I have set the pictures based on the width of the page . Works best in most devices .
If i set them based on pixels they will not show properly on smartphones etc . Anyway , i will reduce the pictures’ relative width .
I am curious what different efficiency values different types of drivers have. I also read that modern boost drivers are much more efficient… If I look at the runtime graph of the U21, I’m pretty pleased.
That doesn’t matter.
You have used a lot of pictures of several megabytes each.
Setting the % page width doesn’t matter, it takes unnecessarily long to load anyway, because the files are huge and many in number.
You should scale them down on your PC first before uploading.
Good point, because i forgot that a linear driver just turns the surplus Voltage to heat = waste.
But in this case the voltage has to be quadrupled (that’s 4x) approximately, which is usually not that efficient.
A.f.a.i.k. boost and buck conversion works much more efficient when it’s within about 20% difference between input and output.
Peak output being at 2.5A which occurs with 14.4V, or thereabouts, voltage is a bit more than tripled, not quadrupled, but still… the constant current style puts a heavy load on a dying cell by maintaining voltage at the cost of ever increasing amperage draw from the dying cell. Sounds problematic to me, considering that a hot cell can be a bomb. Factor in weak, cheap, and/or inferior components on the driver to save every fraction of a cent and it’s not a likely candidate for bumping power to for just anyone.
xhp35 has 2 versions 6v and 12v, if you are measuring from led 12v versions current will be half of 6v version. Measure voltage please if you’re measuring from led
I have 2 of these beauties, lucky me, here are the amp reads thru the 5 levels, for one of them, the other is slightly lower, 2.25amp. UNI-T meter and a Purple Efest 3500 off the charger! Pics of the dirty reflectors too!
Is the sense resistor the same value as the manner u21? If so, then there is really something weird going on.
If not they may have just used the wrong resistor?
