Great !
Now you can calibate it with a calibrated spectrometer or/and with pretested emitters and flashlights, its no matter that it costs 10$ or 50, as long as its calibrated it will work and serve your needs
Great !
Thanks a lot TA. :+1:
Very nice little device! It looks like you have done enough testing to ensure that it is a very useful device for relative comparisons and a pretty strong connection to and direct linear relations ship with official measurements.
Do you plan on assembling any for sale?
I am quite happy with the consistency, my fenix “test light” measures within 2-3 lumens every time. The overall calibration is as good as I can get it with the lights I own but I am quite happy with the results that I have seen. They line up with the Cree datasheets which is a good indication you are doing things right plus all the lights I have that do have ansi ratings are generally within reason as well. Plus it seems to line up pretty well with numbers posted around here.
I don’t plan to build them as the bulk of the cost is in the PVC and that is even more costly to ship.
I suppose I could sell the centering rings for others to build there own and I could share the CAD files for anyone that wants to print them out themselves. Although someone could also make them out of poster board.
The real issue is calibration, we should have a “standard light” that could be used to calibrate spheres but sadly nothing like that exists.
Brilliant. Hard to believe you only have 10 posts to this thread. Must be the holiday business because this thread is gold.
279 reads.
Incredible! Looks so simple to the naked eye, but its a very well thought out contrapment for those that know what really went on into creating this lumen tester.
How sturdy is it? If the area around the horse shoe was longer, if would be a very stable base, but I suppose you wanted it as small as possible, and if its sturdy enough this small, then even better.
I guess your not really pushing down on the pvc, so it shouldnt tilt forward.
So how big is the opening? Can the head to my btu shocker fit? my biggest headed lights are my trustfire j20, shocker, and the tn42.
I’m not quite sure in understanding the black electrical tape….so is the tape still left inside the pvc?
And lastly, so how does the readings work, just put the hs1010a on auto and whatever number you see, is the lumens? So in your photo, it shows 123, does that mean 123 lumens?
One ‘beef’: This is more a “Light Pipe” than a sphere I did a lot of reading-up about these creatures some time back and I’m a stickler for nomenclature accuracy I like both the electrical tape ‘tuning’ and the ‘baffle’; neither is conventional but both are brilliantly simple solutions. The only potential failure point I can see is the electrical tape which could lift, shift, or curl in time but that is easy to check.
We tend to over-think things sometimes and that can mislead by inducing ‘tunnel-vision’ which often leads to dead-end paths we get stuck on. The only thing here which really matters is the results- if they are accurate and consistent who can complain (and can the complainer do better themselves?). I’d like to see a few more details such as the highest and lowest lumens and the largest and smallest head diameters you’ve tested- that would complete this ‘review’ very well.
It’s a given that our home-made measuring devices will never be lab-grade in every aspect but that isn’t really necessary for our uses. To get within a few percent is totally adequate and a major achievement. I always say that if something is doing what it’s supposed to do there can’t be much wrong with it; and it seems you’ve got a winner here :+1:
Phil
Yeah, the idea and execution is quite simple indeed. It was the months of testing to figure out what worked and what didn’t that was hard. I overthought it a lot at first but turns out that the simplest option is the best one as well.
It is quite sturdy, PVC pipe is pretty tuff stuff. If you meant stable then it is actually surprisingly stable as well. I have never had it even attempt to tip forward. I lay my heatsink/LED test rig on top of the inlet port and it holds up just fine.
I used 3” PVC for this sphere because at the time I was too cheap to spend the extra $8 for 4” and the extra space would make it more of a nuisance on the desk. You could easily build this with 4” or even 5” PVC to fit any light you could want though.
The black electrical tape is my “multiple fine tuning adjustment”. Basically by sizing the tape just right and leaving it in the sphere it absorbs a fixed amount of light photos before they reach the light meter.
