HKJ
(HKJ)
December 14, 2016, 7:10pm
1
Hibatt IMR14500 700mAh (Orange)
Official specifications:
Standard Capacity: 700mAh Real capacity
Minimum capacity: 650mAh
Rated voltage: 3.7V
Charging voltage: 4.20 ± 0.05V
Discharge cut-off voltage: 2.5V
Maximum charge voltage: 4.25V
Sustainable maximum charge current: 1A
Sustainable synergistic charging current: 2A
Sustainable maximum discharge current: 10A
Sustainable maximum discharge peak: 12A
instantaneous discharge current: 20A
weight: 23.1 ± 1.5g
allows ambient temperature: Charging: 0 ° C ~ + 45 ° C, discharge: –20 ~ + 60 ° C
Batteries surface temperature limits: Charging: 60 ° C, discharge: 80 ° C
dimensions: 14.2mm (D) × 50.0mm (H).
High current 14500 cells from China.
The two cells tracks very fine up to 7A, the 10A do not looks as good.
The temperature is fairly cool even at 10A.
Conclusion
The cells are slight overrated in capacity and current, but they have very good performance for high current 14500 cells.
Notes and links
Comparison to other LiIon batteries
djozz
(djozz)
December 14, 2016, 7:48pm
2
Thanks for the testing!
Nice batteries with the same performance as the windyfire 14500, but I like the orange colour better
Are the latest Efest imr 14500 cells in your line-up too?
HKJ
(HKJ)
December 14, 2016, 8:12pm
4
No, my queue is nearly empty. I have some Keeppower and have bought a few batteries.
evankouros
(evankouros)
December 14, 2016, 8:45pm
5
Thanks for one more great review HKJ! :+1:
I wonder if you have in mind to test these TF IMR14500 700mAh that seem to be decent for their price.
evankouros
(evankouros)
December 14, 2016, 9:18pm
7
HKJ:
It is in the queue.
Is it a long one? :sunglasses:
HKJ
(HKJ)
December 14, 2016, 9:25pm
8
As I wrote above it is nearly empty, with this I mean about one month testing. I do have test date for a couple of cell, i.e. it will be a few weeks more than that before everything is published.
I am looking for more batteries to add, but I will reduce my publishing rate in February or Marts, except if I get batteries from some manufacturers.
SubLGT
(SubLGT)
December 14, 2016, 10:57pm
9
HKJ, have recent Li-Ion shipping restrictions affected your ability to receive batteries for testing?
HKJ
(HKJ)
December 15, 2016, 4:32am
10
The only issue I have seen is a few $ extra shipping fee.
