deal and actually is not a deal but a continuation of the endless discussion about some unrelated esoteric concept that should have been taken to a separate thread and then wanting to stab yourself in the head for being so dumb to return to the thread Thread".
That’s a bit long for a topic name though… :stuck_out_tongue:
Pretty esoteric what you did there.
+1 to both! :wink:
I wouldn’t give such a long name to a topic, but ImA4Wheelr’s point of view is right. This is a topic regarding KD Deals and new products thread. That’s why I’ve subscribed, not for “endless esoteric discussion about things not Deal Related”. I also keep on returning to see a new deal, just to get another frustration when I see it’s one more off-topic post.
So… please make a new thread to discuss whatever off-topic (at this thread) you want. :beer:
Hi friends,
Maybe I will create another new thread for listing some common flashlight D.I.Y Parts & Accessories in KD.
Thanks for yours’ supporting to KD.
Thanks
Ban
Hi BanL , i received 2 of this order its bright, i luv it but one was dead on arrival. i only realized it after i spend all the work mounting it and it doesnt work, no light or flash just nothing ,very anticlimax :weary: . i know its rare but its the first time it happened to me. i tried to email but got no reply , is there some sort of guarantee cause i waited some time to do it and there will be more delays from this? Thanks.
Should not be neccessary, what is really needed is stopping the esoteric stuff here.
Btw, thanks for listing the triple DTP-board :slight_smile:
Agreed. Your thread is great the way it is. My post was just a light-hearted attempt to ask folks to let this thread return to it's intended topic.
Hi
Sorry for any inconvenience cause to you.
You can PM me your order number or contact our sales support sales@kaidomain.com
I would help to follow your problem and see how to solve it.
Thanks
Ban
I’m about to order a triple nichia 219BT 5700K 92CRI, can anyone confirm is that triple MCPCB works with the carclo optic?
http://www.kaidomain.com/p/S022933.Triple-Nichia-CRI92-NVSW219BT-V1-5700K-LED-Emitter-with-20mm-x-1mm-DTP-Copper-PCB-Parallel-w-optics
It comes with an optic.
Would a Carclo be significantly better?
I think all the KD triple emitters come with an optic.
Been staring at the KD optic and the pic of the Carclo on Mtn. I can not see any differences, really look identical too me. But I don’t have the KD in hand to check on a Carclo.
Well quality is one thing, but what about dimensions? Is it the same as a Carclo? Otherwise it may not fit well in the S2+ (or some other light).
It fits the S2+ just fine
Good to know, thanks!
It’s 20mm in diameter.
The uniqe difference betwen Carclo and Kaidomain lenses are the diameter of their legs inserts (the part which fits inside MCPCB holes).
KD´s are bigger.
[quote=PH_Oton] Kaidomain-s optics doesn’t fit into Noctigon 3XP MCPCB because 3XP is designet do accept Carclo optics ( narrower “legs”) so I widened leg-openings with Dremel in order to fit “unsuitable” optics [/quote]
