Interesting “perception”. BLF has nothing at all to do with the claims of a Chinese manufacturer. BLF members have nothing to do with those claims either. We learned a long time ago that most manufacturer’s use the datasheet in their lumens estimations, not actual light output. There are a few of the big guys going to ANSI ratings, but you’ll pay for that apparently as those are usually more expensive lights. Budgets are met by cutting corners. Big green sphere’s that give the ANSI ratings are not cheap.
The D80 was thoroughly tested, even by myself as I was on the team, and then they changed specs. That’s outside of our control. A disappointment for all. And that was Lucky Sun, not Manker. A different basket of fruit, if you will. Manker was guided in the building of the X6/X5 lights and the Bistro drivers. I myself sent them a component list to build the drivers by, as I’d been building the drivers successfully for most of a year at that point. They did not adhere to the list, the drivers act up under heavy load.
BLF cannot be held accountable for any of that, if you think you’re coming here to get the true story, you’re being misled somewhere. Manufacturer’s are out to make money. The good people of this forum are picking up the pieces and running with em. Group buys are held and it’s largely a trust issue that they sample light will be a representation of the production light. We as members usually try our best to ensure the group buy is a face value thing, but we don’t have any control over it on the other end.
I can test a light, I can give you the actual numbers I see as recorded with my cells, chargers, and testing equipment. I cannot say you’ll have the same result with the light you buy. I have no idea if they pulled a sample light off the shelf at random and sent it to me, or if they cherry picked one they wanted me to review… I just don’t have any control over that whatsoever. The one thing you know here, in my thread, is that it got called like I saw it. I won’t pad anything or cheat to either direction, not for Manker or Utorch or Fenix or Nightcore or any of em. I’m not getting paid, I’m not getting swayed. These 2 lights are a good example of this. I will be sending the Manker U21 to a forum member in Malaysia to further test and prove out. Because he asked. I will be tearing the Utorch UT02 completely apart, torturing it, perhaps damaging it, perhaps modifying it. If I kill it, I’ll rebuild it, doesn’t matter to me either way. A lot of the lights I’ve reviewed have been given away. Some have been used in GAW here, one or two has been heavily modified and sold at the cost of the mod components. That’s just how I do it.
As with all things, weigh what you see, measure what you read, make an educated decision as to what’s going to work best for your needs. Then go with it. And have a Merry Christmas in the process.
