Someone should receive it by next week.
What website are you guys using for tracking? I just tried 3 different ones and my tracking number isn’t found anywhere.
Try
Works good for me …
Item not found. Guess they never shipped it. That’s a little crazy, going to see what they say.
Send me your order details.
I used: http://en.4px.com
Most others, that I normally use, didn’t find squat.
WTF, must checked mine and I”m pretty sure they haven’t shipped either! It’s been almost a month and they haven’t even shipped!
Ozythemandias:What website are you guys using for tracking? I just tried 3 different ones and my tracking number isn’t found anywhere.
Were you able to successfully use that link to check your tracking status? If so, what code do you see here?
I’m going nuts with this @#%# verification code they show… none worked
RollerBoySE: Ozythemandias:What website are you guys using for tracking? I just tried 3 different ones and my tracking number isn’t found anywhere.
Most others, that I normally use, didn’t find squat.Were you able to successfully use that link to check your tracking status? If so, what code do you see here?
You should enter the result, in your example it would be: 10
Also tried that and it didn’t change anything. Will give another go
Now it doesn’t work for me either, i just get:
Operation failure, the exception code is null
But it worked fine earlier today.
They probably won’t fix it until they wake up in China, just a few hours from now.
(Personally I HATE CAPTCHA; it’s not that hard for a computer to bypass it and at the same time it makes life REALLY hard if you have poor eyesight. The blind are completely locked out (their OCR software can’t handle it).)
You need to enter the answer to the math problem.
It worked for me when I just tried it.
Works for me too now.
I don’t know the answer.
d/dx (f(x)) = 6 cos (x - (pi/2)) - 6 sin (2x - (pi/2))
When x = pi
6 cos (x - (pi/2)) - 6 sin (2x - (pi/2)) = 6 cos (pi/2) - 6 sin (3pi/2)
= 6 (1) 6 (–1)
= –6 + 6
= 0
The tracking is working for me and
Mine is on way, somewhere between Singapore and Uruguay. On time, normally takes about a month
When x = pi
= 6 (
1)6 (–1)
= –6 + 6
= 0
What happened to the derivative?
