Review : Utorch UT02 Flashlight (XHP35 / 26650 / usb rechargeable)(in progress)
I don’t own any 26350 . But i can measure max length tube & springs allow .
Edit : Max length should be 70 to 71mm with springs fully compressed . Let’s say 70mm to be sure .
It's an electronic switch light with no power tail switch - if you did try the 2 cells, you will give the driver board 8V unless you physically block one end of the cells - tape or something. Hhmm - if you had a 26700 cell to try, but think two 26350's are a little longer.
I have a U21 and do have 26700 cells, and 26350 cells.
Sorry thought I answered your PM, never hit send I guess! :person_facepalming:
Yes both are still 2.5 and 2.25amps no matter what battery I have used, no matter how many times I check, still the same! :smiley:
Still dirty too! :frowning:
I really don’t get y’all, hung up on watts. Watts is an after the fact measurement of amperage and voltage. Watts is misleading, as you can get more lumens with less watts, look at Cree’s Product Configuration tool.
You don’t feed watts to the emitter, you feed amperage (current) at the voltage it will accept. Wattage shows it’s efficiency. Like statistics on a football game, a team can blow away the other team in statistics but lose by a big points spread. It’s the same way with the emitters making lumens. Voltage and current produce lumens, watts is a statistic of how efficiently it’s doing so.
Hi, does it produce 124000kcd or not?
Yes but we know how many lumens are produced by a certain wattage according to the data sheets. Efficiency is correlates to the flux bins given. So they all matter equally the same.
When the emitter is placed into a light and fed by a driver the numbers on the data sheet only show best case scenario. So if a light is using a certain number of watts measured at the tail we can assume only that the light is producing less light than data sheet. It cannot produce more.
So… this light is underperforming. Not a big deal, but there is no other way to spin the data. All that said, we need someone to measure the actual light output:)
Not true.
I can be if someone doesn’t understand wat it means and how to use it (not saying you don’t know it btw :wink: ).
:student:
10 Watts = 10 Watts.
10 volt x 1 amp = 10 watt, 1 volt x 10 amp = 10 watt.
If a emitter is doing 100L/W then you’ll get 1000 lumens. (10x100)
It doesn’t matter if the emitter is a xpl or xhp35. Lets assume they are both doing 100L/W.
Xpl: 3 volt x 3.33 amp = 10 watt x 100 lumens = 1000 lumens.
Xhp35: 12 volt x 0.83 amp = 10 watt x 100 lumens = 1000 lumens.
Point is, without knowing and using those other numbers watt doesn’t say a lot. (for example the lumens/watt efficiency)
But with all those numbers it says everything.
In one thing you are completely right, current is what matters to us. It says a lot about how a led performs, but that’s because we know our leds. (meaning we know what to expect and what it can handle)
But we are going off topic :beer:
Sorry about that.
I see people that read spec sheets and don’t build lights.
For example, what do your sheets say about an XHP-35 at 4.5Amps?
What do the spec sheets say about an MT-G2 at 16Amps?
Or an XP-L W2 2B at 6.67Amps?
your wattage per lumen figure is going to vary according to the current you’re pushing, so you don’t have a fixed number to work with. Just like the amperage is going to change as the cell dies, and the forward voltage will fall. All you really have is a voltage reading and current reading, everything else is playing the numbers. And the numbers are not nice. What’s the board temperature? The cell temperature? Where’s the constant? There’s not one.
This makes it easier to pass on this light. :innocent:
Yes, all these things you mention are not constants. They are variables. Variables make up equations that can be calculated. That is all we are trying to do. With the data reported thus far and as I calculated earlier, this light will not reach 1000 lumens. But we will wait to see. Hoping I’m wrong.
Wait… I somehow missed this. So you are getting similar amp draw as the u21 by changing the sense resistor?
Giorgio, could you please downsize the pictures in your review?
Those huge sizes are quite pointless, they’re not even sharp enough for that many pixels.
Thanks.
O uhm… Nice light! Looks good. :+1:
But 1300 LM can be obtained with an XP-L too and then you don’t need a boost driver…
I think the efficacy with an XHP35 is much higher than with an XPL. Secondly, output is also more constant.
Pictures are fine from PC .
I have 4 XHP-35 E4 in my TM16. Each one is seeing 1.14A at some 13.1V making 1768 lumens. Collectively, the 4 are seeing 4.55A in parallel and making 7072 lumens.
Edit: The above said for the statisticians. Perhaps it will help figure the variables. It does seem like this light is not running very hard at all and should be doing more. (UT02, I mean)
Yes they are fine, but they’re also a couple of MB and not worth the huge size.
Takes very long to load with the number of pictures on page 1.
1000 pixels width would be more than enough.
Could be a little higher, but you lose efficiency because you need the boost driver.
That’s the advantage of a boost driver. :slight_smile:
I have set the pictures based on the width of the page . Works best in most devices .
If i set them based on pixels they will not show properly on smartphones etc . Anyway , i will reduce the pictures’ relative width .
I am curious what different efficiency values different types of drivers have. I also read that modern boost drivers are much more efficient… If I look at the runtime graph of the U21, I’m pretty pleased.
That doesn’t matter.
You have used a lot of pictures of several megabytes each.
Setting the % page width doesn’t matter, it takes unnecessarily long to load anyway, because the files are huge and many in number.
You should scale them down on your PC first before uploading.