This in turn lowers the reading on the meter and allows me to have the meter output the lumens directly on the readout and not need an external multiplier. It makes taking readings much more pleasant since what you see is what you get.
Yes, the meter is on auto and in this case it was indeed reading 123 lumens. When the lumens go over 2000 it adds in a 10x multiplier on the meter but that is easy enough to figure out, if it has the 10x sign in the corner then you know that it would for example be 1230 lumens.
The name could be argued, IMHO sphere is anything that integrates the light to the point of beam profile/shape/angle not drastically effecting the readings. A light pipe classically does not do this so I feel it is closer to a sphere then a light pipe. Although the largest reason for calling it a sphere is that is what everyone else calls these devices and thus what they would search for.
Yeah, the first several prototypes of this setup were very overthought, didn’t work that well and were hard to use. When I finally said to heck with it and decided I didn’t care I went simple and to my surprised worked way better that way.
The real eye opening moment for me was when I realized the difference between a mathematically calibrated sphere and a standard calibrated sphere. DIY spheres are always standard calibrated. In this case there are only 2 things that matter, consistency and linearity. This checks both boxes so it is then just a matter of calibrating it to a good standard.
On a mathematically calibrated sphere (such as an ANSI certified sphere) things get way harder and that why they cost $10,000.
The electrical tape for tuning was another eye opening moment. I tested extensively to see if it would effect the constancy but it turned out that if the light was truly “integrated” it had no effect other then reducing the meter reading. As far as it peeling or currling, I have not had an issue yet but I also keep that fenix light nearby and check the readings from time to time. It always comes out within 2-3 lumens.
The largest issue I have is actually dust. I left the centering rings off of it at first when not is use and after awhile the dust started to effect the readings slightly. I blew it out and it was back to normal. So now I leave the smallest hole centering ring on it at all times to keep the dust out.
As far as the lumen measurement range, the min lumens it will detect is around ~5 or so, generally doesn’t detect moon modes and under 5 lumens I am not convinced of the accuracy.
The highest it has seen so far is a bit over 10k lumens from an 8X SRK.
For head sizes, it depends on the size of the PVC you use. 3” that I used Is cheap but the price goes up quickly as you go bigger so I decided to pass on that. You can get PVC upward of 6” though so max head size is not really an issue, just a matter of cost and how much space you want to take up.
I personally have measured from a BLF-348 up to a D01 myself, those are the smallest and largest lights I own at the moment, no issues with either at all.
I totally agree on being “good enough”, consistency is way more important then accuracy, as long as it is consistent then it is comparable.
Thanks for your posts, it helped me learn a lot. I especially like the way you modified the device so you can read values directly off the meter without a need for conversion factors.
Inspired by your work, I did a quick test, using a vitamin jar cap as a diffuser. I had to add 1 piece of white envelope paper, and one piece of kleenex, under the cap, to “calibrate” it.
I used my new Integrating Cap to test two Lumintop lights.
On the left a ReyLight Tool w Nichia, ReyLight modes are mfg spec to be 1-16-80
On the right a Lumintop Tool w Nichia head, on a Maratac body, Tool modes are mfg spec to be 18-3-80
you can see in the beamshot that the ReyLight obviously has a lower Low
it just helps to be able to quantify the differences, here is the ReyLight Low calibrated to read 1 lumen
and this is how that calibration reads the Tool head on Low
here are the beams on High side by side, and their readings (these are both N219b lights, you can see they use different batches of CCT)
ReyLight High
Tool head High
I then tested an L11c w Nichia, claimed high is 140 lumens… surprisingly it is only about 5 lumens brighter than the Tool on High.
Very interesting idea, I never considered going that small. That is thinking outside the box, good going!
I also tried many items like plastic and such for the integrating disc but nothing was just right. I didn’t think about 3D printing it until I already had the stryfoam done.
You also did remind me of one of the big reasons that I did this in the first place and realized it would work fine. The light sensors we use already have a diffuser/integrating dome over the sensor that it is calibrated to. So why would another one effect anything any differently?
