GearBest CS does answer, takes about 24 hrs for a response.
In my case they offered $5 store credit and 15 reward points (50 points=$1) which I accepted….easier than pursuing a return and replace, and it is super bright in turbo mode (w/tail cap unscrewed). I was hoping they would just send out another light.
If you get a properly working M3 as most here have, it is a true bargain compared to the Olight look alike.
The above was never answered. From what I understand, the included battery is not an IMR.
I placed my order for the M3 1A last evening. I have little to no experience with LiIon batteries, so I'd like to also know the answers. Since the M3 itself has all the built-in protections, would there be any benefits to using an unprotected IMR in it? Would an IMR give any extra brightness? Would an ICR be better for this light, and give longer runtime per charge?
The included 16340 was similar in output to the Klarus 16340. Surprisingly the light was much dimmer with a Fenix 16340.
I measured the M3 with 725lumens in a DIY sphere, so it is a very bright 16340 flashlight. I guess only the nitecore EC11 with the IMR cell is brighter
This thread is 6 months old. I wanted to bring it back up to see if anyone that has the M3 has good/bad opinions on it now that they’ve been using it for a while. I just ordered a Utorch UT01 but also have had my eye on the OTR M3.
Yeah, I saw the EFEST ones on imrbatteries.com as well, but the button-tops are out of stock, and I’m not sure if the flat-tops would work with this light.
I just ordered the OTR M3 with 5C tint. I was going back and forth between 1A and 5C… I guess I will be losing a bit of output with 5C, but I’ve seen people speak highly of this 5C tint on the M3, so I thought I’d give it a try. I’m hoping I can just attach it to my baseball cap and use as a walking light.
I suspect they are the same cell under the label, but not sure. Dunno - the IMREN's do better than my EFEST's but the EFEST's are older, so hard to say.
The 850 mAh capacity protected EFEST may do well in the stock light, but not sure if it fits.
I like this flashlight a lot - it's perfect as a travel light. The low voltage indicator is a really nice touch too. But it's well made, and I like that you can pull it apart fairly easily.
The only negatives (for me) are:
I'm skeptical about the 900lm claim, but it's fine, it's still plenty bright
The UI
I really don't like the long press to switch it on. I much prefer the Olight UI. A long press for on is counter-intuitive, and annoying (for me)
I wish there was a way to go straight to moonlight/ultra-low from off (again the Olight can do this), or if I could turn off mode memory, and always start from ultralow?
It would be great if they copied the Olight's timer feature
Otherwise, I love this light - it's very practical. If OTR does an upgraded version, I'll certainly look at it.
ooi - has anyone swapped out the driver in their M3 yet?
This cree flashlight look like same as Olight S1. According to your comparison Olight S1 flashlight is more powerful than M3. S1 is one of the best edc flashlights. totalguide and comparison review is here. Then why buy that M3 flashlight?
