Somebody help me figure out what’s wrong with my Blf A6. Noticed my lens starting to look a little foggy and there’s a black spot on my led. I normally turn the light off when it gets a little warm. Hope it’s not something I did. Still functions fine.
Update: replaced the star with led pre flowed because I’m a wuss. It was my first time doing anything like that. I know it’s stupid simple but still felt good when it worked thanks for your help. First baby step taken.
Insufficient thermal paste or ran too hot > LED and MCPCB overheats > Remaining solder paste or flux on the board is evaporated causing the fogging.
A small dark dots on the emitter surface normally means too much current or needs better heat sinking, sometimes it can be cleaned with some alcohol. (When it happens in a HI)
I would take the light apart and check for lack of thermal paste or bad reflowing job. Then run the light on turbo until it gets hot before assembling. I have seen soldering paste remains evaporating many times and fogging up the reflector, specially on the SMO ones.
Could just be flux and you can wipe it of easy?
You need to upload the photo to Flickr or another sharing website and then post the share link here.
So grab the photo sharing url and click the photo icon here and past the url where It goes in the box.
I mourn the loss of my favorite flashlight. Glad I have a second one in a warmer tint that I just discovered I like better. Now I have my first emitter swap to do. I feel like a idiot but the hard way is the only way I learn unfortunately.
