Review : Utorch UT01 Flashlight (XP-L V6 / AA & 14500 / e-switch)
Cool thanks for the review!!
Can’t wait for mine. Shipping is REALLY slow.
Mine is stuck…
“Awaiting International flight - Airline Inspection” since 12/7.
Hopefully its just a laggy tracking update.
EDIT: Sorry…wrong thread.
Trying to decide between this and the Klarus Mi7. What are people’s thoughts on how they compare?
I was trying to make that same decision. What clinched it for me was that I want my light to come on in the lowest mode every time, and be able to cycle up through the higher modes, which the UT01 can do.
The UT01 is brighter (with Eneloops) and you can buy it in NW. Easy decision :wink:
no firefly or moonlight mode?
wle
Ordered NW and on the way- thanks
I had the MI7 and the Manker E11 (the Original of this clone) and kept the Manker. Both are excellent AA/14500 lights with lots of power, but the beam pattern is completely different. MI7 has XP-L Hi and is more like a little thrower (tight bright spot and much darker spill) , and it´s only available in cold white. The Manker on thr other side is much floodier, which I prefer as an EDC that is also used indoors. Plus it´s available in neutral white.
K.
Very helpful comparison, thanks for sharing!
+1 @Andyman. ;)
Thanks for the info Kusie. :THUMBS-UP:
I’m convinced. Ordered NW :slight_smile:
In the UI description I’m missing the “shut down” (off). I guess a longer press will do?
Exactly
This mirrors my opinion.
If tube almost like another one, i guess it will fit in.
I using XTAR 14500 for T01.
OK, I’ll bite…are you contradicting post #20 and referring to post #19?
If so, many thanks for sharing your opinion (I would order at least one more if this were true).
Curious….
How does it draw 2.01A from a 650 mah Efest 14500 purple IMR… and achieve a 45 minute run time?
650 / 2010 = 32 min
Where are the extra amphours coming from?
Obviously it can’t draw the same Amperes all time it’s running.
Exactly . I said runtime until LVP kicks in …
OK cool thanks!! Can’t wait to get mine. I am thinking about ordering the Manker version too.
