I really like the aesthetics of this light, but it’s not a good go-to because of the integrated shelf design which makes it harder to mod. I vastly prefer a removable pill design, making it easier to disassemble, modify, replace emitter, etc. This design also makes the connection with a good spacer for a triple build worse than a brass-pill design.
My personal favorite is the Convoy S6, which has the removable pill, sleek design, and no branding:
…Just found my post here from back when I found my S3 wasn’t as described…
the reason i ended up with S3 and not S2/+ is because mtnelectronics only sells the fat copper spacer for a triple LED conversion for the S3 so that summed it up right there (Because who doesn’t like a 10+ amp 3k+ lumen 1 cell flashlight?)
Just fell in love with the F8! that one in matte black (flat black) would be awesome.
yeah, the integrated head would mean everything you craft has to be an exact fit and you’d have to mod/build/solder inside the cavity. It is feasible in the C8 because it is a bigger light (everything worked on my second attempt) but since the S3 is smaller I’d have to see it in person. with enough time and patience everything can be done though.
Took a better look at the S3 Host. Appears it now has the Flat Black finish as on the newer production models. I like that. But no pocket clip groove… don’t know why not. I would never “deep pocket” an 18650 light. Maybe a clip on a pocket.
I just bought it to try something different than the S2 or S2+ I have too many of already. Wanted to get an S4 before they are NLA. Maybe I should have gone S4 just to have one. My S3 Host is not at the top of my build list.
Idk if the integrated head really makes that much of a difference here. The pill is a lot of mass — in fact that extra mass is a big draw for me — and has quite a few threads into the head. On a triple mod, an S2+ can be scalding hot in under 30 seconds, depending what you put in it. I almost prefer slower thermal response to protect my hand.
True. I’m really surprised Convoy hasn’t made that metal clicker switch available as an accessory or upgrade for their other lights, considering how popular it is. They’d sell a ton.
Hehe, the integrated shelf is the only reason why I chose the S3 for my triple. I made it dual switch. With a pill that would have been way too much work.
