Any way i can test it? It looks fully blue to me but its not very bright.
365nm leds do not look blue to me , it is invisible (but the sensitivity for UV differs per person), all you see is the whit-ish component of the output. 385nm leds look clearly purple to me.
Check the light on banknotes, I know that in the euro notes there are fibres that under 365nm light up blue, green and red, but with 385nm, the red fibres do not light up red anymore. I’m not sure what the markings are on australian notes though.
u got convoy s2+ nichia to compare with?
That purple glow, do you see that with your eyes, or is it just picked up by camera?
If the bird is not yellow/greenish but blue-ish, and the leaves not really red, and if you clearly see purple reflected, the dominant wavelength is not (close to) 365nm, more 380-390.
Nope lol If i buy one it will take ages to get here. Unless some one in sydney has one we can use to compare.
Yea the glow is only on the camera Djozz. Sorry lads i dont know that much about UV LEDs The bird is yellow and the leaves are purple.
i got 3 convoy s2+ nichia when it was on sale
but i want AA version not sure if this one is comparable to nichia LED
I like the looks of these little blue Jetbeams
Send me bank notes from around the world ……and I’ll send you pictures of me running away with your $$$$
Christmas is about giving
Then it is probably correct.
Your in Melbourne?
bahahaha first you need a Santa beard!
Sorry Djozz one more question how bad are these for your eyes?
30 minutes drive to your place man
What is the diameter of the lens? If it is not more than 10mm, you can get a 10mm ZWB2 filter on aliexpress and get rid of the white background light. I never found a 12mm ZWB2 filter.
You Sleigh me …
depending on intensity, but: pretty bad, do not look directly into the beam and when looking at reflections: not too long. Checking a note for a moment is fine but do not stare for minutes.
Common polycarbonate protection glasses block 365nm very effectively btw
I bought this one, and also made me an S2+ with the 3535 UV LED from LED4POWER ( I think ?) and a ZWB2 glass.
I’ll make pics when my Jetbeam shows up to show the difference.
Maybe I should have bought another UV LED from known source and put it in a BLF 348 instead of impulse buying the Jetbeam…
