Brinyte B158 mod thread
281 posts / 0 new
MRsDNF
MRsDNF's picture
Last seen: 3 hours 15 min ago
I reckon they used these and they are 18mm OD.
https://www.fasttech.com/products/0/10001999/1250000-copper-17mm-to-17mm...
I could check tomorrow if you like.
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
kiriba-ru
kiriba-ru's picture
Last seen: 1 hour 40 min ago
Driver size on stock brass pil is 17.9mm.
Lund1660
Last seen: 3 hours 29 min ago
I ordered three extra pills they came with retaining rings. I took a dremal to the wire holes they were a little sharp. Iam waiting for drivers and Led’s from mountain electronics.
luminarium iaculator
luminarium iaculator's picture
Last seen: 6 hours 10 min ago
Mike C,
There is no need for retaining ring when it can be easily soldered to pill… Totally unnecessary part.
Well it is necessary in their design… :
Modding is making something how you want it to be, not how it comes stock...
Old-Lumens
Mike C
Mike C's picture
Last seen: 1 day 4 hours ago
Thanks for the info all. My hosts have arrived with DHL, but I won’t be able to pick them up until I’m home again on Friday.
I won’t need the ring or need to solder. I just need to change the diameter of my drivers if they are too small. I like to press fit drivers rather than solder, makes replacing them in the future much easier.
Please report when you’ll have time…
Old-Lumens
Mike C
Mike C's picture
I got my hosts now… I made a dedicated thread instead of posting in this thread: http://budgetlightforum.com/node/48112
Mstevens113
Mstevens113's picture
Last seen: 9 hours 31 min ago
Subscribed, some interesting ideas forming in my head… Crazy
vidramon
Last seen: 10 hours 52 min ago
I see a lot of people use this light with dedomed XP-G2, but does someone try to use this lamp and dedome a original LED ( U4 ) in it ?
If yes how it operate relative to original LED with dome ?
gchart
gchart's picture
Last seen: 4 hours 54 min ago
I’ve tried it that way, but didn’t leave it. The LED that comes in it (an XM-L2) tightens up and warms up nicely when dedomed. But ultimately, the XP-G2 has a smaller surface area, so it’s beam is even tighter (when also dedomed). I don’t have pictures of the B158 with the dedomed XM-L2, but these pics with a few UF-1504’s (and a B158) side-by-side should provide a nice comparison.
A side note… the original LED comes on an aluminum PCB. If you’re going to drive it harder (say, with a FET driver), you want a copper DTP board. But if you leave the original driver, the aluminum board is fine.
vidramon
No, I just asking about dedome a led, nothing else I don’t want to experiment for now.
I have HI V3 and U4 version and I like more HI V3 because beam is narrowed and it can reach more distance.
Hmm it is strange, so if I understand well you only dedome a led and do nothing more, and lamp warms up more than before you dedome it ?
Rufusbduck
Rufusbduck's picture
Last seen: 6 months 3 weeks ago
Yes, dedoming alters the tint.
Scott
Boaz
Boaz's picture
Last seen: 1 day 9 hours ago
warm meaning a warmer tint ,,,, not hotter temperature … cool white neutral white warm white
vidramon
I don’t think so, he never mentioned colour temperature of the led.
As far as I understand lamp is warmer when led is dedomed.
gchart
gchart's picture
Haha… It’s like the others said. Color temperature is affected by dedoming. Doing so has no affect on the actual temperature (heat)
vidramon
OMG Facepalm
I read some posts where people dedome a led, and I have never read that flashlight was hotter after that so I found it strange when you say that, but obviously I did not understand well.
It is not important to me if colour temperature changes, only thing that I want to know is a beam of the light narrowed and can it gain more throw ?
With U4 when full zoom there is nothing but clear hotspot ( square ), and with HI V3 there is a ring around hotspot ( square ). Is this also a case when you dedome a U4 do you remember ?
vidramon
FacepalmCrying
Why are you crying? If you are white wall hunter just buy reflector light and enjoy on a nice wall beam pattern.
Aspheric beam mostly has those ringy imperfections around die. They can be eliminated… If you want pure square beam than use black oven paint or similar and apply lightly and precise.
I even enhance reflection around sqare (flood) in my builds and while it ain’t look nice on a wall I really don’t care for that. I really care how it throws at nigth an if I can get usable flood out of it.
There are even reflector – aspheric flashlight combinations out there with even more ringy beam like this:
Old-Lumens
vidramon
This from your picture looks awesome Cool
I cry because that pic is result of ‘‘dedoming’‘ a led, if it can be called dedome, because I screwed up.
Original led was clear and without anything just pure little square, also a fabric V3 HI is clean and pure, and then look at my result Sad
There is visible some marks like + and dot also too many residues from the dome, it look pretty ugly. When I watched on YT about dedoming it was easy and fast, but in my case not at all.
LightRider
LightRider's picture
Last seen: 4 days 7 hours ago
Those are just common reflections. The dome blocks those reflections. After dodo mint it is normal. Your dedome doesn’t look bad at all shining on the wall.
vidramon
Does this stock driver in b158 ( nanjg 105C ) work well if I replace HI V3 with XHP35 HI ?
Something like THIS ?
sac02
sac02's picture
Last seen: 4 days 5 hours ago
XHP-35 are all 12V, so I do not think so without an appropriate boost driver.
There are a few boost drivers but none that I have seen in 17mm size.
Here is a 22mm on KD. Or Google search LD-51 driver.
Also TaskLED has a couple options but they are large and very expensive ($40 USD).
vidramon
Does any of you try a XHP35 HI in this light ?
I have one body and want to try XHP35 HI in it, but I’m curious does anyone try it yet ?
Mike C
Mike C's picture
Did you read the post just above yours? Finding a suitable driver for a 12V LED in a B158 is apparently not so easy.
vidramon
Ok, no problem, I just aks if someone managed to find it or to make it and to try it, I want to know how it will work.
Jerommel
Jerommel's picture
Last seen: 1 month 5 days ago
Should have known about this thread before!
On page one there’s the problem of the floating driver board, which in my case caused flickering.
So i did the obvious:
Double (but a little thin) springs upside down.
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
sac02
sac02's picture
I see a copper wire around the neck of the pill – is that a spacer to get the pill closer to the lens (for wider flood I assume)?
How does it affect the tightness/focusing of the spot?
Jerommel
Jerommel's picture
Yes, you assumed correctly. Smile
It doesn’t affect the focussing zoomed in, the head stops at the LED shelf of the pill, it moves past the copper ring (1.8mm diameter wire).
Planning on adding a bit more, because i like it when you can zoom out as far as possible and have a wide flood.
Jerommel
Jerommel's picture
Speaking of zoomed in and focussing, i replaced the 1mm thick copper DTP MCPCB with a 1.6 mm thick one (Noctigon) so that it does no longer “over-zoom” but stops at focal distance of the lens.
So in all zoomed out has the lens now 1.8 + 0.6 = 2.4 mm closer to the LED than how i bought it.
(changed the switch too, it’s a reverse clicky now, and recessed the boot a bit so it can tailstand better)
zipelgas
zipelgas's picture
Last seen: 7 hours 34 min ago
Just wanted to share me slim edition mod. I very happy how it turned out..
Overkill is just about enough!
