Sorry, I just watched the Matrix trilogy again, so I'm hung up on the one, in my mind. for a while.
I have a TK35 clone and decided to make it look and work different. You know I can't leave anything alone. I am turning it into a polished, 4NiMH, U2, 7135 clone.
Some of the light is polished and some is brushed. Looks a little different from the stock one.
Here's where the one goes to the source. I have never touched one of these lights, so I went to DrJ for some information and some help. I wanted to keep the light with batteries in series, but I also wanted to put in one of the 8x7135 linear drivers, to power it. I went to DrJones, since he is the source of the parallel mod and his driver program, allowing the two switches to be used, with the 7135 driver. In the photo, I have removed all of the original components and also in the photo below. They now serve only as contact points for the 7135 driver that will go in.
I also decided I might as well put some copper in it somewhere. It's just not a light without copper... I replaced the brass rods that serve as electrical links from the tail cap, to the board in the driver area.
I also changed the contact ring above to copper and made a copper outer cover over the upper contact plate that goes to the LED.
I am using Four 2/3A NiMH batteries, but they are too short in the compartment, so I have made spacers out of copper, to fill the gap.
The last photo is the where the wires will go, to the 7135 driver.
That's all for now. I am awaiting a driver to come in, from DrJ, so I can wire this puppy up and see if it goes or blows (up that is).
Well, the driver came in today. It came all the way from DrJ (thank you DrJ). I installed it and put the light together. It works great and I like the beam. I really don't have more build photos. I was too busy whipping it into shape and finishing it.
Low is 5%, medium is 40% and high is 100% (of course). It has DrJ's program in it, so it has the ramping, which I really like!
Here's beam shots.
ISO 200, F:2.7, Daylight WB, Shutter is 1 second.
ISO 200, F:2.7, Daylight WB, Shutter is 2 seconds.
It's a thrower and a nice one at that. Is has a large hot spot, but it's bright and I really like the beam, which is something coming from me, since I never like the beam from a smooth reflector.
That's all. It will be up for sale shortly.
