Review : Utorch UT01 Flashlight (XP-L V6 / AA & 14500 / e-switch)
383 posts / 0 new
giorgoskok
giorgoskok's picture
Last seen: 4 days 14 hours ago
Utorch UT01 LED Flashlight – 800Lm Cree XPL Memory Function
Groupbuy here : Click!
Utilizing latest CREE XP-L LED, the UT01 provides an incredible illumination that is up to 800Lm on single 14500 battery, is also compatible with AA battery. Side switch offers one-handed operation and allows you to select from 4 constant outputs with ease. Precision reflecting system ensures powerful lighting in illumination and distance. it’s small but bright, simple but functional, well-built and incredibly lite weight!
Overview :
Brand: Utorch
Model: UT01
Lamp Beads: Cree XP-L
Emitters Quantity: 1
Lumens Range: 500-1000Lumens
Luminous Flux: 800Lm (14500) / 400Lm (AA)
Color Temperature: 6500K (1A) / 5000K (3D)
Feature: Cooling Slot of High Efficiency,Lanyard,Lightweight,Pocket Clip
Function: Camping,EDC,Hiking,Household Use,Night Riding,Walking
Switch Type: Clicky
Switch Location: Side Switch
Mode: 4Mode (High > Middle > Low > Lower)
Battery Type: 14500,AA
Battery Quantity: 1 x AA / 14500 battery (not included)
Mode Memory: Yes
Waterproof Standard: IPX-8 Standard Waterproof
First Look :
Package Contents:
1 x Utorch UT01 LED Flashlight
1 x Lanyard
1 x Clip
1 x O-ring
1 x English Manual
Extended View :
Flashlight :
UT01 length : 84mm
Max UT01 diameter : 22mm
Utorch logo & e-switch close-up :
Back side , nice knurling :
Square anodized threads & tailcap :
Tailcap :
Head & Reflector , note the AR coated glass too :
Driver is 17mm , press fited in the head (not glued probably). It has a small brass “post” , not a spring .
Beamshots :
CW :
NW (nice tint , not green) :
How it works (&modes) :
UI : Ultra low – Low – Medium – High and hidden Strobe – Sos – Beacon mode
From off :
Single click (short) turns light on , on the lowest mode
Longer click turns light on , on the last used mode (not available for ultra low mode , because you can access it with short click)
Double click turns light on strobe (you enter hidden modes)
From on :
If you are in a regular mode :
Single click cycles between (Ultra Low – Low – Medium – High)
Double click and you’re in Strobe
If you are in a hidden mode :
Single click cycles between (Strobe – SOS – Beacon)
Double click and you’re in last used regular mode
Measurements :
Doesn’t fit protected 14500 batteries
Stand-by current (parasitic drain) : 0,014mA
Efest IMR 14500 V2 650mAh :
Amperage Draw :
Lowest – 24.3 mA
Low – 133mA
Medium – 0.60A
High – 2.01A
Lumens on High : 775
Intenisty : 2197cd
Nitecore IMR 14500 (NI14500A) 650mAh :
Amperage Draw :
Lowest – 24.2 mA
Low – 132.8mA
Medium – 0.60A
High – 1.90A
Lumens on High : 735
Eneloop AA 2000mAh :
Amperage Draw :
Lowest –
Low –
Medium –
High – 4.2A to 3.3A
Lumens on High : 360
Intensity : 1648 cd
Runtimes :
Actual tested Runtimes (will be updated as i test in more modes) :
High (Efest 14500) : 42 minutes (until first “LVP” warning)
When battery voltage is below 3V drops to the lowest mode
High (Eneloop AA) : 55 minutes (until shutdown)
Medium (Eneloop AA) : 1hr 40 minutes (until shutdown)
When battery voltage is equal or below 1V shuts down
Light has programmable output levels for every mode . Here is a how-to :
1) Open the flashlight , navigate on the highest mode , and turn off the light
2) Press the button until it blinks two times (it will open in highest mode , and flash 2 times after 7-8 seconds)
3) After it blinks twice , release the switch and double click again (It will enter strobe , beacon etc and a constant current output level & regular modes )
4) Now navigate with single (short) click to the lowest mode
5) It will ramp through 3 different output levels . Single click confirms selected output level of mode and goes to the next one
6) Do the same for all the modes , and when you are in strobe turn off the light with a “long” click .
Updates will come for more runtimes and measurements (post #2 update log)
Edited by: giorgoskok on 02/18/2017 - 05:19
giorgoskok
12/11 added Medium mode (on AA) runtime
12/11 added Intensity measurements
12/19 added Lumens using Nihm and how to program output levels
evankouros
evankouros's picture
Last seen: 6 days 24 min ago
Waiting for the updates and your overall impression Giorgos. Smile
Please specify if you can the max battery length that can fit in it.
giorgoskok
Overall impression is really good Smile Very small light , capable of great output , for a small time of course ( limitations are : the capacity of the cells and of course the small mass of all the lights of that size )
Edit : longer cell i have is 50,6mm and works fine .
sb56637
sb56637's picture
Last seen: 16 min 26 sec ago
Very nice, thanks for the detailed review!
Any idea on parasitic drain from the e-switch?
Freedom
Freedom's picture
Last seen: 1 year 1 month ago
“_High (Efest 14500) : 42 minutes (until first “LVP” warning)
When battery voltage is equal or below 1V shuts down_”
Is it common for the LVP to keep on draining an unprotected Lithium Ion battery while a NiMh cell is simply shut down via the same LVP?
