12/11 added Medium mode (on AA) runtime
12/11 added Intensity measurements
12/19 added Lumens using Nihm and how to program output levels
Waiting for the updates and your overall impression Giorgos.
Please specify if you can the max battery length that can fit in it.
Overall impression is really good Very small light , capable of great output , for a small time of course ( limitations are : the capacity of the cells and of course the small mass of all the lights of that size )
Edit : longer cell i have is 50,6mm and works fine .
Very nice, thanks for the detailed review!
Any idea on parasitic drain from the e-switch?
“_High (Efest 14500) : 42 minutes (until first “LVP” warning)
When battery voltage is below 3V drops to the lowest mode
High (Eneloop AA) : 55 minutes (until shutdown)
When battery voltage is equal or below 1V shuts down_”
Is it common for the LVP to keep on draining an unprotected Lithium Ion battery while a NiMh cell is simply shut down via the same LVP?
Thanks for the review! A few questions for you:
- is there a lock-out feature, so that it won’t turn on in a pocket?
- can you give us just a brief qualitative description of the mode spacing both with a nimh and a 14500?
- does it seem to have fairly flat regulation (output remains fairly constant) or does it dim gradually?
- how slowly do you have to single-click to change modes, without accidentally engaging the strobe modes?
How much PWM with this one? I would also like to know if it has a lockout mode.
Thanks Matt
Syrbuff has a youtube review on this light.
sb56637 , as i mentioned on the review it it 0,014mA .
Freedom , it is designed from the factory like that i guess .
peteybaby , No there isn’t lock out mode . It has a fairly good regulation , no visible dimming , until battery is not able to provide the required current of course . Only if you press the switch for a second time exactly after you release the switch it enters strobe .
mattlward , i will measure PWM frequency tonight .
Thank you George.
No lockout mode? I thought the light would lockout if the head is half turned?
Yes , this is phusical lockout (if light has anodized threads , as ut01 has).
Thank you for all the info giorgoskok.
Would you know the lumen values for the different modes?
I might get a couple more while the price is good, if the spacing is to my liking.
Thanks
I’ll give you an estimation :
Lowest - 10-25 lm
Low - 70 lm
Medium - 270 lm
High - 775 lm
A little bit disappointed,
OP updated with runtime for Medium mode , with AA .
Why , if i may ask ?
Just saw your edit.
Since a 50.6mm cell fits & works, I don’t see why a 50.5mm protected XTAR 14500 wouldn’t.
Do you have any XTAR 14500s (or any other 14500 protected of about that size) to check if they fit?
I have the same cell you mentioned (xtar 14500 protected) , and it’s actually longer (50.9mm - 51mm) and it doesn’t work .
Can you just remove the protective pcb to make it fit?
I have several of those in transit to my place.
