[Ended]Groupbuy : Utorch UT01 (XP-L , AA & 14500 battery , e-switch etc)
Review sample is here !
More coming soon :slight_smile:
I would like 02 NW.
Thank you.
Finally! Come on now, give us the review, can’t wait! :stuck_out_tongue:
Ordered 02 NW.
Thanks.
Me too!!
If you could start with:
- overall build quality
- output levels
  • power on max on Eneloop/Alkaine (is it about Klarus Mi7 or more like Manker E11)
    I would be very grateful :slight_smile:
Also, if you don’t mind, could you confirm the mode order, and whether or not it has memory? Thanks!
And beamshots!
And tint impressions/comparisons!
And runtimes!
:wink:
Ha ha, I know you’re working on it - looking forward to the review!
The review will be posted tomorrow . But here is a sneak peak :
UI : Ultra low - Low - Medium - High and hidden Strobe - Sos - Beacon mode
From off :
Single click (short) turns light on , on the lowest mode
Longer click turns light on , on the last used mode (not available for ultra low mode , because you can access it with short click)
Double click turns light on strobe (you enter hidden modes)
From on :
If you are in a regular mode :
Single click cycles between (Ultra Low - Low - Medium - High)
Double click and you’re in Strobe
If you are in a hidden mode :
Single click cycles between (Strobe - SOS - Beacon)
Double click and you’re in last used regular mode
Also , max lumens on High , using 14500 should be ~600 (to be confirmed in review) .
Doesn’t fit protected 14500 as some people said .
High quality from a quick view .
So far I like it’s UI, but not the “Doesn’t fit protected 14500” part.
Giorgos, could you compare UT01’s lm/cd output to Mi7’s?
I don’t own a Mi7 . Sorry
Strange! :stuck_out_tongue:
The Mi7s I’ve ordered haven’t arrived yet, else I’d gladly give you one to compare.
The E11 suffers from this too
Thanks for the quick pre-review!
That’s a small bummer - do you have a maximum length of battery that will fit, so I can confirm the fit of batteries I already have?
I completely forgot about this unsupported protected cell and I have no unprotected 14500 around :person_facepalming:
Think about a pair of UR14500P or/& TrustFire IMR14500 (good comments at FT) that I’ve ordered some days ago from KD ($9.38 / $5.31 using code BLF).
Thanks a lot for the first impressions! It tentatively is looking very good.
Is this similar to to the E11 with the battery you are using? Budda suggests that “you’ll need high quality IMR 14500” in his review of the Manker E11, which had considerably higher output, but might be a battery difference:
I’m interested now, 2x NW
Any idea if a T01 copy is coming?
I tested it with Nitecore IMR 14500 but i also have a Efest purple to test tomorrow .
Also the output on AA looks very promising .
what markings does the light have on it ?
Cool!!
How is it with flat top cells? I have efest purple IMR-unprotected that are flat topped.
How is the PWM?
thanks George
