Review : Utorch UT02 Flashlight (XHP35 / 26650 / usb rechargeable)(in progress)
They claim its 1300L, are those ANSI Lumens or just a ball park number? (looks like the latter)
Curious… how much wattage does the XHP35 need to reach 1300 emitter Lumens ?
How is the PWM ?
How did you get the UT01 so quickly?… hope mine comes soon to CA, USA.
I think it only needs 800mA to 1A to reack 1300lm .
Pwm not visible , i’ll try to test with oscilloscope (if i have access this week) .
UT01 was sent with dhl .
It depends on the flux bin, but in this light it would probably take 14-16watts
Again, the Manker U21 specs were basically copy/pasted, so I'd expect what I posted in post #48, assuming they copy/pasted the light .
The 1,345 lumens I measured was at 30 secs in my NIST calibrated PVC light box (ok - PVC light boxes can't be NIST calibrated, but would be nice). I'm pretty confident my PVC light box is in the ballpark from testing 100's of lights in it. The lower modes though are quite a bit off in what I measured.
It sounds like 3 of 3 received so far are doing much lower in amps, much lower in output, so....
I don’t know about KWB’s lights…
Sent him a pm , never got an answer . I really don’t know .
In that case, this is not high flux bin, so it looks like 18-20watts required? Is this why people are saying it’s no less to use an overdriven xpl?
I have seen this khas .
I sent him a pm too .
Can you test if 2 26350 will fit? Without destroying the light of course…
I don’t own any 26350 . But i can measure max length tube & springs allow .
Edit : Max length should be 70 to 71mm with springs fully compressed . Let’s say 70mm to be sure .
It's an electronic switch light with no power tail switch - if you did try the 2 cells, you will give the driver board 8V unless you physically block one end of the cells - tape or something. Hhmm - if you had a 26700 cell to try, but think two 26350's are a little longer.
I have a U21 and do have 26700 cells, and 26350 cells.
Sorry thought I answered your PM, never hit send I guess! :person_facepalming:
Yes both are still 2.5 and 2.25amps no matter what battery I have used, no matter how many times I check, still the same! :smiley:
Still dirty too! :frowning:
I really don’t get y’all, hung up on watts. Watts is an after the fact measurement of amperage and voltage. Watts is misleading, as you can get more lumens with less watts, look at Cree’s Product Configuration tool.
You don’t feed watts to the emitter, you feed amperage (current) at the voltage it will accept. Wattage shows it’s efficiency. Like statistics on a football game, a team can blow away the other team in statistics but lose by a big points spread. It’s the same way with the emitters making lumens. Voltage and current produce lumens, watts is a statistic of how efficiently it’s doing so.
Hi, does it produce 124000kcd or not?
Yes but we know how many lumens are produced by a certain wattage according to the data sheets. Efficiency is correlates to the flux bins given. So they all matter equally the same.
When the emitter is placed into a light and fed by a driver the numbers on the data sheet only show best case scenario. So if a light is using a certain number of watts measured at the tail we can assume only that the light is producing less light than data sheet. It cannot produce more.
So… this light is underperforming. Not a big deal, but there is no other way to spin the data. All that said, we need someone to measure the actual light output:)
Not true.
I can be if someone doesn’t understand wat it means and how to use it (not saying you don’t know it btw :wink: ).
:student:
10 Watts = 10 Watts.
10 volt x 1 amp = 10 watt, 1 volt x 10 amp = 10 watt.
If a emitter is doing 100L/W then you’ll get 1000 lumens. (10x100)
It doesn’t matter if the emitter is a xpl or xhp35. Lets assume they are both doing 100L/W.
Xpl: 3 volt x 3.33 amp = 10 watt x 100 lumens = 1000 lumens.
Xhp35: 12 volt x 0.83 amp = 10 watt x 100 lumens = 1000 lumens.
Point is, without knowing and using those other numbers watt doesn’t say a lot. (for example the lumens/watt efficiency)
But with all those numbers it says everything.
In one thing you are completely right, current is what matters to us. It says a lot about how a led performs, but that’s because we know our leds. (meaning we know what to expect and what it can handle)
But we are going off topic :beer:
Sorry about that.
I see people that read spec sheets and don’t build lights.
For example, what do your sheets say about an XHP-35 at 4.5Amps?
What do the spec sheets say about an MT-G2 at 16Amps?
Or an XP-L W2 2B at 6.67Amps?
your wattage per lumen figure is going to vary according to the current you’re pushing, so you don’t have a fixed number to work with. Just like the amperage is going to change as the cell dies, and the forward voltage will fall. All you really have is a voltage reading and current reading, everything else is playing the numbers. And the numbers are not nice. What’s the board temperature? The cell temperature? Where’s the constant? There’s not one.
This makes it easier to pass on this light. :innocent:
Yes, all these things you mention are not constants. They are variables. Variables make up equations that can be calculated. That is all we are trying to do. With the data reported thus far and as I calculated earlier, this light will not reach 1000 lumens. But we will wait to see. Hoping I’m wrong.
Wait… I somehow missed this. So you are getting similar amp draw as the u21 by changing the sense resistor?