Domari Nolo “I Refuse to be Subjugated” (1st Pennsylvania Regiment Flag) https://www.1stcontinentalregiment.org/blank
(Flagguys.com):..and man o man did they ever refuse to be subjugated. These guys were everywhere. They were important in Washington’s siege of Boston. They stayed behind and were the last to leave after covering the main army’s dangerous nick of time retreat from Long Island. They crossed the Delaware with Washington. They were “..at Brandywine, Germantown, Monmouth, and every major skirmish, and battle all the way to Yorktown..” where they fought “the most important part of the siege” according to General Steuben. These guys saw action in every one of the original 13 colonies.
peteybaby
peteybaby's picture
Last seen: 1 hour 35 min ago
Thanks for the review! A few questions for you:
  • is there a lock-out feature, so that it won’t turn on in a pocket?
  • can you give us just a brief qualitative description of the mode spacing both with a nimh and a 14500?
  • does it seem to have fairly flat regulation (output remains fairly constant) or does it dim gradually?
  • how slowly do you have to single-click to change modes, without accidentally engaging the strobe modes?
mattlward
mattlward's picture
Last seen: 13 hours 52 min ago
How much PWM with this one? I would also like to know if it has a lockout mode.
Thanks Matt
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
arow55
Last seen: 4 days 3 hours ago
Syrbuff has a youtube review on this light.
giorgoskok
sb56637 , as i mentioned on the review it it 0,014mA .
Freedom , it is designed from the factory like that i guess .
peteybaby , No there isn’t lock out mode . It has a fairly good regulation , no visible dimming , until battery is not able to provide the required current of course . Only if you press the switch for a second time exactly after you release the switch it enters strobe .
mattlward , i will measure PWM frequency tonight .
peteybaby
peteybaby's picture
Thank you George.
agent80
Last seen: 28 min 34 sec ago
No lockout mode? I thought the light would lockout if the head is half turned?
giorgoskok
Yes , this is phusical lockout (if light has anodized threads , as ut01 has).
cdjaney
cdjaney's picture
Last seen: 7 months 1 week ago
Thank you for all the info giorgoskok.
John 1:5 "The Light shines in the darkness, and the darkness did not comprehend it."
strongest2004
strongest2004's picture
Would you know the lumen values for the different modes?
I might get a couple more while the price is good, if the spacing is to my liking.
Thanks
Low mode and long runtime lover…
giorgoskok
I’ll give you an estimation :
Lowest – 10-25 lm
Low – 70 lm
Medium – 270 lm
High – 775 lm
mrheosuper
Last seen: 5 days 19 hours ago
A little bit disappointed, Sad
Forgot my pen
giorgoskok
OP updated with runtime for Medium mode , with AA .
Why , if i may ask ?
evankouros
Just saw your edit.
Since a 50.6mm cell fits & works, I don’t see why a 50.5mm protected XTAR 14500 wouldn’t. Wink
Do you have any XTAR 14500s (or any other 14500 protected of about that size) to check if they fit?
giorgoskok
I have the same cell you mentioned (xtar 14500 protected) , and it’s actually longer (50.9mm – 51mm) and it doesn’t work .
MAD TM26
MAD TM26's picture
Last seen: 10 months 4 weeks ago
Can you just remove the protective pcb to make it fit?
I have several of those in transit to my place.
we buy light for a brighter tomorrow
giorgoskok
Battery’s pcb ? Yes (but not really good solution)
Trevi_lux
Trevi_lux's picture
Last seen: 11 months 3 weeks ago
How about clip? I have a similar light with a similar clip, and I can not insert easy, is very closed for the flashlight
Regards
giorgoskok
Clip is really hard to insert too.
giorgoskok
Trevi_lux
Trevi_lux's picture
Thumbs Up Thanks for confirm. I any case, great light for 14500 unprotected and awesome for NiMH.
Regards
BLightSam
Extended View :
Flashlight :
UT02 length : 84mm
Max UT02 diameter : 22mm
UT01 ?
Threadneedle
Threadneedle's picture
Last seen: 2 weeks 6 days ago
Thanks for saying this – https://www.youtube.com/watch?v=PQHn1BFt-u0
The user manual is a complete photocopy of the Manker E11’s, just without the Manker logo.
Without trying to sound too controversial, may I ask if this torch, and the UT02, have been copied out of spite for Manker?
Btw, thanks for the review, giorgoskok. I’m now going to buy more than one.
giorgoskok
BLightSam wrote:
Extended View :
Flashlight :
UT02 length : 84mm
UT01 ?
Sorry , UT01 i meant .
evankouros
So, only 0.3-0.4mm length difference makes such a damage... Sad
I guess that there might be even some IMRs that won't fit then.
Anyway, I've ordered a pair of 49.5mm UR14500P and a pair of 50mm TF IMR14500, so I will have 14500s that fit, but... do you think that there might be a problem with flat-top cells? Will the UT01 work with these?
giorgoskok
evankouros wrote:
So, only 0.3-0.4mm length difference makes such a damage… Sad
I guess that there might be even some IMRs that won’t fit then.
Anyway, I’ve ordered a pair of 49.5mm UR14500P and a pair of 50mm TF IMR14500, so I will have 14500s that fit, but… do you think that there might be a problem with flat-top cells? Will the UT01 work with these?
They will fit.
Most IMR without button top work ok
