KD (kaidomain): Deals and new products thread
Possibly, yes…
You can put a main switch in the tail though.
Yeah, i thought so too.
But i don’t feel like gambling on the PWM.
Visible PWM is a deal breaker for me.
Thats. So. Awesome.
Guys, forgive my ignorence, but Simon's listing for the S2+ host sais "LED plate: Diameter 16mm".
Since the Triple Nichia 219C is 20mm, how can you fit it for the mod?
you would use a spacer. copper from MTN or kiriba-ru. Or self-built (filling a copper pipe or turn a rod on a lathe)
you can also use spare copper sheets, coins, metal pieces, …
If you value your time I’d recommend buying a spacer. It is easier and gives you peace of mind since they will fit. If you are quite handy on your workbench and don’t mind spending some time: You’d build a few spacers. I have made quite a few with coins, solder paste and it was easier than expected. Copper parts would be preferred though.
Thanks MILSPEC! :slight_smile:
For sure I’m gonna prefer a ready spacer, as I don’t have a suitable workbench (most probably not even the ability for a DIY spacer :blush: ).
Do you know where can I see a photo that shows how such a spacer (16 to 20mm) shows in a Convoy S2+ (or any other flashlight) ?
Note: Different lights require different spacers. S2 vs S2+ vs others and so on. With the height of the spacer you can also vary the overall inside dimensions of your light.
There are tons of triple builds around, with good build reviews and pictures. Especially here and on CPF.
I am building two myself atm but need to find more time next week to finish it off.
edit: Apologies for so much off topic all, but to stay on topic - the kaidomain triple 219C set is still on sale.
The 20mm triple optics I’ve received from KD are made by BICOM and identical to optics I’ve found in Eagletac/Sportac lights. IMO, the BICOM optic is closest to the Carclo 10511. The BICOM puts slightly more light into the periphery of the beam. I’ve also drilled out Noctigon boards to accommodate them. The legs are also longer so you could drill holes in the spacer to keep the MCPBC from twisting; or just file them down which I have chosen to do.
That is useful info, thanks!!
My 219C triples arrived today. :slight_smile:
KD is cool. :sunglasses:
Product request:
Cree XP-L2 V5 3A
…or V6 or W2… :slight_smile:
+1
V6 or up otherwise might as well get xpl version 1.
I would be happy with any of these tints.
3a, 3c, 3d
First time to order from kaidomain. What does it mean by “Order pending-packing”? Is my item out of stock? It’s been like that for about a week now.
It means the order is pending because it is being packed. took 24 hours for me at that stage.
you might want to contact BanL here on the forum if that status doesn’t change. or Abby on Skype (her ID is on the website).
Hi friend
I will help to follow your order and see what is the matter in that.
Please don’t be worried.
Thanks
Ban
Support @ kaidomain.com KD
Hi
We get a very limited stock for CREE XP-L2 V6 3B Neutral White 5000K in stock.
http://www.kaidomain.com/p/S026460.Cree-XP-L2-HD-V6-3B-Neutral-White-5000K-LED-Emitter
And also mounted on LED DTP Copper MCPCB
http://www.kaidomain.com/p/S026461.Cree-XP-L2-HD-Neutral-White-5000K-LED-Emitter-with-KDLIGHT-3535-16-16mm-x-1_5mm-DTP-Copper-MCPCB
http://www.kaidomain.com/p/S026462.Cree-XP-L2-HD-Neutral-White-5000K-LED-Emitter-with-KDLIGHT-3535-20-20mm-x-1_5mm-DTP-Copper-MCPCB
Thanks
Hi
Cree XHP35 HI D2 3D Neutral White 5000K CRI80+ LED Emitter is in stock
http://www.kaidomain.com/p/S026091.Cree-XHP35-HI-D2-3D-Neutral-White-5000K-LED-Emitter
Thanks
Couldn’t resist to order a XP-L2 V6 3B, although i normally avoid B and C tint bins.
On another note @ BanL:
I received triple MCPCBs but i ordered 20mm single 3535 MCPCBs.
The baggy they came in had the correct SKU number, but the wrong item in it.
But it’s okay, i’m glad to have them, but you might want to check what’s going on with that.
Hi
Sorry for our careless mistake.
You can PM me your order number and i would help to see what is the matter.
If you place the new order, i would help to take back the correct PCBs into it.
Thanks
Ban
It is now shipped. Thank you BanL.
Well those XP-L2’s didn’t last long, they’re already gone.