A larger “integrating space” does help even out variations from beam pattern which is real important once you start dealing with different sized lights with vastly different beam patterns.
That is a tricky set-up, jon! To have a fixed calibration for all kinds of flashlight sizes and types, your set-up depends on a luxmeter that correctly reads light coming from any direction, hitting the detector at any postion (and as I understand, that is not an easy requirement to match for a luxmeter).
But the proof of the pudding is again in the eating, if in a series of tests, the calibration of this set-up proves correct enough in various types of flashlights, all is good.
Edit: TA had a parallel answer to mine .
I agree completely
I have no idea if my tests would be relevant with anything other than an AAA light with similar reflector, but it does let me compare similar heads at least. I dont trust the ~85 lumen reading on the AA L11c. Maybe my plastic cap is not consistent when the LED is closer to the plastic vitamin cap on the AAA head, and further away on the AA head.
great fun though, Ive compared a bunch of AAA maratacs and Tools with various drivers, LMH and HML modes, each in both N219b and with 3000k XPG swaps.
I can tell you a reylight with a 3000k XPG reads .6, and a reylight with a 4500k N219b reads 1 on my integrating cap (note that the drop in lumens is in proportion to the drop in CCT):
I also have an Olight i3s, whose stock 6000k XP-G low is mfg spec of 0.5 lumens, modded to a 3000k XPL it reads .2 on my meter:
and a Worm w Nichia (spec is 3):
the high on the Worm is spec 80 lum:
heres a Fenix E01, spec is 13 lumens:
some things are sort of working
Thanks for the inspiration Texas_Ace! :+1:
The real hard part with this type of thing beyond the sphere setup is getting a good calibration. This was my limting factor for my sphere. I simply didn’t have any better lights from which to use as a standard.
If I had a 100% known lumen output light calibration would have been 100x easier, the issue when all you have is modded lights or lights without trustworthy lumen ratings is picking which one to use as your standard.
In my case I settled on a midrange point between all the halfway trustworthy lights and then compared that to the Cree data sheets with a few LED tests.
I have no idea if it is accurate or not but it lines up with the ansi ratings on the few lights I have that came with them and it also lines up with cree data sheets and lastly it is in line with the numbers I see posted on here. So I am happy with the calibration.
true
at the very least though, you can determine which of your lights are the dimmest, and in what order
fwiw, I redid the L11c test with a hot off the charger Eneloop and got an extra 20 lumens compared to my earlier test, but still 35 lumen below spec
I still agree a larger diffusion area would do a better job of comparing lights that are not using the same heads
my Dinky Integrator is just AAA size for now… thanks for helping me get some cheap thrills
I still think you made a major contribution to the Integration Tool concept, by calibrating to your meter. That seems to work. I dont see any particular challenges in regard to consistency of the reading at Low vs High levels (in the narrow range Im testing anyway.) I think you concept is sound, and it made my whole setup really practical. Im very grateful for your contributions to my entertainment…
Yep, you can easily compare your own lights with a setup like that with reasonably accurate results.
I have really enjoyed the reading, thanks for sharing your knowledge.
Just wanted to say thank you TA for creating this thread. I've been playing around with improving my light tube using the ideas you published in the OP. Really has helped a lot. It has also got me trying other materials and designs. So far, nothing has done better than your model in the OP, but it's interesting to explore this aspect of the hobby. In the past, I've been frustrated and discouraged by how much my measurements could vary by just the slightest change in flashlight depth into the tube and such.
I call mine a PVC light box . I'm a little surprised the round spheres haven't taken off more so than the PVC light box designs. I think I read of some issues with the spheres, but haven't followed it closely. I haven't had time to look in adapting mine to how yours is set up here, but looks like it has definite benefits. For me, I'd probably want to build up a 2nd one, rather than losing my only means of lumens measurement while I build, tweak and test, then also I'd have something to compare with.
This is great work though TA!!
