What is the diameter of the lens? If it is not more than 10mm, you can get a 10mm ZWB2 filter on aliexpress and get rid of the white background light. I never found a 12mm ZWB2 filter.
depending on intensity, but: pretty bad, do not look directly into the beam and when looking at reflections: not too long. Checking a note for a moment is fine but do not stare for minutes.
Common polycarbonate protection glasses block 365nm very effectively btw
I bought this one, and also made me an S2+ with the 3535 UV LED from LED4POWER ( I think ?) and a ZWB2 glass.
Iāll make pics when my Jetbeam shows up to show the difference.
Maybe I should have bought another UV LED from known source and put it in a BLF 348 instead of impulse buying the Jetbeamā¦
Are there any decent AA nichia on the market approximately same price as convoy S2 uv?? if not why no manufacturer fill the gapā¦iām sure few people would want!!
Forgot about that one (link does not work btw), it has the good filter but the led is weaker than the Nichia 276A that Convoy uses (but can be upgraded of course )
Is it possible put forward to the man āMr Convoyā to make/produce AA nichia version for us BLF?? how does work and why hasnāt he done it yet?? mmm?? As stated by Mr djozz and Mr Nicolicous other UV expensive and āā¦out of dateā so clearly there a hole and $$$ to be made but no one willing fill??
