I’ve got to say that I’m absolutely giddy with delight over the idea that if TF gets this right (*crosses fingers AND toes), I’ll be wielding a pair of bada$$ lights at a superbly economical price. Thank you to everyone involved with getting this thing happening!
I wonder what the TF price will be after this initial group buy if it’s made per the specs on the first page. It seems like it will stack up against lights costing easily three or four times as much.
Seems so simple doesn’t it? All they have to do is build the driver exactly as it was designed and tested and they have a serious top shelf winner on their hands. Don’t follow the recipe, they just have a mess.
I work with many Chinese shop owners and the one thing I notice for 110% certainty is they are extremely tight as all mighty penny-wise. An example is asking for credit for literally 1/2 a bottle of fizzy drink - because the boxes come in 15’s, and 7 were leaking. I said I would credit half a box…… meaning the 7 damaged…. but he took me literally and demanded 7.5 were credited :person_facepalming:
We are all hoping for that driver to be to 100% spec but I’ll be honest I’m getting a little apprehensive now. Obviously I know not of what’s going on behind the scenes. But I think 8 months is pushing the boat out……
Adding latest battery tests, including the protected GA's just received last night, the LG2's with solder tops, and 30Q's solder tops to make the comparison with the LG2's
Measurement of the Protected GA's:
Measurement of the HG2's:
Measurement of the 30Q's (new cells):
Notes
Those Protected GA's seem to do well for protected cells, least better than I thought. They even out performed the solder top GA's. Could be being brand new, charged slightly higher, and the new Seiko high performing protection circuit, or combination thereof.
The last test of the solder top 30Q's produced the highest amps, even better than the VTC6's. These are also very new 30Q's recently bought from GearBest when they had them in the US warehouse. This may have been the first time used as well.
For the most part, lumens output and amps track pretty well.
Edit: Ooops, typo: lumens taken at 30 secs, not 20 secs
Re: matched cells,
I don’t think the capacities or discharge rates of the cells need to match, only the voltage close enough so they don’t charge each other so fast they heat up. I am sort of planning to use whatever cells I am not using elsewhere, some of the time. It will run off the high discharge ones when in turbo mode and the high internal resistance ones will charge them back up when it is switched off. That won’t give 6,000 lumens, but it beats running on less than four cells.
Technically this is fine, it is the same thing I do when charging cells. I toss them all in the same parallel bank, only thing I worry about is the voltage, the brand, type and model all vary. Never an issue, never had a good cell get hot doing this. They all come off the charger at exactly the same voltage.
that said this can be abused by those that don’t check the voltage so best to put a disclaimer on this setup, only if you know what you are doing.
I personally would never use different capacities or discharge rate cells in one light. Like smoking a cigarette while fueling the car. Way too risky for me.
If I’ve got 4 cells in parallel supplying power to a driver, I want them to all run down in a similar fashion. If I don’t have 4 matched cells, or very close to being matched, I simply won’t use the light until I get 4 new cells in.
I won’t put different brands of tire on my car either, not only same tires on an axle but same tires all around for me. I’ve got well over a million miles behind me and this has never failed me, not gonna change it up now.
So there it is, for the record, the guy with several hundred builds behind him DOES NOT recommend mixing cells. Not different brands, not different capacities, not different voltages within a few hundredths (like 4.20, 4.19, 4.18 maybe… I’d probably toss the 4.18 to single cell use and re-order 4 for a light like this, too high on the amperage pull to mess around).
Different tires works too, but only if you know what you are doing and don’t slip up. I had a Fiat 850 in Europe and found cheep snow tires for it, but they were over-size and cross bias. So I drove this rear-heavy car with radials in front and cross bias in back. It worked, since I didn’t ever forget and drive it like a normal handling car.
I have not had 2 matching tires on my 4runner in, well since I got it come to think of it. Not by choice, I just could not bring myself to waste tires that still had tread and now that they don’t I can’t afford new tires lol.
you are not doing it right until you are Driving around with steel belts showing :student:
Tom helped me out in a huge way and got one of his lights to me in time for my Brother-in-Law’s birthday. This is a Narsil firmware SupFire M6, light pipe beacon off the driver and with all the modifications… I got Josh’s wife to record him when he opened the package. He is 28 now, the look on his face seeing the light, knowing what it was after having seen my own M6 a couple of weeks earlier, he was stunned, in awe, and his wife giggled behind the camera as he exclaimed and oohed and ahhed. I spoke with him on the phone later and he said he was outside, after dark, actually talking to my wife on the phone (his sister) when His wife fired up the M6 from an upstairs balcony and lit up his backyard like daylight! He was just absolutely amazed. I told him he had another surprise in store for him… he’d only seen it with the new cells fresh out of the box… I suggested he charge the cells and check it out tonight! (if he was blown away with it on nearly dead as-shipped cells, he’s gonna pass out when he sees it running on full power!)
Thank you Tom, very much appreciate your help in getting this to me so fast. Josh can’t believe his new flashlight has a 4 page operating manual!
Edit: Of course I told him about the upcoming Q8, he’ll have to get a few for his friends after they see this M6 he just got. He was quizzing me on how he could get more, he knows of 6 or 7 people that are gonna HAVE to have one after they see his…
