I received mine in pristine condition hardly any dust. i know how hard it can be to maintain cleanliness in factory conditions so :+1: . The light is also amazingly bright , hot and throws like hell ,as far as many of my super throwers. Im overall happy with this GB.
However , i specifically asked for a SMOOTH reflector many times but got a op orange peel one .
HAIKElight Alva , How , can i get a smooth reflector ? In the future ,i meant to mod this light into a thrower like all my other lights.
Oh boy. Think they talked bout it, but I didn't think it was available then.
As far as the threads, yea, mine has some issues too, pic from the review:
Dunno, I think I noticed is at the time but didn't think much of it. I always apply Nyogel on the threads anyway, and they felt smooth, even though bare aluminum is showing on the outer 1 or 2 threads, just in isolated spots as well.
I just checked the other end (driver side) and those threads on mine are about perfect - can't notice any bare aluminum there. Mine also has double O-rings on each end.
That is my understanding too, but I find lumen and throw loss more annoying. Also, I imagine these separated die LED's to eventually be replaced by other types of big emitters as tech marches on.
Im holding my horses on modding it to xhp35hi since there might be a xhp70 hi eventually . The current brightness is unprecedented for a single led production light at this price ……until later when boredom wins patience….maybe :smiling_imp:
Received both lights today. Initial impression is they look nice, anodizing looks great, threads are cut nice with good close tolerances but there is some anodizing missing. Ordered 8 batteries and received 4.
Got 3 of them haven’t got around to test all of them yet but one of the MT03 button stuck… can’t change the mode, it’s just blinks non stop, the only way to stop it is to take the batteries out :person_facepalming:
My MT03 switch cover is not good. It’s like the rubber switch cover is made of thick jello; it makes for difficult successive button presses like turbo activation. There’s a lot of squish before activation and there’s a slight delay for the rubber to rebound off the switch. The MT07 switch covers are smaller, and much more solid and tactile.
Initially my MT07 would not function, but after taking the tailcap off a few times it started working. I haven’t been able to recreate the issue.
My 03 only has 4 modes, the 2nd and 3rd mode are the same, it will flicker between 2 and 3 but the output stays the same. No way to test the actual lumens so not sure on output. Of the two I prefer the 07.
You are probably right, 150 lumen difference would be hard to see. Crazy if they actually made the two levels that close. Went through the levels 9 or 10 times and while looking towards the outer edges of the beam, though I might have seen a difference once. ,While typing this I thought about the reviews and went back and read them as well as the specs from the company. The difference between level 2 and 3 should be way more than 150 lumens and easily noticeable. Still happy with the lights for the money spent.
The money definitely well spent, bad or no QC at best, but it still a GREAT light for the money, it’s quality far from Fenix,Nitecore,Klarus, etc but it’s still decent light, at the moment it might seems like they cranked these lights just to get it out door for the GB.
Rough machining marks on the thread, stiff button switch,scratch easily on the body ( mine came with few fine scratches )
But give it time and input, this company no doubt will grow into a fine one, think of them as early KIA motors.
In the beginning they offered cheap car with cheap stuffs inside the car, but now… they making really great progress.
I wish they offer DIY kit,or at least offer that MT07 in XHP 35 HI for cheaper price.
I bet those deeper reflector will give TN42 a run for their money, especially for the GB price.
Hi all I Thought I’d mention I found a good deal for the Sanyo GA batteries at at a company called IMR and just picked up 4 this evening seeing I got shorted 2 pair by Haike after paying about the same price of $5 ea., there is a also discount a discount code a friend and member here worked out for us which is code BLF15 for 15% off.
I checked at RMM’s and these batteries were about $8,50 each for 3500mAh 10A, IMR with discount was $5 each but then again you pay shipping which is about as much as you saved with the code.
